Question about RTO M-D Building Products Carpentry & Construction Box Beam Level 48"
Refinishing my basement....my basement is paneled and has 1x2 behind it. It is not insulated.Do I take it all down or should I put up 2x4'sandinsulateand refinish?
  • Richard Crate Mar 19, 2011
    Hello. Without knowing what climate you live in, I cannot say what should or should not be done. However, considering a few more details may help clarify. 1) What is your climate? Living in a warm climate may have less need for insulation compared to my winters that can get to ?30°C or colder at times. 2) The ability to properly vapour barrier your basement with a complete re-do will assist in dampness control. 3) Your walls will be sturdier/stronger and hold up over time better with 2x4?s rather then just strapping. 4) 2x4 construction will allow for electrical to be done in accordance with local building codes. And 5) proper installation of a 2x4 wall will prolong the life of the materials used, which in turn will show your basement better.
    I realize this does not provide you with a clear cut ?do or don?t? answer, but consideration of these points will greatly assist you in defining your options.
    Looking forward to hearing back from you,
    Richard
Take the paneling down to inspect condition of wall behind it.
This will reveal termites, or wiring problems, or cracks and leaks that might need attention.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 19, 2011
The hazard lights im my 2003 chevy trailblazer stay on. Even though there not turned to on position
The turn/hazard flasher module is probably bad .
Removal Procedure
  1. Remove the left closeout/insulator panel. Refer to Instrument Panel Insulator Panel Replacement - Left Side in Instrument Panel, Gages and Console.
    showgif.do?image=763321
  3. Remove the flasher retaining bracket from the insulator panel.
  4. Disconnect the flasher from the electrical connector.
  5. Remove the flasher from the vehicle.
Turn Signal/Hazard Flasher Module
Behind the I/P near the headlamp switch
Dec 30, 2015 | Cars & Trucks
I am fixing a closet in my home. It is part of an exterior wall and creates a lot of coldness in the house. How can I insulate this wall better? My kid is freezing at night she says. <a href
If you have enough room behind the stud wall install 1" rigid foam tape seams and then use the thickest possible roxsul insulation to fill the studs. Or axe the foam and install 6mil plastic on warm side of the wall after insulating tape all seams when done.
Jan 30, 2015 | Cam Spray Pressure Washer Foamer...
My Carrier Infinity system Model FE4A is leaking water from the bottom of the unit on to the basement floor. How do I stop the leak?
have your HVAC technician check the pressures in your unit...sounds like you may have low pressure. You should NOT be having any ice build up to melt off.
Sep 13, 2014 | Carrier Infinity Series Variable Speed...
I have noticed blue mold in my basement coming from behind the area that has wood paneling, but also around the entire edge of the floor even where the walls are concrete (both interior and exterior...
This mold is from dampness in the basement.
Often this is a result of no vapor barrier installed when the insulation is put into the walls. Moisture is allowed to seep through the walls and gets into anything, even concrete.
The other problem may be from a lack of weeping tiles outside the house.
When the contractor formed the foundation walls, he was supposed to install weeping tiles to keep moisture out from outside.
Most older houses don't have this, and I'm seeing it more and more.
I would advise contacting a general contractor and getting some advice from them. You may have to have weeping tiles installed, which consists of tearing up the ground around the foundation to do so.
Then you may have to remove the flooring and wall panels as well as the drywall to install a vapor barrier.
Good luck.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Sep 22, 2011 | Computers & Internet
I have a early model 88 .308. it was in good shape, but sat in a closet for a month after a house fire. there is no fire damage but was laying with wet clothing. It now has a fair amount of pitting on...
The gun seems to be worth around 700-800$ in decent shape, so I'd say depends on the price for refinishing. Try to see if you can get an estimate. If you're not planning on selling it, and keeping it in the family. I would recommend getting it in good condition and put in a nice case so it can stay good.
Jul 28, 2011 | Sport & Outdoor - Others
We have a small leak (drips) on the rear end passenger side of our 2001 Fleetwood Southwind. Where are our holding tanks located?
Does this leak have a color to it? Take and dip your finger in it and put it on a clean white piece of paper. What color do you see?
Regards, Tony
Apr 21, 2011 | Ford F-250 Cars & Trucks
Need attic insulation for ladder area
Buy some styrofoam panels at the hardware store. They're usually 2"x2'X4" and they only cost a few dollars. Also get a small tube of construction adhesive. Stick them to the top side. Styrofoam if one of the best insulators you can but. I have it on the inside, of my metal basement door. In the winter, when the temperature drops to 10 °, my cellarway maintains about 65°.
!/16" thick styrofoam protesct your hand from 170° coffee.
Aug 11, 2009 | Hand Tools
How do I eliminate of vastly reduce the road
put carpet down and fill the door panels with insulation and put some sort of insulation(sleeping bag) in the hatch on the floor. take some housing insulation board, comes in 4X8 sheets and cut an fitting piece to place behind the rear seats in the hatch.
Apr 19, 2009 | 1998 Honda Civic
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
RTO M-D Building Products Carpentry & Construction Box Beam Level 48" Logo
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Tim Venetis
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
