Question about Sony DAV-DX255 System
My son turned on the dvd player and it brought it up in black and white. Curious of how I change it back to color settings? Thank you
    Master:
  • 525 Answers
If you are using component cables red blue green make sure they are all securely fastened.
Posted on Mar 19, 2011
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
NV-VP60GC-S How do I get the color?
really? that's a settings issue..open up the menu(got a manual with this item?) and reset for defaults.
May 23, 2008 | Panasonic Multi-System Region-free...
How to change ntsc and pal settings in a sony bravia ex400? It shows black and white color with a dvd player.
how to change ntsc and pal settings in a sony bravia ex400? It shows black and white color with a dvd player.
Jan 22, 2011 | Sony BRAVIA KDL-V40XBR1 Television
How to change to color from black and white
Pls check if your unit has a selection for NTSC/PAL, if yes toggle between the two. It normally would be in the Menu Setting.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Exonic EXD7010 Car Video Player
Dvd only playing in black and white
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Aug 06, 2008 | Sony DVP-S500D DVD Player
Curtis progressive scan DVD player 1071
your not using progresive scan out are u change that back to regual
Feb 06, 2008 | Curtis Progressive Scan DVD Player 1056
RTD 155 - only black and white...no color
Perhaps you have set your DVD player for Progressive Scan Mode while your Television does not support for the same. Go to the setup menu and turn Progressive Scan Off. This will solve your problem.
Feb 04, 2008 | RCA RTD155 System
TV plays color, dvd black and white
If I understand your post/description, the DVD plays OK except it is in Black & White. If so, change setting from PAL to NTSC or vice versa depending on the region you are in. US operates on NTSC, Most of Europe is PAL.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Jan 19, 2008 | Jwin Electronics JD-VD138 DVD Player
Tv/dvd combo only plays dvd's in black and white
Finally figured this out. On your remote push tv menu until you get to function. You should automatically be under col.sys. change this to NTSC. Took me awhile to get remote to work here, ended up pushing in the middle of the red vol +,- bar on the right of the remote. Couldn't find the right button according to the directions on the screen. DVD is now in color!! If you are not already on the option to change col.sys, use the red channel up down bar on the left of the remote.
Feb 22, 2007 | Jwin JD-TV1300 13 in. TV/DVD Combo
Sony DAV-DX255 System Logo
103 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
