Question about Whirlpool Dishwashers
Water won't completely drain out of our quiet partner 111
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on Mar 20, 2011
Whirlpool quiet partner II starts and stops. What should I check?
the first thing to do is unplug it for 3 minutes then check to see if it reset by running
Jan 07, 2018 | Whirlpool 24 in. DU951PWB Free-standing...
Whirlpool quiet partner II stops running or won't complete it's was cycle, sometimes is will wash for a few minutes and stop or it will stop before the water even starts to flow.
I had the same problem with my dishwasher. After hearing that the motherboard was the problem I decided to take a closer look. There were two capacitors (1000 microfarads, 6.3 volts) that looked a little suspect. The tops of capacitors should be flat...these looked like soda cans that had been left in the freezer. Got on eBay, located the capacitors for roughly $3 and $4 shipping, for approx total of $10. Soldered the two new capacitors into the motherboard and put it back together. As soon as I closed the door, the dishwasher started draining the water. When I ran a Normal cycle it completed successfully. Saved myself over $120!
Aug 02, 2013 | Whirlpool Gold Dishwasher with Quiet...
My Whirlpool Quiet Partner II will not drain at the end of the final cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirlpool Gold Quiet Partner III dishwasher. When I unload the "clean" dishes, there is some type of film or crud on the dishes. I have to hand wash them to get this off. It seems like a...
You need to check the drain system completely, look for plugged screens, pump impellers, valves and the drain hose. You need to witness a large volume of water flow during drain.
Sep 19, 2010 | Whirlpool Dishwashers
I have a whirlpool Quiet partner II. It will not fill w/water.
ck the float in bottom of tank . it may be stuck n the up pos .. moce it up and down and listen for click of the sw .. very common . also the water valve may have failed and it will need replaceing . mm
Dec 07, 2009 | Washing Machines
Seem like its not draining. soapy water when finished cycle.
found a kink in the drain hose, shortened hose-problem solved.
Mar 22, 2009 | Dishwashers
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
137 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
