Question about GE Refrigerators
I have a GE side-by-side refrigerator that is not defrosting. I have checked the evaporator and it is iced up. I need to know how to put it on defrost manually, if I can, to check what component is deffective in the defrost system. PLEASE, PLEASE, I DO NOT NEED A GENERIC ANSWER SINCE THIS UNIT HAS A CONTROL BOARD AND HAS NO SCHEMATIC. Thank you very much. I dont mind paying if I get the answer for the right product
    Guru:
  • 683 Answers
Have you tried cleaning the condensor coils. Also check the drain line going to the bottom and make sure its open. if the condensate cant drain it will just refreeze. let me know.
Posted on Mar 19, 2011
My GE model GSH25KGMB BB side by side refrigerator is not cooling on fresh food side. Freezer and ice maker side working fine. How should I troubleshoot this?
On your model I would go straight to the defrost heater and defrost thermostat and check them first after defrosting the evaporator first with a hair drier. Both parts need to be replaced=> WR51X10055 Defrost Heater Assembly 25953576-emtx2i4tcmlh0qfjbwwrn2z1-2-0.jpg and the=> WR50X10068 Defrost Thermostat APPLIANCE 911
Nov 11, 2015 | GE Refrigerators
My GE side-by-side is not cooling.
The electronic control board is probably your culprit. These control boards control the compressor, fans and defrost. Look for any burned spots on the printed circuit bout it could be just bad.
May 11, 2014 | GE GSS25SGPSS Side by Side Refrigerator
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
Warm refrigerator. Iced over freezer back panel. Read that I could test defrost timer myself but don't know where it is located. Also, is this something I can replace myself if it is broken?
first of all there isn't a defrost timer in this model,its an adaptive defrost system controlled by the motherboard in the lower rear of the unit,first check the heater on the lower side of the evaporator coil,then if this reads continuity,secondly,check the defrost thermostat located near the top of the evaporator coil for 0 ohms like a switch(needs to be checked under 32 degrees or it will show open/bad)
Jan 26, 2011 | GE GSH22JFT Side by Side Refrigerator
Fridge and freezer running too warm
You will need to unplug the refrigerator and remove the back panel inside the freezer. Check for ice or a frozen over evaporator coil. If frozen defrost and we will need to examine the defrost heater at the bottom of the evaporator. It may have a glass tube covering the heater element inside. I want you to check to see if it is burned out. The part number for the defrost heater is WR51X10042
You please let me know what you find. If the element is burned out I recommend you replace it and the defrost thermostat part number WR50X10068
You and order the parts by clicking the link below and entering the part number into the part number search feature and click FIND IT. Let me know what you find, Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Here is a photo of the defrost heater.
WR55X10656 Mother Control Board
It is possible that there problems with you mother control board. Need to unplug and examine both sides for burn marks.
If you need help feel free to let me know, Thanks Sea Breeze
appliancepartsse@yahoo.com
Jul 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water and ice in bottom of freezer, occasional water on floor
I believe your defrost condensate pan below the evaporator is blocked with ice and now when defrost happens the water pours over the tray and to the bottom of the freezer. You will need to defrost the ice in the collector tray and the pour a solution of hot water and clorox to make sure the water ends up in the condensate pan below your refrigerator. So unplug the refrigerator remove the panel and let me know what you find. I have some more solutions depending on what you see is happening. Thanks, Sea Breeze
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrig not cold enough, ice buildup on banck panel of freezer
ice build up means your refrigerator is not going through defrost cycle. you have ice build up on evaporator which restricts your cold air flow into the fresh food side. check defrost timer, defrost thermostat located on evaporator behind the wall where your getting frost. check defrost heater. it wraps under the evap.
Jun 21, 2009 | GE Refrigerators
GE refrigerator not cold but Freezer works fine
you need to find out if the evaporator fan in the freezer is working. or if the evaporator is all iced up. If the fan is not working you will need to replace it. If the coils are all iced up you have a defrost problem and that will ned to be resolved. Once a evaporator is all iced over air can not pass through it and you will loose your cooling in the refrigerator first. Check the heater and the terminator to make sure they are good. You can use a hair dryer to clear the ice off the evaporator. Once you find the bad part replace it and the unit will function normally
Jul 23, 2007 | GE J Series 18.2 cu. ft. Top Freezer...
GE refrigerator
this may be water from the defrost cycle. if this drains to tray over compressor, check tray is not too full (water evaporates from heat of compressor) otherwise defrost water will go to a seperate container which may have a split or is overflowing. fault can also be caused by poor door seals which would produce too much ice on evaporator pipes
Mar 21, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
