Question about RCA R52WM24 52" HDTV Projection Television
When the picture is on its looks like 3d with 3 different color lines on top off screen what is wrong with my tv is it fixable
    Genius:
  • 1,030 Answers
Now from the symptoms u describe you are haveing a problem with convergence curcits... with these set the first thing you have to determine is you have the comon fl231 fuse problem. to do this read this http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in . if this is not your problem then you will have to determine which part of this cuircit is damaged.... do you have convergence setup options.... and can you manually and auto converge these.
Posted on Mar 19, 2011
Hi, im having picture quality problem. kind of a blue shadow mixed with a little orange mostly on top of the screen. you see double of the image in a shadow haze. should I junk this tv or is there a fix...
No,this tv it is fixable and still can be in used for many more years to come.This tv have a problems known as a convergence pictures problems,it is dead.Tv problems have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes this problems.Must have the tv convergence board to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 16, 2011 | Hitachi 57F500 57" Rear Projection...
I turned My tv on and the top of the screen has red, green, and blue swirl lines, and the rest of it looks like watching a 3D movie without glasses, and the picture looks as if you took out the screen and...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or pictures look like 3D?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Aug 11, 2011 | RCA D52W19 52" Rear Projection Television
The top and bottom of the picture makes a rainbow effect toward each other in the center of the screen++++++++TV. model 3 ws55807 it's a 55 inch screen the problem occurs all the time. I have no TV repair...
This tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than this tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.Fix the tv convergence board to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Question - What would cause the colors to be off..meaning..it looks almost 3D and with widescreen shows the black on the top and bottow bows into the main area of the screen. Any ideas?
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.The tv convergence board must be replace all these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Dec 17, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen looks like it is in 3D colors are seperated.
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergnce board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | Toshiba Televison & Video
The tv displays 3 screens and each one in different colors
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence and some or all of it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Nov 08, 2010 | JVC HD-52G786 52" Rear Projection HDTV
Text/images overlap each other in 3 colors, 3D distorted picture
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Picture is bending at the top and bottom and looks 3d
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 15, 2008 | Samsung PCN5425R 54" Rear Projection...
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pictures looks 3D-ish with small horizontal lines
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
