Question about Briggs & Stratton Measuring Tools & Sensors
POULAN RIDING MOWER WITH BRIGGS AND STRATTON ENGINE. RUNS FOR ABOUT 30 MINUTES THEN DIES. WILL CRANK AGAIN AND RUN FOR ABOUT 20 MINUTES
  • 10865 Answers
SOURCE: Engine dies when hot
Your carbeurator needs to be rebuilt.
Posted on Jul 05, 2009
  • 115 Answers
SOURCE: mower starts but when you take your foot off the clutch it stops
sound like the seat saftey switch under seat you can either unplug it and see if that works or jumper the wires with a piece of wire if either works replace switch
Posted on Jul 08, 2009
  • 634 Answers
SOURCE: Having problem starting and keeping engine
some have fuel filter some do not , but it sounds like you have contaminated fuel and is is clogging up fuel line or carburetor,look into gas tank with a flash light and see if there are specs floating at bottom of the tank, if there are drain tank of all gas and remove tank and flush it out with brake cleaner, then disconnect both ends of fuel line and spray through tube into white paper towel until u see no dirt/debris. then remove air filter clean foam( soapy water, dry re-oil 10w30 is ok). remove carb from engine spray through main port with carb cleaner not brake cleaner, and use tube and spray through inlet tube while holding throttle wide open reassemble and it should run fine, if not u may need to disassemble carb if not comfortable with this then order new one usually under $100
Posted on Jul 09, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 7 Answers
SOURCE: Can a novice replace a carburetor on a Briggs
Yes its pretty easy you can do it.Are you sure the carb is bad most of them just need a good cleaning .I would disassemble be careful there are some little parts in there and if you are careful and pay attention as you disassemble it you can just clean it .Go to auto parts store get a can of spray carb cleaner .remove bowl be careful the is a float in there a little square or round bellows .Slide the pin out and then the fuel loat pin underneate the float now take out any adjustment screws you can find and spray cleaner in every hole you can find several times and reassemble if idle or fuel mixture screws were removed a standard setting of 1 1/2 turns out from seated position is the norm and some adjustment may be needed once running either in or out till runs smooth.
Posted on Nov 11, 2009
Oil is fine, runs fine for about 10 minutes then bogs down and dies. Let it sit for 10 minutes it will start again and run fine for another 10 minutes. Used to be 20 minutes, then 15. The cooler the...
It could easily be an electrical issue, or not. Get a spark tester (hooks up to the spark plug). Pep boys, Autozone, and Napa all sell them for less than $10. Check for spark when the mower has quit. If no spark, most likely need to replace the ignition module. Also check the flywheel key, if it is has been sheared or even knicked, the engine will run hot.
If you still have spark when engine has failed, check the vent on the gas cap. A clogged vent will cause a vacuum to form in the tank and stall the engine.
Aug 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
New Craftsman 20hp Briggs & Stratton 42" riding mower, Model 917.289104. Loses power, dies while mowing. Will not start unless sits 20-30 minutes. Problem began second time I owed with it. ...
first make sure the air intake screen on top of engine is not clogged with debris if thats not a concern you could have a faulty ignition coil etc your engine should have a two year warranty and can be serviced at no charge to you at your local briggs service dealer make sure and check your manual for the fine print though. Briggs makes a great engine and very rarely have I ever seen a problem allthough if you were to have an engine issue it will accur during the first few hours of opperation good luck
Jan 23, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Poulan Riding Mower will run in neutral, not in forward or revers
you have safty switch on the mower one or more are bad there are three of them
win you put in reverse some mower will cut off this is a safty device on some mower
Jul 18, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
2005 Poulan PD17542LT Lawn tractor, It starts fine but after cutting my front yard (20-30min) it dies, it will start up but dies in a few sec. If I let it set and cool off I can get 20=30 min till it gose...
Normal maintenance been applied to this rider ? Filters, lube, cleanings ? This sounds like an electrical issue (component hot), or a vacuum in the fuel tank. Next time it 'stops' open the fuel tank up and listen to any air 'whooshing' in.
Jun 22, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
SAbre ridingb mower. Runs, backfires,almot die, still run. Backfire again,then dies and can not restart. PLEASE HELLP!!!!! PHIL Mpwer M#1438 Engime B&S M#287707 14.5hp, OHV
Sabre riding mower. Runs, back fires, almost dies,still runs. Back fires again, then dies and can not restart Please HELP!!!!!! Mower model #1438 14.5/38. Engine Briggs and Stratton, Model #287707, 14.5hp, OHV.
Jun 06, 2009 | 2003 Ford E150
Mower will not drive
Usually, that's an indication the the seat switch is not working. It's like getting off the seat without locking down the parking brake or getting off the seat with the baldes engaged, same result...engine dies.
Jun 02, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan Pro model 185H42ST dies after 30-45 minutes mowing
Put a carb kit in it. If that does not work replace the gas cap they are supposed to breath and if they get clogged it will create a vacuum in the tank starving the engine for fuel.
Apr 24, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
When mower gets hot it cuts off crank back up run a min cut off
1 of 2 things happening
first change the fuel filter seams that the gas is vapourizing
If that does not fix it replace the engine coil as it heats up it is breaking down in voltage causing the engine to die
Apr 05, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Measuring Tools & Sensors Logo
16 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
