Question about Canon MP-25DV Calculator
How do you make the gears go in the direction so a new ribbon can move to the right?
  • 47 Answers
There is a lever between the two spools that will flip to one side or the other and change direction of ribbon spools.
Posted on Mar 19, 2011
Can a damaged electronic ribbon in my hp office jet all in one printer cause a loud crackling sound when the printer head was cleaned and reinserted to the printer?
Yes It could if it kept the print heads from moving freely. You are probably hearing plastic gears or the toothed drive belt grinding. Re-alignment is tricky - your alternative is dumping the printer. With printer unplugged, try to move the print head and take careful note of the belt and gears. Move head as far as it will go. Then remove the belt and move the head the rest of the way in that direction. Then reinstall the belt and test. You may have to do this a couple times to get it right, but I have been able to on ink jets (And have also failed)
Mar 02, 2018 | HP Office Equipment & Supplies
Calculator does not print since new ribbon was installed
Take the paper roll and ribbon out and see if those gears move. If they do, then you have the ribbon badly placed. They are also notorious for the ribbon itself not being flat and sitting correctly.
Jun 18, 2016 | Sharp EL-1197PII Calculator
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
The ribbon will not index forward on my 345 DLE. It appears that the shaft that inserts into the cassett does not turn to move the ribbon.
if the knob on the ribbon cartridge doesn't move the ribbon when you turn the knob the direction of the arrow (on the cartridge next to the knob) you need a new ribbon
Nov 03, 2011 | Smith Corona Wordsmith 100 Typewriter
I have a circa 1940's-50's Royal Desktop Typewriter. The ribbon that was already on it was rather worn and severely faded so I bought new ribbon for it. The only available ribbon was a red-black silk inked...
You have the ribbon on wrong. The ribbon dosen't feed off the spool but take up onto the spool. install the ribbon so that the moving spool is taking up the ribbon.
DickyO
Oct 16, 2010 | Royal MS 25 Typewriter
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
Ribbon does not move during typing and no ink gets on paper.
Hi:
It appears that the ribbon feed connector has come loose from the ribbon feed motor. On top where the ribbon sits you will see where the ribbon couples to the ribbon feed motor on the right side. Look on the bottom of the ribbon and you will see where the ribbon couples with the ribbon deck feed motor. Directly under that ribbon deck is the ribbon feed motor. It sound like the cable came loose and it just needs to be plugged back into to motor.
Good Luck
Andrew
Mar 11, 2009 | IBM Wheelwriter 30 Typewriter
Don't know how to load and string the ribbon on an ibm selectric
Selectric III has two different ribbons the selectric II ribbon tha the ribbon guides are part of the macine and the "bicycle" ribbon that has the guides bilt into the ribbon. to replace the "bicycle" ribbon move pull the red lever on the right toward you, drop the ribbon in turn the knob a few times in the direction of the arrows, move the red lever back done.
The other style move the lever, drop the ribbon in, be sure the ribbon is left of the slacker finger sticking up on the left,thread it tru the guides, turn the knob inthe direction of the arrows, move red lever back,done.
DickyO
Feb 24, 2009 | IBM Wheelwriter 30 Typewriter
Wheelwriter 30 Series 2
First off make sure the ribbon turns freely.Take off the ribbon and turn the ribbon wheel in the direction of the arrow and see if it turns smoothly. If it turns smoothly the ribbon motor is not moving or the gear is not moving. take off the ribbon and type. See if the black ribbon drive gear on the ribbon deck moves as you type. If not the motor is N.G. or the ribbon gear clutch spring is not grabbing the gear to turn it. Lawrence
Feb 14, 2008 | IBM Wheelwriter 30 Typewriter
Ribbon problem
does the ribbon feed by hand? If not get a new ribbon.
DickyO
Dec 24, 2007 | Brother ML-100 Typewriter
Canon MP-25DV Calculator Logo
265 people viewed this question
old marine
old marine
