My acer aspire 1650z recovery dvd is damaged and disk to disk doesnt initialise . the erecovery utility doesnt seem to be present. how can i fix this
    Master:
  • 525 Answers
Call acer and order a new set of recovery discs. It will cost you about $20.
Posted on Mar 19, 2011
How do i do a system recovery without a disk
Try This . When the System CD and Recovery CD are not available, you can create them by
using this feature.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery window, select Recovery settings and click Next.
5 In the Recovery settings window, select Burn image to disk and click Next.
6 In the Burn image to disk window, select 01. Factory default image and
click Next.
7 Follow the instructions on screen to complete the process.
Jun 24, 2011 | Acer Aspire 5500 5570-2609 Laptop
Factory reset for Aspire one without disk and alt + F10 doesnt work
The disk-to-disk recovery may be disabled preventing the Alt + F10 key sequence running eRecovery. To enable disk-to-disk recovery, you must do the following... (do not have an external monitor attached)
1. activate the BIOS utility by pressing F2 during Power On System Test (while Acer logo displayed)
2. select Main from the categories listed at the top of the screen
3. find D2D Recovery at the bottom of the screen and use F5 and F6 keys to set this value to Enabled
4. exit the BIOS utility and save changes.
The system will reboot.
5. while the Acer logo is showing, press the Alt key and the F10 key at the same time repeatedly
6. wait as Acer eRecovery starts up then follow onscreen instructions to perform system recovery.
Alternatively to the above, if Windows can be accessed, the recovery can be done by launching Acer eRecovery Management by running the program from the Acer Empowering Technology program group in the Start menu.
Mar 22, 2011 | Acer Aspire One PC Notebook
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Cant restore factory settings Acer Aspire One A110-Ab 8.9" 1.6 GH
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Jul 13, 2010 | Acer Aspire One Netbook 8.9" Notebook
How do I do a full recovery with the disc
Turn your computer on.
Insert the Disk and choose to enter BIOS, should be F2 but watch the screen to see the right function key.
Change the boot device order to: CD-ROM, HDD in that order.
Save changes and restart the computer.
The Recovery Disk would boot up and a wizard will guide you through the recovery process.
Follow the instructions to recover your computer.
Apr 03, 2010 | Acer Aspire 3050-1733 Notebook
Error: 0XC000000C; What's the solution?
My 0xc000000c problem seemed to result from disk surface damage on the restore DVD. I burned a new copy of the restore DVD and the restore then proceeded normally.
Using a DVD copy program that provides an aggressive read method to extract data from damaged disks might help you the most.
Nov 08, 2009 | Acer Aspire 5100 Notebook
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
2 Press Alt + F10 to open the Acer eRecovery Management utility.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process
Here Acer download page: Acer Service & Support
May 05, 2009 | Computers & Internet
How can do i clear my hard drive and reinstall windows
You can launch Acer eRecovery Management in a number of ways:
By pressing the hotkey <Alt> + <F10> during the boot-up process, or at any
time when you are running Microsoft® Windows®.
This will open the Acer eRecovery Management main page.
Password
Acer eRecovery Management requires a password to activate. The default
password is six zeros (0s).
Note: If an incorrect password is entered three times, Acer
eRecovery Management closes and returns to Windows®
automatically.
System recovery
Step 1: Click on “Recovery actions”.
Step 2: You are presented with a list of available options
CHOOSE-->Recover system from CD/DVD backup
If you choose to restore from an image on an optical disk, the BIOS will be
changed to boot from the optical drive. If no backup disk is found, you are
prompted to insert the disk.
Reinstall
IF THOSE DISKS DONT WORK , YOU CAN ALWAYS RESTORE TO FACTORY SPEC FROM THE HIDDEN PARTITION ON YOUR HARDDRIVE.
Hope this helps you out .. Regards
Apr 07, 2009 | Acer Aspire m5640 PC Desktop
Acer d2d recovery problem
Idiot. You deleted the partition containing the D2D.
Mar 03, 2008 | Computers & Internet
D2d recovery
Is the d2d erecovery function enabled in the bios?
To check, activate the BIOS utility, press <F2> during the POST; while the notebook PC logo is being displayed.
To enable D2D recovery ard disk recovery), select Main from the categories listed at the top of the screen.
Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled.
That should allow you to use the F10 function key to activate D2D.
* Note: D2D e-recovery is not in Acer Empowering Management.
AEM is a power management utility that supports ACPI (advanced configuration and power interface) which allows for maximum power conservation and maximum performance. (Managed by the windows OS)
Jan 04, 2008 | Computers & Internet
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
