Question about JVC Audio Players & Recorders
I dont know which wires goes to the cd player like where the wire harrness from the cd player meats the car harrness which wires go to which one
Posted on Aug 02, 2008
Cd player color code wiring panasonic cq
FYI if you remove the factory unit it will disable the cars starter and or fuel pump. The radio is tied into the security system. You shoud be able to get the wiring color codes here:
Jan 17, 2014 | Oldsmobile Cars & Trucks
Car cd player
what is 432/7568 math
Oct 03, 2013 | Dodge Nitro Cars & Trucks
I have a misubishi cd and casette player out of a jeep model #P04704383AD date code 3447 supplier28046 serial #T00AM3447B0509 I need the wiring diagram its doing into a ford explorer
The easist way to install it ,Is to get a wireing kit from a car audio supply store for your ford, As long as the radio harrness isn,t cut off you can get a wireing kit that plugs in to the factory harness, I installed car audio equipment for over 40 years, Untill i retired this summer, End a llways use a kit,If some one didn,t cut the harness of, If they did cut the factory harness off,I would go end get one from a auto wrecker ,End put it in all so. It makes it a hake of a lot (Easier) to install, Hope this hels you out,
Nov 08, 2012 | Audio Players & Recorders
Too many different color wires, and i dont know which wire goes where
the cd player wires them selfs should say what they go to. your also going to need a stereo wiring diagram for you car, sometimes your wires from your car have what they are for too.
Sep 21, 2011 | JVC AM FM CD DET FACE CAR STEREO
Hi, i have a 2004 dodge ram 1500 with the infinity stereo system. The factory cd player broke and i tried to install a new cd player, i bought the right wiring harrness and conected it. But the speakers...
it sounds like you need to turn on our amplifier. this is simple and easy to do just by connecting the blue/white wire off of the back of the radio to the blue wire on the harness that connects to the factory harness.
Jul 02, 2011 | Car Audio & Video
I have a deh p3900mp
Antenna does act as ground, just not the best way to do it. Use the 6mm bolt hole in the rear of the chassis for a mounting strap, run a wire from there to the factory (vehicle) radio harness ground.
May 17, 2009 | Pioneer DEH-P3900MP CD Player
I dont know which wire in the memory to connect it to my after ma
The memory wire is usually the yellow wire in the harness - it goes to a constant 12v (battery) source. That's how the cd player remembers all of your presets. The red wire (the other power wire) is connected to a switched 12v source, so it only sees power when the key is on. That is why the cd player shuts off when you turn the key off.
Mar 27, 2009 | Pioneer DEH-1600 CD Player
Car stereo
its pretty simple, the remote wire is used to tell the amplifier that the cd player has came on. once the cd player has came on, the amp then comes on. simply take a light tester that has a sharp tip, turn the ignition until the cd player comes on, and start testing all of the wires. when you hit a wire in which the light tester says there is power flowing through it, turn the cd player off. if the light goes off with the cd player, you have found a wire that is suitable for a remote wire. dont know how to use a light tester? http://www.bcae1.com/testlite.htm
Jun 18, 2008 | 1996 Pontiac Grand Am
SONY EXCD-206 December 1996
I have the same radio, the radio's harrness has a red wire ignition 12 volt,yellow battery 12 volt, black ground, and a blue Iam not positive it can be the amp, or illumination.
Nov 18, 2007 | Sony CDX-CA400 CD Player
How to install a panasoinc cq-df903u in 91 integra
The wires for the two harnesses should be color coordinated or at least closely colored. The harness should have come with either a guide that says what is what or the wires themselves have little flags saying what they are. You can use this to match it up with CD Players wires by using the manual from the CD player to know which wire is what.
May 18, 2007 | Panasonic CQ-DF903U CD Player
93 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
