Question about Tag Heuer TH 5016 Sunglasses
Screw that held right arm broke when I tried to put on the glasses, model TH5016 812. Based on comments on the Internet, this seems to be a weak spot of this particular model. Any suggestions? Does Tag Heuer repair? P Schaeffer
  • 8,197 Answers
To get repair service for TAg Heuer you need to contact them at 1.866.260.0460 to get the shipping address.
Posted on Mar 19, 2011
Testimonial: "Thanks for the concrete advice."
Rear wiper rotates around
the wiper arm is held against the glass by a spring-corrosion in the arm doesn't allow the spring to pull it against the glass-in order to position it properly take the arm off,run the wiper while watching it-you need 2 people for this job-noting where it starts from and where it ends at. put the wiper where it looks close to where it should be and try it you may have to reposition it a few times. as far as the wiper arm being corroded-I would replace it. the reason its going down right now is because its in the wrong position from the carwash-these things can be nasty to get off-you can get a tool at the auto parts stores-ie autozone ,advanced auto or pepboys-cheers Denny
Nov 03, 2013 | 2004 Chevrolet Blazer
Broken glass in kitchenaid kuds301xwh dishwasher
CALL Chas&Son,s at 570-379-0993 and they will come out the same day no less okay
Feb 12, 2013 | KitchenAid 24 in. KUDI01ILBS Stainless...
A glass broke and pieces of glass fell inside of the washer strainer module. How do you remove this screw that sits on top so that the glass inside can be vacuumed out. The screw moves but does not...
Hello, Welcome to FixYa.
Based on your description, I think this should help and be just what you need to get to that piece of glass and remove the spray arm so you do not have to call a technician...and maybe more.
You`ll need to follow these steps to access and clean it. (The key with the spray arm nut is to hold it while you spin the spray arm, not the nut...provided it is a KUDS02 series dishwasher as stated).
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress the rear tab, i.e.
b ) Then twist the feeder to the right ( clockwise ), i.e.
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out. This should allow you to remove the broken glass.
If my explanation is not clear enough, here`s a link which provides a pretty good video of how to do this, these guys aren`t pro`s but the "how to" video is pretty thorough nonetheless.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
May 20, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
I have a Ricoh Aficio 220 and after moving it to a new location, it leaves a blank strip on the right side of each page.
There is likely toner on the laser shield glass. The laser shield glass is located just below the toner hopper -- should be covered by a small plastic cover held in by 1 screw. Remove this screw, pull off the cover, and gently slide the glass strip out. Clean the glass with a dry lint-free cloth then reinsert it and put the cover back on. Your blank strip should be gone.
Feb 21, 2011 | Ricoh Aficio 220 Laser Printer
How do you get the back off of a rearview mirror to stick it back n the window
Some have a cover hiding the screw or from the bottom theres a clip that need to be pryed back and held while you slide mirror of bracket, if theres no screw on the mirror to loosen then theres a clip arm holding it, also make sure to glue the right way take note of how it goes on because once you glue to glass its not coming off.
Dec 07, 2010 | 2004 Kia Optima
My glass globe/shade is damaged. I need to buy a a replacement. As far as I can tell the ss# is 0499 and the model looks like WL 62. I am reading upside down in a tight spot. The globe fits in housing 9...
You can probably find a replacement at Home Depot or Lowe's in the lamp department. They sell these globes as universal replacements rather than being specific to a particular model of fan. The 3 set screw holding method is pretty universal for ceiling fixtures and fans of all brands. If the current shade is not shattered, put a little tape on it and take it with you to the store. good luck, Al K
Dec 07, 2010 | Encon Industries (78018) Ceiling Fan
How do i put the lower spray arm back together? I had to replace the top screw part and it seems to stand up to high. I have a small white plastic ring, a larger white split ring and the arm itself. I...
Spray arm first, then the split white ring on top and the top screw. There will be around 1 1/8" gap (the spray arm wobbles when it's not running). You're doing it correctly.
Oct 29, 2017 | KitchenAid 24 in. KUDS25SH Built-in...
Need plastic handle on Rival Crockpot lid.
For what it's worth, when the handle on my mother-in-law's crockpot broke, I went to Home Depot and bought a cheap wooden drawer knob (about $1 as I recall). I put a plastic washer between the knob and the glass and another under the screw head from the bottom (to prevent cracking the lid), tightened the screw and good as new.
Feb 20, 2009 | Rival 38601 Smart Pot 6-Quart
Plastic arm of water dispenser broken off - need help trying to remove plate to access screws for replacement
Try looking under bottom edge of control pad that says monogram on it. You should see 2 or 3 holes. Push in with a blunt object in either end hole while pulling panel forward. Then dot the center if has one, then the end one. MAKE SURE YOU HAVE POWER OFF!! Now you can see 4 screws to access rest of dispenser.
Nov 19, 2007 | GE GSS20IEP Side by Side Refrigerator
Tag Heuer TH 5016 Sunglasses Logo
315 people viewed this question
Top Tag Heuer Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a Tag Heuer Clothing Accessory Expert? Answer questions, earn points and help others
