Question about Thomas and Friends Bring Along Thomas the Train Set
How do i put the little tikes Thomas the train bed together?
Need instructions/method to put thomas bed canopy together
I wasn't able to locate instructions online for you but if you contact your local kid's furniture shop they might have spare instructions for you.
Jun 19, 2012 | Baby Gear
Moved and now missing is the hud caps on the wheels which say little tikes
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Dec 01, 2011 | Little Tikes Roadster Toddler Bed
I have the Little Tikes train 4505 and need a battery, charger and a new connector to the battery. Where can I find these parts or is there another way to fix these problems?
Janice We also have a little tikes train circa 1980's that we would would llike to get running for our grandson. I have ordered a battery from Apex Battery.com. I believe that The Elpower EP695 battery should work. It is the right dimensions and is a 13 Amp hour battery vs the 9.5 amp hour that was installed. We do not have the connectors for the cars and wonder how they connect together. Could take a photo of the car connectors and post it so that we would have an idea of what we are looking for. Thanks
Nov 04, 2011 | Toys
Little tikes lightning mcqueen toddler sized bed replacement decal kit
I found something on amazon, click here and take a look: Amazon com Little Tikes parts. I hope this was helpful. Cheers
Aug 24, 2011 | Little Tikes Toys
I am not able to put this train set together some tracks have letters others numbers
the tracks with letters are misty island put c and d together for corners (swap other side) then rickty bridge inbetween on one side and switch track on other. For numbers pretty much you can go by number (start with 1 and go left) I had to fidget a little but it worked
Jan 08, 2011 | Hit Thomas the Train Misty Island Deluxe...
I am looking for the white plastic "hub cap" for the red twin size Little Tikes race car bed. It's not the sticker but an insert.
Hello. You can order the parts directly from the company at the following link: http://www.littletikes.com/consumerservice/replacementparts.aspx
Thanks for choosing fixya! Regards, Joe
PS please rate my answer. Thank you.
Dec 11, 2009 | Little Tikes Sports Car Bed Frame Police...
Crack in toybox of little tikes racecarbed
Depeding on which bed it is ( older or newer) you may be able to get a replacement lid from little tikes directly.
If it is not replaceable, a little bit of silicone caulk should fix the crack good enough where little fingers should not get pinched.
Feb 06, 2009 | Little Tikes Sports Car Bed Frame Police...
How do I get the white hub cap off of a little tikes race car bed
If it is a real wheel and not just a sticker decal. There should be a little tikes logo right in the middle of the wheel. The only way to get that off is to break that off. I found that if you take a flat head screwdriver you can break just one side off and then turn it around so the whole thing doesn't break off. That way you can get to the screw that is under the logo. When the bed was first put together it was made to stay together. I had the same problem and was on with little tykes and they said the only way to get it off was to break off the logo. Just break the one side though and turn it out of the way so the whole thing doesn't completely break off.
Dec 04, 2008 | Little Tikes Sports Car Bed Frame Police...
Thomas and Friends Bring Along Thomas the Train Set Logo
65 people viewed this question
Top Thomas and Friends Toys Experts
Tom Chichester
Bill Boyd
Are you a Thomas and Friends Toy Expert? Answer questions, earn points and help others
