Question about Garmin GPS
Outside of the screen on my Garmin 2730 split and peeled away. Looking either for somewhere to purchase replacement screen or reasonable repair.
  • tcouchman Aug 02, 2008
    Wow - seems like a simple replacement if I could buy the screen...My zip code is 95004
  • 3,422 Answers
The only way to repair is to go to a authorized Garmin service center.If this is not under warranty then let me know your zip code.
Posted on Aug 02, 2008
  • Priya darshan Aug 02, 2008
    If you give me the zipcode i will let you know if there is a any local repair person who can repair this for you.If it is under warranty then i strongly recommend you to replace it.
    ok,now if you need a replacement screen there are only two ways to get that.1)get it repaired from authorized Garmin service center and they will replace the screen.2)please click on the below link,contact them and ask if they have a replacement screen for your model.As for replacing it you will have to do it yourself.
    Now there are no local repair shops to repair your device in your area.
Garmin gps troubleshooting
you do not "obtain" a split screen. It automatically shows the exit of a freeway as you come up to it. you also have to be navigating somewhere not just viewing the maps. if that seems to not be working, try updating the maps as that is bundled with them (junction view)
Jul 21, 2014 | Garmin nuvi 2597LMT 5" GPS Navigator -...
Vaneli shoe repair
I've got Vaneli shoes that the linings are peeling away. I've tried to contact Vaneli but they don't respond. The suggestion of taking the shoes to a shoe repair which I've done but the shops I've been to say they can't replace linings.
Mar 09, 2014 | Vaneli Clothing Accessories
Can you replace or remove the plastic 'sheet' on the screen of the garmin gps? there's a tear on my gps screen.
There's a protective plastic sheet on them when new. This peels off. If yuo're talking about the scren itself it's not user replaceable. You may be able to get it replaced by garmin. Contact details for Garmin are available at
Jul 28, 2010 | Garmin GPS
I am trying to replace the LCD Touch Screen Digitizer on my Garmin Nuvi 205. How do I open the thing? I do not see and screws etc.
The two No. 5 Torx screws are under the label. Just peel both sides away a little and you can access these screws. Then pry open carefully with plastic spatula or something thin made from relatively soft plastic material. Good luck!
Mar 24, 2010 | Garmin nuvi 205 GPS Receiver
The touch screen now works intermitantly, and it appears that their is a mist on the inside (water??). No one has opened this unit up. Is it warrenteed? What is the fix for this?
It sounds as if a small amount of water or moisture has entered the GPS.
The 2730 is now a discontinued product, and if bought new, is likely out of warranty. If purchased recently (less than a year) as a factory refurbished device, it would normally be covered under a Garmin Factory warranty. Water damage however, may not be covered.
If it is no longer covered, Garmin offers a "flat rate" repair for $170. Learn how to go about obtaining this service at the site below:
A couple things come to mind... at $170, to me - it doesn't seem to make much sense to repair, when "like new" factory refurbished GPS units can be had for the same / less money. The refurbs come with 1 year warranties (instead of a 90 day type after repair) & latest version of maps.
Lastly, if you don't want to do either of the suggestions above, you could attempt removing the back cover and allowing the device to fully dry out in direct sunlight for a day or two. Reassemble and operate the GPS again. Doing this sooner rather than later will increase the chances of successful drying with having permanent water damage.
Oct 08, 2009 | Garmin StreetPilot 2730 GPS Receiver
Garmin 2730 touch screen has failed. cannot get past first screen
My 2730 would not calibrate. I saw this on a forum and it worked like a charm.
1) Fill a bowl or sink with warm water and a small amount of neutral soap. AJAX worked for me!!!!
2) Turn the SP2xxx screen down towards the water and immerse the front of the unit in the water.
3) Using a *soft* toothbrush, *gently* clean around the frame edges of the screen. With care, the soft bristles should dislodge any foreign object that may have become lodged between the screen and the unit case.
4) Rinse the front of the unit under running water.
5) Gently dry the outside of the unit with a soft towel or cloth.
6) If desired, leave the unit in a warm airing cupboard overnight to completely dry out.
Hook up the unit and try it out! All reports I've read elsewhere reported that the touch screen worked again after this process. If it fails, you were going to send it back to Garmin anyway so you haven't lost anything by trying it. This worked and I plugged it in right after with hair drying on cool for a couple minutes.
Aug 12, 2009 | Garmin StreetPilot 2610 GPS Receiver
A fixed safe way to carry a Garmin GPS on a horse?
You can purchase a neoprene pouch with clear plastic front screen which has a belt clip on it. It's made by Garmin. Check your local Garmin dealer. It's very secure and I've never lost mine yet.
Jan 07, 2009 | Garmin eTrex Legend GPS Receiver
Screen broke
Here are your options:
1. Contact Garmin to repair your unit.
2. Purchase a As-Is Nuvi 3xx on eBay with a working screen and repair yours.
3. Purchase a replacement screen on eBay and repair yours.
4. Purchase a new GPS.
- Jim
Sep 02, 2008 | Garmin GPS
Garmin 2730 OFF and ON
Had a similar problem about a year ago., and discovered that the jack on the power cord had split at the seam and the contacts were not touching the unit consistently. A little bit of super glue to glue the halves of the plug together solved the problem.
Nov 13, 2007 | Garmin StreetPilot 2730 GPS Receiver
GPS Logo
140 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
