Question about Fujitsu LifeBook S7211 Notebook
I'm using fujitsu life s series s7211 and could not start up my laptop . the fan is running, the battery icon is showing, but no screen.
Try to unplug the power from the back of the notebook and take out the battery and any other accessories. While no battery and power, press the power button for 10 seconds to drain everything inside. Plug the power back, turn it on w/o the battery. If you have a POST screen then try to go Fujitsu website to see if there's a new firmware for the notebook. If no screen then you need to take it to a tech/repair shop.
Posted on Mar 19, 2011
My fujitsu lifebook s7211,s series have startup
It seems like a hardware issue with the RAM you just put in. Please take it to the nearest service center and get it fixed. You may need to remove the RAM and reinsert it into the memory slot correctly. Also please check if the RAM matches the laptops specifications, ie, the laptop supports the RAM that you are installing.
Aug 31, 2014 | Computers & Internet
Remove bios password
You need to open it up and disconect the bios battery or reset with jumpers on mother board.
Oct 17, 2013 | Fujitsu LifeBook S7211 Notebook
When I plug my acer 7736/7736z Series laptop in to charge up the battery icon says 0% available (plugged in) not charging. After leaving it plugged in for an hour it still says the same thing. Any...
Try taking the battery out and running it. Some models will run without the battery, some won't. If it runs it's the battery that's shot. It is often the battery that goes as they only are good for a few years. I'm assuming you get into windows with it plugged in as you're seeing that it shows "0" left charge. Batteries will also get a much shorter life as it ages.
Jul 29, 2011 | Computers & Internet
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
I got a fujitsu laptop S7211. I lost my password its not the bios password. How to solve the problem. Pleasa help me
Hi open the link below for your passwrd recovery.
http://www.recoverwindowspassword.com/windows-7-password-recovery.htm
Jun 05, 2011 | Fujitsu LifeBook S7211 Notebook
How can I remove S7211 BIOS password
Find the original sales-receipt, to prove that you, and not a thief, is in possession of your laptop. Telephone Fujitsu, and ask for Technical Support -- once they verify that you are the owner, they can remove the BIOS-password.
Jul 17, 2010 | Fujitsu LifeBook S7211 Notebook
Laptop battery dead
nope, battery can die even if always on AC power with battery installed. Time to replace the battery. sorry for the bad news.
May 31, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu LifeBook S7211 DVD burner can't access CD
It may be one of the optics on the drive that has gone away, if so replacing the drive is the way to go. Most of the time you can get one off of eBay for around $30 or so.
If the drive is showing an error (or is missing) in device manager, do the following:
Start Registry Editor (Start, Run and type in regedit then click O.K)
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor.
Hope this helps
Apr 21, 2009 | Fujitsu Lifebook S7211 Notebook PC...
Fujitsu LifeBook S7211 Notebook Logo
184 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
