Question about Sanyo CLT1554 15 in. EDTV-Ready LCD Television
My TV will turn on & there is sound but the picture only shows static. What parts do I need to replace? Is it expensive? Thanks.
  • 902 Answers
For the price of the parts to replace (the main pc board in there) you can buy a new one for cheaper. walmart and a 19in for 120 dollars hope this helps
Posted on Mar 19, 2011
Just yesterday i noticed a thin black line running from top to bottom of my screen. What could be the solution to this
Rather than alarm you... I am going to comfort you with an entertaining VIDEO... If you take the brief moment to watch it. you will find the possibility of a "pack re-seat" solution...
(cleaning contact by removing & replacing the same pack) .
((in an industrial application should get you fired/demoted))
The contact surfaces should be properly treated "cleaned".
Or a fairly inconsequential pack replacement...
Watching this "TAMPATEC" can lead you to believe it is safe & easy to go INSIDE your set... Not correct.
First... you can get zapped (always dangerous) and second...
a mere (tiny) static spark can DESTROY all the collateral equipment your are NOT trying to fix... BIG EXPENSIVE parts... rending your ENTIRE unit a useless pile of waste.
I adore watching this guy...
particularly liked the part where he ADMITS he damaged ANOTHER BOARD with ESD (Electro-Static discharge)
Professionals do remove power (whenever possible.
and do know how to wear ESD Wrist-Straps (anti-static) circuit pack handling!!
Watch the video... go to shopjimmy.com and find out how much ($$) and IF you pack is available.
Take lots of pictures & put everything exactly back as you found it. The only guarantee I will provide: If you go in carelessly YOU WILL further damage your equipment.
Good luck & happy hunting
TV Parts Universal TV Stands DLP Chips ShopJimmy
Video Search
Feb 13, 2016 | Sony KLV-32EX330 Series BRAVIA Direct...
What is the likely problem, and is it likely to be expensive?
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 05, 2015 | Syntax Olevia 532H 32 in. LCD HDTV
Static & no picture from UHF input / Component Video fine
there is sinal interferences from laser products pc mobile transmitters or video games get high quality vcr and cable tv cables move or switch off any video games cd players energy saving lamps or pc and microwaves n motors like pumps change the position of installation of cable and antenna to avoid path of interference
Jul 18, 2013 | Sony KV-36XBR450 36" TV
The actual tv will no show a screen, but you can
if theres power its more likely your picture tube went out or blowed & will have to be replaced or repair. If there is there sound other than the power like static or normal sound. then it's definely the picture tube but if theres nothing but juice & its a newer model tv its a problem with the fan or lamp
Oct 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Model # F32649- TV has static, no picture no
RESOLDER LOOSE CONNECTION IN THE TUNER OR YOU NEED TO REPLACE THE TUNER
Aug 23, 2009 | Televison & Video
Just starte last day - turn on TV, (Sears model)
Bad solder on the mother board, chinese were sleeping, or bad tuner or processor chip due to temperature, Sorry pro help needed...
please rate!
Jul 10, 2009 | Televison & Video
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
My tv has picture, but no sound (lots of hash sound)
should replace capacitor ( c 1010 marked on board if it is a M134C chasie also (c 1013) both capastors are 10 mfd at 16 volts. Also check (Q603) rca part number 266897 could be bad.
Jan 27, 2009 | RCA 32V420T 32" TV
PLTV-32 GOOD PICTURE, Static Sound
If it is under warranty, you would be better off the return it for an exchange as the main board will need to be replaced. this board is not cheap. Good Luck
Mar 21, 2007 | Protron PLTV-32 Television
Sanyo CLT1554 15 in. EDTV-Ready LCD Television Logo
79 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
