Question about Numark DM1200 DJ Mixer
HISS from Numark DM1200 mixer. Not present in speakers (self powered) when mixer off. Using XLR cables with telescoping ground lifts on each line. Monster 3500 power filter. Ideas?
  • Numark Master
  • 5,603 Answers
All interconnected equipment MUST be powered from the same receptacle or source. The XLR to the speakers should NOT have ground lift. The power for the mixer should come from where the speakers are and be routed alongside the XLR cables. All the other connected items should also be powered by the same source. The ground bounce within a building cannot only cause noise, but can rupture the input circuits of equipment. As an electrical engineer I don't know why manuals supplied with the equipment doesn't go into this more. The professionals at the big venues all know this as they have had to pay to get equipment repaired.
Now to get down to "hiss" once you get the other stuff straightened out, there are two things to know at the start: The first is that due to the statistical nature in electronics "noise and hiss" are among the laws of physics that we can't completely get around. The level of the hiss should NOT be objectionable however. The second thing is that proper level setup is important to minimize the effects of noise and hiss. You should be sending the levels to the powered speakers at near full line level into the line inouts, never mic inputs that some have. Using excess gain at the speakers will amplify any noise pickup on your audio lines. Next, at the mixer, try to keep all the level controls around 10 to 2 0'clock for rotaries and 70% for faders. Excess gain at certain stages will cause hiss to be objectionable.
Posted on Mar 19, 2011
Have a low noise like hum when i turn on thump 15A It doesn t change by moving level but when I plug in anything it s feeding a noisy tale on every signal attack.
Make sure you are using BALANCED audio line to the speaker AND your mixer is powered from the SAME receptacle as this speaker. One MAY have to run an extension cord back to the mixer and othe equipment, but this must be done to reduce noise and also for equipment safety. Multiple recepatacles in a building have grounding issues that can generate noise or worse damage equipment due to ground loops. If you DJ mixer does NOT have balanced outputs, use DI boxes so you can use balanced lines to your speakers. Your cables will either be XLR or 1/4 inch TRS types, not just TS type.
May 14, 2011 | Mackie TH-15A Active DJ Powered THUMP...
I have just bought a PRX612M. When I play my digital piano through it at low volume there is a buzz which is most noticable as the notes volume dies down. Loud it sounds great but i would love to know what...
1000 Watts? Well, those are peak values. !000 watts RMS into a 12 inch speaker and it would smoke... this is some of our inflated advertising. But that is beside rhe point... now on to your problem: What you are having is a ground loop. You may have to do more than one thing to correct this here is the things to do in the order to do them to solve the problem:
1. Connect the piano and the speaker to the SAME power source or receptacle, even if you have to run an extension cord, three wire of course. Plug all of this ONLY into a grounded outlet, if your house has only two wire plugs, then you need to get an electrician to install a grounded receptacle.
2. Use Balanced lines. This means XLR or TRS balanced cables between the piano and the speaker. Use the 1/4 inch jacks output, not the RCA ones.
3. Since the AUX outputs do not support balanced lines, the next step require you use DI box. They are about $20 from Guitar Center and others. With very short 1/4 inch mono cable connect the piano to the DI box from the L/R mono piano to the high impedance input port of the DI and set the ground lift switch to "LIFT". Use an XLR to XLR cable from the DI box to the speaker. This last step if needed is the last thing in our bag of tricks to break the ground loop that can cause the buzz. Dirty power, if you have lamp dimmers can be a source of the noise.
Apr 06, 2011 | JBL PRX612M 12 Inch Two Way Self Powered...
Humming noise since adding a vocopro DA-1050pro mixer to our system.Have connected a ground loop isolator but it makes no difference.The mixer is the only change in the system
Make sure ALL interconnected equipment is powered from the same receptacle or source such as power conditioner. This isncludes mixers, amps, CD pllayers, etc.
Second make sure ALL interconnecting cables are BALANCED lines using XLR or TRS cables.
Isolators other than DI boxes are a no-no.
Mar 30, 2011 | Vocopro Da1000pro Professional Digital...
I record a podcast with the 8track multimix usb Alesis. I use one XLR - Jack input and the rest XLR-XLR. There are 4 inputs being used in total. I seem to be getting alot of hiss and buzzing from the...
