How to remove black mould from rubber door seal
    President:
  • 1,273 Answers
Hello Warren, W/D here.
With the washer door open, feel around the inside of the bellows seal, where it abuts the tub. You'll probably feel grit and debris, possibly some pet hair, too. Wipe all the way around with a paper towel, and get as much as you can. Next, mix up a 50-50 bleach/water solution, with just a small amount of dish washing detergent in it and wash the bellows seal liberally, topside and underside. Pour the remainder into the washer's tub, followed by two cups of bleach. Fill the dispensing cups (detergent/bleach/softener cups with bleach, and run the longest, hottest cycle available with the hottest rinse cycle available (for our machine, it is the "sanitary" cycle).
Follow this with a regular cycle to flush out any bleach residue.
One more thing: between wash days, leave the door open. This cuts down on the moisture in the machine, and reduces the ability of the washer to breed mold and germs.
You may have to do this from time to time, but this method will stretch the cleanings way out.
Best regards, --W/D--
Posted on Mar 19, 2011
  • 1,531 Answers
The best thing to do is replace the rubber boot.
Black mould in rubber door seal beko washing machine how to remove?
Hi, the best way is to try and get a damp cloth and i use the end of a wooden spoon with the cloth to remove as much as i can. Then if and when you finish doing that i obtained from the supermarket a washing machine cleaner called Dr Beckmann deep clean .
Mar 18, 2016 | Beko Washing Machines
How do i clean Bosch WAE20261AU front loader washing machine
The lint will be in a removable filter and as for cleaning the rubber seal the black grime will most likely be mould. Try a good mould remover.
Apr 27, 2013 | Washing Machines
The grey rubber door seal in our Electrolux EW1080 F has lots of black mould trapped inside it. Is there any way to remove the entire seal to clean it or do you just have to try your best to wipe around...
Don't use eucalyptus oil, because it will damage the rubber, and the smell will linger.
The black mould should be wiped off using a damp soft cloth and mild detergent. Diluted bleach (1 part in 10 parts cold water) can also be used, with care (wear gloves); don't use full-strength bleach, because it can damage rubber and corrode metal. Leave the door and detergent drawer open between washes and overnight to keep air circulating through the machine. This will slow down the regrowth of mould. For further improvement, wipe the seal dry after each use of the machine. If your laundry room remains steamy or damp for hours after washing, improve the ventilation
Jan 31, 2018 | Washing Machines
Black mould
this is the fatal flaw of front load washers, see this complaint over and over, use bleach to clean it or Tilex mold and mildew remover, make sure the hole that drains the seal is clean.
May 13, 2010 | Zanussi ZWF1440 Front Load Washer
Mould/gunk on the rubber seal of a Maytag MAF1300 AAW - help!
Once mold is present the only way to get rid of it is with peroxide. Any residue left will grow again.
May 13, 2010 | Washing Machines
How do you clean the mould build up off the flexible door seal of a front loading machine. Can I take out the door seal safely to do it. Westinghouse front loading washing machine model LF711C
Bleach:Water solution 1:2 should kill the mould effectively.
What they should have told you when you bought this machine and what it almost certainly says in the owners manual is that front-loading washing machines, all brands, are prone to this problem. You must wipe the rubber gasket/door seal off when done using. Every time.
Dumb, I know, but necessary.
Sep 08, 2009 | Washing Machines
Milldew in washine machine.
You can't remove it ,you would have to replace door seal,the cause is becoming very common,people are washing at lower temperatures,the mould is fungus,its alive higher temperatures kills it.Close Ire.
Nov 30, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Mildew
I have found nappy soaker on a damp rag effective in removing mould from fridge seals. It might also work on you washer.
Mark
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
141 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
