Question about LG LHB975 Theater System
Have LG bluray home theater system model # LHB975, the subwoofer has suddenly lost its signal and will not rematch with system. We have unpluged and repluged, done the mute/stop combo, ran sound tests till our ears hurt. Still will not pick up signal goes from blue blink to red every time. ( this just occured yesterday)
  • jmendez41282 Mar 19, 2011
    Thank you for the solution, but unfortunatly it didnt work. I rinsed and repeated multiple times but i still am not getting a signal from my subwoofer or wireless receiver. Is there anything else i can try?
    right, does that mean that it needs maintance??
  • 2,574 Answers
Try to reset the network settings ..
Select [Connection Setting] option in the [Setup] menu then press ENTER
The [Connection Setting] menu appear on the screen. Use up/down arrows to select [Wireless] and
press ENTER
Selects [Yes] and press ENTER (to continue. The new connection setting
resets the current network settings.
Reconnect the wireless receiver ..
Turn on the main unit and turn off the wireless receiver.Press and hold x (STOP) on the front of unit
and MUTE on the remote control. "REMATE" appears in display window.Turn on the Wireless Receiver
Posted on Mar 19, 2011
  • 1 more comment
  • Reparatii PC - Service IT
    If there is no audio signal for longer than 10 seconds,the wireless receiver will automatically switch to red.I think that the wireless sub-woofer is not communicating with the wireless receiver .
    I suggest you return it to the supplier for repair if you still
    have it under warranty
    Yes.
Everything working fine, then home screen no longer displays on TV. On startup, pink dots go across TV screen, then TV goes black. Signal from most recent input is not coming trhough the audio or TV.
I have the same problem. I have an LG lcd tv as well. I have my cable box connected to via hdmi into the reciever then from reciever to the tv via another hdmi cable. I can watch tv and like the problem above see the pink dots on boot-up but I can't get the home screen to display.
Jan 08, 2013 | LG LHB975 Theater System
Lg lhb975 no sound from tv
If the RCA cables are correctly connected you should have an "AUX" input on your DVD player which will allow sound from the TV to the player
Jun 01, 2012 | LG LHB975 Theater System
My two wireless speakers are not working. the wireless receiver flashes blue 10 times then turns red. It was working fine and now is not
I am having the same problem with my LGHB905TAW. Called local support without any feedback... I think this is the bug in design phase.. Search around the internet but without any positive result...
Sep 27, 2011 | LG LHB975 Theater System
My subwoofer and wireless speakers won't sync lhb975 blinks blue then turns red
http://www.avsforum.com/t/1386546/lg-lhb975-wireless-speaker-sync-repair Te solution is here
Jul 18, 2011 | LG LHB975 Theater System
Hook up everything right,but can't seem to get suround sound from TV. Went to Bestbuy and brought a Digetal Optical cable and it still dosen't seem to give mr that sound like the home theater sound---help!
On the remote press the surround mode button and set it to Prologic movies or music when you are watching TV to get the rear speakers to work.
Or if you have Digital cable TV with Dolby Digital 5.1 content, make sure you have connected theLG to your TV using HDMI v1.3a. There is an audio return channel on this cable which will stream 5.1 audio signal to the LG system.
Mar 11, 2011 | LG LHB975 Theater System
How do i get my speaker on to the speaker bracket?
On page 16 of the user guide it gives step-by-step instructions on mounting the speakers. But simply you take the mount screw side up and wings toward you and slide the speaker down.
If user guide was lost or didn't come with it you can find pdf version here: http://www.retrevo.com/support/LG-LHB975-Home-Theater-Systems-manual/id/23662ag010/t/2/
Feb 02, 2011 | LG LHB975 Theater System
This system has a wireless subwoofer that doesn't connect anymore. When the unit is plugged in, it flashes the blue LED four or five times and then goes solid red as though it's turned off. We have been...
I just called LG Electronics 1-800-243-0000 and this is the solution I got from them. Unplug the main unit from the wall, Hold the ON button for 30 seconds. Plug it back in. That should do the trick. They call this procedure a "Hard System Reset". If this doesn't work, call them back and they will repair or replace accordingly.
Jan 30, 2011 | LG LHB975 Theater System
My LG LHB975 Theather system subwoofer keeps going on n off when playing music flashing blue slowly
marvinpogno,
Sounds like you having an interference issue. Firstestablish a good connection, then diagnose why the signal is getting lost. You write that the problem occurs whenplaying music, which makes it sounds like everything is fine when playinganything but music.
First establish the connections; press and hold the stop button then press themute button on the remote. Check to make sure all units are operatingwith something other than music. Now to diagnose the issue; what you are using to play themusic most likely is causing an interference that is breaking the wirelesslink. Try something else to produce themusic from, ipod, mp3 player, etc. Don't forget about other things that could cause interference. Microwave ovens, wireless phones, wirelesscomputer router, etc. Hope this helps. Please rate the answer if I was able to help, thanks. -Chris
Jan 09, 2011 | LG LHB975 Theater System
I have a lhb975 5.1 bdhtib lg wifi with remote sub and rear speakers (blue ray surround sound system), the sub and rear speakers don't work anymore, a few days ago when this started it would come on about...
You've probably found an answer to this already but just in case...
You're most likely going to have to return the unit -- just receiver and subwoofer in my case as the sub was the only speaker not synching up.
Rather than dealing with their useless "Chat" web support, I would HIGHLY recommend calling their support # to get an RMA. Then request they EMAIL the RMA forms to you rather than snail mail. Also, make sure they have your correct name and info in their ridiculously poor customer database. They had my LHB975 serial # associated with some other person's name and address!! It literally took weeks and at least 6 calls to get it straightened out. Never again....if it dies again, it goes straight in the trash.
Dec 02, 2010 | LG LH-T754 Theater System
Digital Optical port to 8-pin din
Optical digital cables can't be magically wired to copper inputs. NO digital signal can be magically connected to an analog interface and work.
Even if you could do what you propose, how would you control volume?
Why don't you just connect the BluRay to the JVC system and let IT handle the audio to the sub and satellites?
Run an optical cable to the JVC TH-C60's Optical In port. Make sure there are no tight bends in the optical cable as that will degrade its ability to transmit a signal.
Jan 30, 2010 | Audio Players & Recorders
LG LHB975 Theater System Logo
1,305 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
