Whirlpool TEDX640PQ Dryer Logo
A
Anonymous Posted on Mar 19, 2011
Dryer is heating but not turning making noises from control switch even in off position
Dan Webster
Level 3:
  • Whirlpool Master 8,221 Answers
  • Posted on Mar 19, 2011
Dan Webster
Whirlpool Master
Level 3:
Answers
8221
Questions
5
Helped
2379035
Points
25840
That's a plain jane timer on that dryer. The motor probably has a stripped gear in it. Seen it.
Nothing in the dryer would cause this timer to make noise UNLESS the RH terminal was arcing while in the heat mode of the timer setting. The result over time would be this:
I would say you is in need of a new timer. This timer has feature which advances the motor only when the heater is not on using this orange wire to feed back to the timer motor:
That is the middle wire on the high limit.
To replace the timer yank the knob straight off and remove the screws. Pay attention to how the wires connect. Pretty simple fix.
I have a manualdryer is heating but not turning making noises - themobilian_1963.jpgotos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
I have a Maytag PYE2300AYW electric dryer but does not heat. (I Found the Culprit)
It could be either a clogged vent or no gas flow. Other problems with your dryer not having any heat being produced might be caused by a faulty thermal fuse and or broken heating elements.Or it could also be the fact that your dryer is dying and has to be replaced.
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Dryer making noises from control switch heating up but not turning belt is ok makes noises from switch even in off position
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
1helpful
There is a clunking noise -like a tennis shoe in the dryer- when i turn it on even when empty I made a mistake on the e-mail i entered [email protected] not [email protected] please correct and...
Press the door switch with the door open and set no-heat run. Try to locate the position of the noise. If it remains in one place, that is where you need to look inside the case. If it seems to be moving all around, release the switch and try to move the drum side to side and up and down, looking for a very loose bearing. There may be a segment of the drive belt that could be missing. Check the drum interior for loose bars fastened to the inner rim.
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Unpredictable heat
hi i think you have problem with thermostat. t hermostats, the dryer temperature control switches, are controlled by the temperature inside the dryer or by the heat of the motor. One or more thermostats on the panel can be adjusted to control the temperature in the dryer. Operating thermostats sometimes stick, causing control problems. These thermostats are usually positioned near the exhaust duct bulkhead or the fan housing of the dryer. Remove the back panel of the dryer to get at them.
Before you make any checks, try tapping the housing of the thermostats lightly with the handle of a screwdriver. This may jar the contacts loose. Temperature control switches are located behind the dryer control panel, and the panel must be removed for switch testing or replacement. Here's how to test and replace the thermostat:
Step 1: To check the control panel thermostat, make sure power is off to the dryer. Test the thermostat with a VOM set to the RX1 scale. Clip one probe of the VOM to each thermostat terminal. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Step 2: If necessary, replace the thermostat with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 3: To check an operating thermostat, first make absolutely certain that the power to the dryer has been turned off and the dryer is cool. Then disconnect the leads to one side of the thermostat. Test an operating thermostat with a VOM set to the RX1 scale; clip one probe to each terminal of the thermostat. Disconnect the leads to one side of the thermostat so that the meter won't give a false reading. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
thank you .............please rate it
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
