Question about Bose Lifestyle 38 Series III System
I have a Bose ps28 III. There are five speaker wires plugged into five separate connectors in the back of the unit but only one speaker connection works. There is a green light blinking.
4 Suggested Answers
SOURCE: Bose Cube Speakers separated
Ok…
I had the same problem with a Bose separated double-cube Acoustimass speaker/array but was able to fix it as follows:
Tools:
small, thin, flat-head screwdriver
large pliers
C-clamp
Instructions:
1. Disconnect the speaker wires from the cube.
2. Remove the grille from the top speaker cube. It just pops off.
3. Insert a small, thin, flat-head screwdriver around the perimeter of the speaker. You will have to pry lightly to break the glue’s seal.
4. Using a set of pliers (large, plumber-sized) wiggle the speaker until it comes free. You might need to grip it top to bottom and then left to right. The speaker will come free of the case.
5. Remove the white insulation to get a clear view of the dislodged brace/connector.
6. Stack the top and bottom cubes. Make sure that the rubber seal between the cubes is seated properly and that the black and white cables are not pinched.
7. Using the C-clamp, compress the brace/connector until it seats on one side. Loosen the C-clamp and compress the opposite side. The brace/connector should snap into place. Be sure the make sure that you do not pinch the speak wires that are running through the center of the brace/connector.
8. Test the articulation. It should be the same as your other speakers.
9. Replace the white insulation in the back of the speaker case.
10. Press the speaker into the case’s face. If you wish, you can apply your preference of glue to the edge of the speaker prior to pressing it into the case.
11. Snap the grille onto the speaker.
12. Connect the speaker wires to the cube and you are done.
You should be good to go.
Posted on May 17, 2008
MarineTech1
  • 76 Answers
SOURCE: No sound Bose Lifestyle 38 III
I am quite sure that the indicator lights should be green. The blinking yellow likely indicates that there is no communication between the head and the audiomass. Verify that the connections are tight and then try powering off (unplugging) the system (both head and audiomass) for 30 seconds and then powering on again. That will often re-establish communications.
Posted on Aug 22, 2009
bobhifi
  • 635 Answers
SOURCE: my bose ps28 is making
You have lost the sponge roll surround of your subwoofer ( suspension ). Its known as foam rot.
Either you can buy new woofer drivers for the subwoofer or repair the surround alone. Kits are available. But you will need some technical skill.Check out this link.
http://popular.ebay.com/consumer-electronics/bose-speaker/bose-speaker-repair.htm
Posted on Mar 10, 2011
I want to connect my Bose ps28 iii to another reciever. How and what do I need to make this possible. If I run a av left right to the unit will the reciever turn the unit (bose woofer) on.
The media center plug is wired to carry your left/right signal for front and rear along with reference and turn on voltage. Here's a link to the media center cable pinout images. If you have the connector you can pigtail in your high level inputs (speaker out from the amp you want to use to the corresponding pins. However, I can't guarantee this will work. Bose makes these cables proprietary for a reason... to make money. If hillrods like you and I can easily hack their stuff then they wouldn't be able to overcharge for their goodies. Here's the pinout link anyway. Good luck! http://www.google.com/patents/EP1605637A2?cl=en
Mar 01, 2016 | Bose Audio Players & Recorders
Can I connect a Bose lifestyles PS28 woofer to a PC without the Bose Control or brains? How?
You probably can if you're patient. Here's a link to the media connector pinout. You'll have to cut a 3.5mm cable and tap into the left/right audio signals (Z1 or Z2). I'm not sure if the sub will stay on without the 10v on signal or not. That will be another problem to solve once you've tested the 3.5mm connection. Use the schematics provided in the patent link to make your connections. http://www.google.com/patents/EP1605637A2?cl=en
Feb 22, 2016 | Bose Audio Players & Recorders
How do I test the Bose ps28 3 sub woofer without any other bose components?
Thats a toughie because that system is well..a system. They build those so that each component runs through that main circuit board there and then thru the outs on the sub--I would look for a used player that you can hook it up to or pass on it.
Jan 24, 2015 | Bose Lifestyle Ps28 Iii Subwoofer Dual...
Need to replace pigtail fuse
This may not be a fuse. Bose uses devices like this as "speaker protection". If this device is wired to the woofer, that is exactly what it is. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 01, 2013 | Bose Lifestyle Ps28 Iii Subwoofer Dual...
I have a pair of redline bose cube speakers and an acoustimas. I don't have cable for the connection. I would appreciate if someone help me showing diagram and which cable I should use it. Thanks
You can make a serial cable for it. All you need is a 15-pin d-type female connector and a bunch of speaker wire. Solder the speaker wire as shown in my diagram.
Sep 22, 2009 | Bose Acoustimass 10 III System
Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
Jun 24, 2009 | Bose Acoustimass 10 III System
Ok…
Tools:
large pliers
C-clamp
Instructions:
Aug 29, 2007 | Bose Lifestyle 12 System
Bose Lifestyle  38 Series III System Logo
486 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
