Question about Samsung HLT6176S Television
I have a Samsung DLP HLT6176SX/XAA model and the 1st and third light are blinking and the tv turns off by itself. I tryt to turn it on and then after seconds, it turns off again. I think this may be related to a fan not cooling correctly? Is this the problem, what can I do to fix this, do i need to replace the fan, can you help with part and directions on fixing this? Thanks
  • 41 Answers
SOURCE: Cooling fan motor is making loud humming noise
You will have to pull out the light engine. That will consist of 4 or more screws and disconnecting some plugs. The the whole unit slides out where you can get to the fan housing.
Unless you're mechanically inclined, you should not try it as you could damage the assembly.
I don't know the part number off hand and some of those have newer part numbers as replacement for the original. Just do a google search to come up with a part number.
Posted on May 18, 2009
circuitworld
  • 335 Answers
SOURCE: how can i fix my samsung tv model:HLS505WX/XAA is
In order to fix this problem the back cover has to be removed and some voltage test on the power supply and interface board need to be tested. You need a multimeter to make these basic tests, you can get one from radio shack. With this meter we can see which circuit board is at fault here. Once we locate which board is causing this problem you can either have it fixed from a repair shop or replace it with a new one.
SAFETY FIRST:
its best to get someone who technically proficient to do these test.
If you decide to do these tests yourself keep in mind the high AC voltages you will be exposed too. These AC voltages are dangerous and very harmful if failure to respect certain testing disciplines. Remember this is a TV.
Let me know if you want follow up on this.......
Posted on Dec 07, 2009
  • 37 Answers
SOURCE: We have a Samsung DLP model HLP5067 WX/XAA. It
NEEDS A COLOR WHEEL ABOUT 150.00 DOLLARS
Posted on Feb 09, 2010
jotvguy
  • 146 Answers
SOURCE: Samsung HLT5076SX XAA turned itself off. Two
If you do not hear the color wheel start to spin inside of light engine this may have failed also check to make sure fans are working and safety switch is making contact
Posted on Mar 05, 2010
SOURCE: blinking lights on HLT5075SX/XAA samsung
Manual says you need to replace the lamp: When do I need to replace it?
• It should be replaced when the screen becomes darker, less clear or when all three LEDs on the front (STAND BY/TEMP, LAMP, and
TIMER) are flashing
imgadgetman
Posted on Apr 22, 2010
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Model Number HLT5676SX/XAA 56" Samsung
your question does not help us or you as we do not know your problem .
Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
I replaced the lamp on my Samsung HLS5086WX/XAA DLP set. How do I reset the timer on the lamp?
I have a Samsung DLP HLN617WX/XAA. After turning off by itself, the three indicator lights were blinking... signifying a defective lamp. I've re-seated the old lamp several times with no change. I bought a new lamp and reset the lamp hours through the "service menu" with no change. My television is still turning itself off and still blinking the same indicator lights. What should I look at, next?
Oct 26, 2010 | Samsung Televison & Video
Samsung Dlp completely shuts off and then all three lights flash
Sounds more like the TV is overheating. The lamp cooling fan may be seized or not spinning fast enough. If the TV gets hot enough to trip the thermal, it could rupture the lamp.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP - Model HLR4667WAX/XAA
A stuck color wheel can cause this exact problem.
Feb 26, 2008 | Televison & Video
Televison & Video Logo
280 people viewed this question
Jerry Greenberg
Jerry Greenberg
