Question about Splendide 2100 Vented Washer-Dryer
Code F-10 on model ARWXF129W. What does it mean?
What does code F-10 means?
F10 is a pressure switch fault which could just be the pressure chamber is blocked and needs cleaning out
use this link for error code Domestic Appliance Help
Oct 03, 2016 | Indesit Washing Machines
How to put into test mode arwxf129w
if you put dial on start should fill then turn to spin then to rinse then to drain
Jun 10, 2014 | Splendide ARWXF129W - Washer 24" Whit...
How to fix error code f 05 on splendide arwxf129w (na)
F05: Blocked Pump or Pressure Switch stuck on Empty Found
Overhaul CNF (pump connector)
Overhaul Pump Connector
Control Pump Filter
Control Pump Windings
Change Pump
Replace Card
Dado
Jun 07, 2014 | Ariston Technologies Washing Machines
H20 fault code splendide washer
Hello!
Seems that a fill valve is broken.
Usually in such cases, a valve replacement is required.
Nov 19, 2013 | Splendide ARWXF129W - Washer 24" Whit...
Set won't turn on, 10 red flashing lights
This is an error code and depending on brand/model number can have a number of meanings---
You can GOOGLE the model number with "error codes" etc to get an idea of what likely your error code means.
Mar 19, 2012 | Televison & Video
Splendide 2100 Vented Washer-Dryer Logo
98 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
