When machine is turn on when ask to use function user code will not work don't have code, print works just block out of copy mode.how do you reset it.
  • 3 more comments
  • ed chavers Mar 19, 2011
    its a Ricoh mp5500 copier
    it's a Ricoh mp5500 copier.
    is there a reset for the admin code?
    This is not a printer it's a copier Ricoh mp5500 and it will not allow a code for the user code....
    if you go to the setting it will not allow any change.....
    Hi the name and model Ricoh model mp5500
  • 2,632 Answers
Welcome to Fixya. Can you please try to use the Manual below and try to delete the user code and create a new one. You can also use the manual for more info and finction of the machine. Please refer to page 167
Ricoh Support Manual
If you have questions please let me know. Thanks for using Fixya.
Posted on Mar 19, 2011
  • 794 Answers
Hi jakebuysm457,
May I ask for the brand name and model of your machine.
Thank you for using Fixya.
  • 2,574 Answers
Which printer model do you have?
  • Reparatii PC - Service IT
    The default username and password are Admin ...and blank on password.
    You can change/delete a admin password by logging into WIM (Web Image Monitor) with the default user name and password:
    Username: supervisor
    Password: (leave blank, there is no password).
    If the Supervisors account details have been changed and you do not know the details, you will have to do a NVRAM replacement to regain control and access to the machine. A NVRAM (Non-volatile random access memory) is a piece of computer memory chip where all the user login and password information/settings are stored in your Aficio SP 4100N.
Unable to print 46
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Sep 29, 2014 | Brother MultiFunction Center MFC-440CN...
How to reset the user code?
there is two ways to achieve this, either enter servisse mode using yellow 1 0 7 and stop (hold stop for a few seconds) go to copy sp the go to 5 mode and the scroll to 801 memory all clear... this will reset the machine completely... if you not feeling so brave inside 801 there is sub menus just stroll down to clear UCS
May 15, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
I have a Brother MFC-9840 that comes up with Print Unable 21. I have cleaned as set out in maintenance to no avail. Please help. Thank-you
The MFC-9840 manual says that this code is reporting a mechanical error.
Try to reset your machine in maintenance mode:
menu * 2 8 6 4 (within 2 seconds)
91 and then 99 to exit service mode.
User manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_9840CDW_EN_2378.PDF
Brother's suggestion:
Turn off the machine's power switch and then
turn it on again. If the error message continues
leave the machine for several minutes and then
try to print, copy or scan again
Good luck.....
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 15, 2010 | Brother MFC-9840CDW Laser Printer
Inherited a copier, but locked out
First of all be very careful as this machine could be a leased machine and if so the dealer and or leasing company is going to want it back.
Press the utility key, then admin tab. The default password is 00000000.
If that does not work then try 12345678
If neither of these 2 works then reply back and I will have to try and walk you thru the service mode entry procedure.
If it does work then you want to turn off the copy track function. That will clear all the accounts and allow full use of the copier with no user code.
Nov 18, 2009 | Minolta Di3510 Fax
We have an error code SC546 any idea what that means. It just showed up.
This is a fuser code; it can be reset on newer models by pressing...
clear modes(yellow key)
1, 0, 7
clear stop (hold down until screen changes)
select copier sp
turn machine off with red rocker switch(likely on left side of machine)
wait 10 seconds and turn back on
If the code comes back, there is likely something malfunctioning on the machine, and it will require service. If not, this should get you by for awhile.
Nov 18, 2009 | Ricoh Office Equipment & Supplies
Hi, I have a Brother MFC-210C that keeps telling me its unable to clean, I followed the user manual but it keeps displying the same message, what do I do now? please help
For Brother MFC210C Printer Fax Copy Scan
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode).( "The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.") Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Carry on printing !!
Dec 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Reset error codes for Canon imageRUNNER 3300i
We followed the instructions from your tech. on which buttons to press to get into the menu function and then followed the directions for clearing the error code. After that turned the printer off and back on and the error code reset and the printer worked like a champ.
Jul 02, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Copy limit
the only way is to goto additional functions > System Settings> dept I.D > set a user code and password, then you can set a copy limit per user id, once a copy limit is reached you have to reset it or create a new user I.D. Thats the only way, you can also get reports on how many copies each I.D has done..
Hope this helps
May 16, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
When I turn on the printer "Download Mode" appears on the lcd screen.
The machine might be trying to download the latest firmware wait a few minutes it may go if not it is it the user manual under on screen messages.
Thanks J
Sep 13, 2007 | Sharp AL-1661CS All-In-One Laser Printer
k24674
jasbo
jasbo
