Question about Maytag Dryers
Buzzer won't go off when dryer is stopped - All else works fine - must leave door open
  1. The buzzer won’t go off. When dryer is stopped you must leave the door open or the buzzer will sound. All else seems to function fine.
Fiddled around with the start button. It had gotten stuck in the on position and when I moved it around it freed up. I consider this a temporary fix only and have already ordered a replacement switch.
Posted on Aug 03, 2008
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
The dryer buzzer keeps going off even when dryer is off
When the dryer stops can you advance the timer a little to turn off buzzer? Or when you open the door does the buzzer stop? I was trying to find a schematic for that model but I have had no luck. Power should come from the timer to the buzzer. If you know how to read a schematic. Unplug the unit and remove the back to the control panel. Check to make sure that all the wires to the timer are on the right connections. You may need an appliance repair service from your area to come out and diagnose it for you.
Apr 02, 2013 | Frigidaire Westinghouse Electrolux...
Dryer won't turn off
Relay stuck closed in control circuit, usually the door interlock. Slam the door shut a couple of times to see if it frees the contacts.
May 15, 2012 | Washing Machines
Buzzer won't shut off. only when door is left open
could be a number of things, but you may want to test with an ohmmeter if you have one.
It sounds like your timer needs to be replaced. If the buzzer is not shutting off, the timer may not be turning to the off position. It may be really slow our out of wack, not letting the dryer completely dry. It also could be an error with the dryer's control module (kind of like a computer for the dryer)
I also recommend playing around with door switch, it to may be faulty. If the dryer does work with door closed, it is unlikely to be the door switch. You will have to test timer and door switch with ohmmeter or voltmeter to determine that the voltage current is constant and not speratic or shorting out.
May 18, 2009 | Kenmore Dryers
Done buzzer sounds
The cheapest solution is to continue leaving the door open. The timer is bad and hanging up at that particular point. They are typically 80 to 150 dollars to replace.
Mar 13, 2009 | Dryers
Buzzer wont quit
have you tried to turn the knob slightly at end of cycle to see if it would shut off? try that if it does shut off then replace your timer
Jan 06, 2009 | Kenmore 73952 Gas Dryer
Kenmoore 70 series Buzzer will not stop
buzzer is built -in the timer you all should replace it if you really want it solved they have done their work over the years. It's not something you can just go in and unplug or cut sorry. Good Luck. Post your make and model numbers next time please.
Dec 19, 2008 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
640 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