What is the source of the input signals? These need to be balanced lines and the sources need to be balanced. If you happen to be using condenser mics, you probably haven't turned on the Phantom Power in the mixer. If you are recording from a sound card in the PC, those have a lot of noise and are unbalanced and you have to use DI's with ground lift ahead of this mixer.
Feb 08, 2011 | Alesis Multimix 8 USB 2.0 8-channel Mixer
Kpc10mp line out jack dos'nt work
These are hard to work on... but one possible thing is if you are using an XLR adapter that is going from balanced to unbalanced 1/4 inch plug. You need to go XLR to XLR on this one. The MONO adapters can ground out the signal as these things don't always drive balanced signals... The signals are also line level so one does NOT want to use an impedance converting adapter.
The preamp is mounted on the plate with the jacks and has pretty short leads that limits how far you can pull it out. Taking off the grille and removing the woofer to get access can be a pain, especially to get the grille back in with the rubber edging.
Of course there is always the possibilty that the driving op-amp on the preamp board could have been fried. Word of WARNING: Power ALL interconnected parts of your system from the SAME receptacle or source. Powering say a mixer from a receptacle at the back of the room and powered speakers from a receptacle at the front is a good way to have equipment fried by "ground bounce" on the power system. Run extension cord to your mixer from the front where speakers are powered!
Dec 31, 2010 | Kustom KPC10MP 10" Powered Monitor Speaker
Bought a powered monitor as it said to do even though I thought it was weird as you usually use a passive monitor with a power amp. Purchased Kustom 10" powered monitor, hooked it up to monitor...
You didn't mention what brand powered mixer you have, HOWEVER MOST powered mixers also have a line level monitor and main output jacks. These are almost always 1/4 inch jacks. In any case you should be using BALANCED lines to the powered speakers using either XLR or TRS connectors on the ends. Please tell us what powered mixer you have so we can give you better answer regarding which connections to use. IF for some reason your mixer does NOT have line level outputs, you can use a high level Direct Box to condition the powered outputs to be sent to the powered speakers..
Also make sure ALL your interconnected equipment is powered by the same receptacle or source to avoid damaging due to ground bounce on utility lines and circuits. This often means running an extension cord from the stage where the powered speakers are along with a snake of the audio cables.
Dec 10, 2010 | Kustom Profile 2 PA Speaker / Mixer Stand
WE ARE EXPERIENCEING RADIO INTERFERENCE AND ARE BLOWING SPEAKERS, DO WE NEED TO HAVE THE MIXER AND EQUIPMENT ON UPS SYSTEMS WE ARE USING NADV AUDIO PM-200 A POWERED STAGE MOINTOR 115/230 VOLT SER#...
UPS will not help this. Make sure you are using GOOD quality balanced cables, preferably XLR to connect to powered speakers. Make sure ALL (read that "ALL" closely) of your equipment is powered from the SAME receptacle or power module... this means run power to your mixer or speakers alongside your audio lines or snake between the units. This includes ANY other devices tied into your mixer with the exception of truly ground lifted DI's.
Good way to pop speakers is to run them on stage power and mixer from plug at the rear of a room... The common mode ground noise will exceed the common mode capability of the audio inputs and fry them.
Nov 30, 2010 | Behringer XENYX 2442FX Mixer
DXM09 MIXER ADAPTOR
Often the cord has broken wires. First try to repair the power supply.
Also check the connector in the mixer as they can get damaged by side pulls of the cord.
Sep 28, 2009 | Numark DM1200 DJ Mixer
I have a numark cd mixer and one of the cds wont play can you help me find a place i can take it to fix
Where are you located? Also, is the mixer the problem or is it the actual player that is not working?
Thanks,
Dan
Aug 16, 2009 | Numark DM1200 DJ Mixer
Numark dxm power failure?
i'm having the same problem, just wondeered if you found any solutions to this?
Jul 14, 2009 | Numark DM1200 DJ Mixer
Numark DM1200 DJ Mixer Logo
210 people viewed this question
Top Numark Music Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
rhodesworks
Seanzilla
Are you a Numark Music Expert? Answer questions, earn points and help others
