Question about Toshiba Satellite A65-S126 Notebook
I need to replace rtc battery in my Satellite A65-s1070 but i can not find the rtc battery. Could you help me please?
  • Toshiba Master
  • 32,281 Answers
On this model Toshiba the BIOS battery may be under the keyboard.
Posted on Mar 19, 2011
How do i do a total pc restore on a toshiba Satellite A65 s1070. please help...
Hi! Welcome to www.fixya.com.
1. Copy all your files and documents to an external storage device. 2. Shut down the computer. 3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears. 4. Click "Repair Your Computer" if you are not already on it and then press ENTER 5. choose your country and click OK 6. On the "System Recovery Options Screen" click "Restore Application" which is the last option. 7. Follow the on-screen instructions 8. When prompted, click on "Full Factory Recovery" 9. "Next" 10. Click "Yes" 11. you will notice for a while it seems like nothing is happening, give it some time. 12. After some minutes, recovery will complete and you click "Finish"
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 25, 2011 | Toshiba Satellite A65-S1070 Notebook
Replace rtc battery
Unless you are a seasoned PC Laptop tech, I don't recommend you try this repair, however here are the instructions for you. The manual for this laptop is located on your hard drive in a PDF format. If you cannot locate it, you can download a copy from the Toshiba web site. You will need to order a new battery from Toshiba or another vendor.
Here are some step by step illustrated guides for you to disassemble the A65-S126
http://www.irisvista.com/tech/laptops/ToshibaA65/satA65_1.htm
1. Remove the battery (side latch release) and hard drive. The only screw that holds it down is marked F-4 on the cover. (look for the panel with the 2" circle, that is the HD)
Use the white pull tab to move it left then upwards. It should move with little effort. Be careful not to loose the screw from the HD panel.
2.Remove all screws annotated F6 from the bottom bezel with a Pt. 2 screwdriver. (from my count there was less that a 15 )
Depending on the screwdriver, there are times where you might have to push the screwdriver down a bit to get in contact with the thread. Just be careful not to strip the threading.
3.Remove the "B25" screw located near the heat sink-fan vent. Somewhat carefully take your hand, and lift the bottom bezel up enought to disconnect (about 1-2 inches from surface) the battery with your index and midde finger. Look at they way the battery is run, and seated in the plasic clips.
With the bottom semi-open, plug in the replacement battery, and re-seat it in underneath the white ribbon cable, and clips on the housing per the original.
4. Replace all screws
5. Re-seat the hard drive, by sliding it in first with the metal tab under the plastic housing, to the left, then puling it to the right. Replace the panel with the one, shorter, F-4 screw. Reseat the battery.
If you wish to test the battery, simply unplug it and remove the battery for 30 minutes. Then power it on with only the A/C adapter. If no CMOS screen appears, you are good to go.
Please feel free to give a shout out if anyone finds this helpful.
Hope this helps FixYa! Please leave me some feedback and supply a testimonial if you find this helpful.
Apr 06, 2010 | Toshiba Satellite A65-S126 Notebook
I've got some purple and yellow vertical lines laptop screen
Yes it is the LCD itself unfortunately... this is a common thing I have seen it many times, it is like a cancer and spreads all over eventually getting worse and worse.
Feb 20, 2010 | Toshiba Satellite A65-S1070 Notebook
Where is the CMOS battery located in a A65-5126 Toshiba
Cmos or (RTC) battery is located on the main board and can be accessed by taking the palm rest off the lower case.
Sep 06, 2009 | Toshiba Satellite A65-S126 Notebook
Excessive heatup
Most likely you will need to replace your battery. Adapter seems to work fine since it can charge battery up to 12%, but the battery itself cannot charge more than 12%.
Battery replacement is inevitable.
Jan 16, 2009 | Toshiba Satellite A65-S1070 Notebook
CMOS or RTC battery for this laptop : can it be replaced
Hi AshishB, Yes, Toshiba does refer to the CMOS battery in their literature as the real time clock battery. Your retailer is half right, the battery is on the motherboard but its attached via a connector and it can be replaced. Here are links to a couple of venders that sell the RTC battery for your laptop: - Http://www.sparepartswarehouse.com/Toshiba,Satellite,L15-S104,Laptop,Batteries-Backup-RTC.aspx - http://cgi.ebay.com/Toshiba-Laptop-motherboard-battery-cmos-L15-S104_W0QQitemZ170060189842QQihZ007QQcategoryZ3666QQrdZ1QQssPageNameZWD1VQQcmdZViewItem Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 18, 2007 | Toshiba Satellite L15-S104 Notebook
Toshiba Satellite A65-S126 Notebook Logo
203 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
