Question about Cameras
My camera says it is write protected ???? i cant use it now :-( how do I correct this (if I take the card out I can take pictures but not when the card is in )
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
You didn't specify the make and model of your camera, so I'm assuming it uses SD cards.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 19, 2011
There is no sd card inn my camara but it reads write protect and cant take any pictures
As long as you don't put in any memory card, where the camera can put its pictures, it will say write protected.
If you did put in a memory card the wrong way around you also can have damaged the little switch in the memory card holder, so it always thinks the switch is engaged. Please put in a correct card, with the lock switch up. Not pointing to the lock position and check if that will work.
Oct 12, 2014 | Olympus SP800UZ Digital Camera
Camera shows write protect when open
When what is open? Always keep the battery / memory card door closed. If it is not closed correct, the camera won't work as expected. To protect the file system, when someone should pul out the memory card, while the camera is accessing the memory, it will or shut down completely, or at least protect the memory card against writing to it.
Before opening the battery / memory card cover, always make sure the camera is completely shut off. That means no light is allowed to burn or flicker. The memory card can also be write protected (SD cards) when the lock switch is down like in the picture on the 32GB card.
Before you can make any picture the switch on the card should be up like on the 64GB card on the picture. 3635bcf4-65df-478c-a04d-92e341d15860.jpg
Jan 29, 2014 | Cameras
Camera. Card's write protect switch is set to lock
i try to write protect my pictures on my camera canon eos rebel t3 after that i cant snap i cant do anything when i press the shutter button then it write cards write protect switch is set to lock please help me
Feb 06, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
When i got back my lostet pictures whith a program named ;cardrecovery, ,i can see the picture in a net bok ,but when i put the card on my camera it seys;card protected,, i cant make a new picture ,,,,the...
Apr 28, 2011 | Fuji FinePix S1000FD Digital Camera
Cant Take pictures
1) Take the card out, check the card, halfway up the left hand side, there may be a sliding notch. Move it to "Write enable".
or
2) Go through your camera menu look for photo protect, check if you've write protected all your photo's.
Just in case, you can download a user manual from here:-
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
May 30, 2010 | VistaQuest VQ-5015 Digital Camera
Fujifilem Z20fd I cant turn the card protection off which appears
Is your flash working? Do you have the flash turned on?
Jul 11, 2009 | Fuji Finepix Z20fd Digital Camera
Write protected-Olympus EVOLT E-510 Digital Camera.
Hi there
The write protect is on the memory card, take the card out and unlock it, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for using Fixya!!
May 15, 2009 | Olympus EVOLT E-510 Body Only Digital...
Protected card pops up and i can't take or delete any pictures, but i can look through the pictures.
remove the card. there is usually a switch on the side. turn it to the other position.
Apr 19, 2009 | Kodak EasyShare V1073 Digital Camera
Cant take picture. polaroid a500 camera reads sd protected.
It means the sd card cant be accessed unless you remove the protection . Connect sd to laptop and use software to remove the protection .
Mar 13, 2009 | Polaroid A500 Digital Camera
Protected card pops up and I cant take any pics?
Remove the card from the camera.  There is a small slide tab on the card which shows a picture of a lock.  Move the slide tab to the unlock position.  If this doesn't fix it, replace the card.
Nov 11, 2008 | Fuji FinePix A201 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
