Going wireless - Computers & Internet
  • 32,281 Answers
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Posted on Mar 19, 2011
I deleted my wireless program off my computer
you have 2 options (assuming you have xp)
1. you can use the wireless zero configuration (windows wireless configuration) and go into network adapters, go into the properties of the wireless adapter, go into wireless network tab and select the checkbox that says; "use windows to configure my wireless network settings".
or
2. go into your laptop manufacturing website, go into support, look into drivers section and dowload the sofware for your wireless adapter according to the operating system you have. post back with your computer brand and model and I'll help you find it!
Apr 25, 2010 | Computers & Internet
D-link DIR-625 wireless router is setup and wired to laptop
First of all make sure the Wireless switch in your Laptop is turned on.
Now Disconnect the cable from the Laptop to the Wireless router
Now go to your Wireless Network connection and search for the available network. Select the appropriate network and connect.
Thanks
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Tip
Configure Wireless Zero Configuration to configure wireless connection on XP...
Configure Wireless Zero Configuration to connect to wireless network on your wireless XP computer.
Below mentioned steps will help enable Wireless Zero Configuration on your XP computer and achieve wireless connectivity. These steps applies to your XP wireless computer (Desktops and laptops) with external or built in wireless cards.
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight the SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button. You should have successfully established a wireless network connection.
The above steps will help you in the configuration of wireless connectivity if you are not aware about the settings of wireless connection utility installed on the computer.
on Mar 18, 2010 | Computers & Internet
Tip
Enable WZC (Wireless Zero Configuration) and connect to wireless network on...
Windows XP has built in wireless utility which can be used to connect to the wireless network. Though, you can still use the wireless utility software that came with the wireless adapter. Please perform the following steps on your XP wireless computer to enable WZC (Wireless Zero Configuration):
4. Change the Start Up Type to Automatic and click on Apply.
8. Go to the 'Wireless Networks' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
7. Highlight thee SSID from the list that you want to connect to.
9. You should have successfully established a wireless network connection.
These steps will help enable wireless zero configuration on your XP wireless computer and you can connect to your wireless network using it.
on Feb 13, 2010 | Microsoft Windows XP Professional SP2
What is the security key
You can get the key by going into the setup of the wireless router. That's where you setup a key, or passphrase, and security options for anyone else connecting to your wireless network. Sometimes your router might have a default key on a sticker or in the manual.
Generally you access your wireless routers through the PC that is wired to your router and for setting it up.
You need to first find out how to login to your router's setup. Often it can be using your browser going to 192.168.1.1, but it varies router to router.
From there you can get your key information to be used on the other wireless computers so they can access the wireless network.
Once you have the key, you then go to each wireless computer and go to your Control Panel, then click Network Connections, then look for any wireless connection. If your wireless router is working, your other wireless computers should see the wireless network, then click to connect.
Apr 11, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How do i connect to my livebox c240 using a netgear wpn311
following steps can fix your issue(only for XP)
ENABLE WZC
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Mar 14, 2010 | NetGear WPN311 108 Mbps 802.11g RangeMax...
Router will not go wireless. all lights come on
The "wireless" (second) light on this model does not indicate that the router's wireless features are active, it indicates that a computer is connected to the router wirelessly. If the "router" (fourth) light shows three little "radio wave" symbols, the router's wireless capability is on.
Nov 18, 2009 | Belkin (F5D8231-4) Wireless Router...
Acer aspire 5542 laptop won't connect wirelessly
GO TO START>NETWORK CONNECTION
CHECK WIRELESS IS THERE OR NOT
if not there
go to Start>Run type "services.msc"
start windows zero configuration
right click WIRELESS
properties
select wireless tab
put one tick mark in the use windows to configure.......................
ok
agin right click on wireless
view wireless network
search on wireless(leftside)
select connect
Nov 01, 2009 | Acer Computers & Internet
Cant connect wireless on acer 3680 internet provider says its the computer my acer laptop not picking up wireless internet
you may try:
1) check a wireless switch is on, and wireless light is on on your laptop, if not on go next
2) go bios check wireless setting is enable. if 2 not fixed go next
3) go windows check wireless driver that easy to see at right down bar show a icon of wireless. and then check control panel system and go hardwire management network adapter, you can find the wireless card status. if all above normall
4) recommend reinstall your windows.
Dec 26, 2008 | Computers & Internet
Laptop
go to my computer right clik it then select properties.
then go to device manager go to network adapters.
in there u see device or devices right clik on them and enable all one bye one .
thats it
Sep 29, 2008 | Dell Latitude C610 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
