Question about Hayward Comfort Zone Electric Spa Heater 11kw
The heater kicks on for about30 seconds then the breaker trips its a brand new filter plumbing and everything so the flow is exactly where it should be .. so whats the problem ????
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
It's a bad heater element.
Posted on May 09, 2013
2 Suggested Answers
thepool
  • 78 Answers
SOURCE: Hayward H250K gas pool heater error code
Low Flow errors are not necessarily real. They can be caused by improper adjustment or a defect of the pressure switch. Locate the pressure switch. Verify that the "switch" makes contact. Adjust the dial, reducing the distance the switch has to travel to engage. This will effectively lower the operating pressure required to operate. Keep adjusting until the unit stays on.
Posted on Apr 23, 2010
Fl0 code
Flo ? for Flow Error?
That would for any number of reasons that the Flow Switch is not sensing enough water flow to trip the sensor/pressure switch or actual true water flow switch.
Heater will not run or heat, if there is not enough water flowing!
The heater will sense this. So, whatever will restrict or stop sufficient water flow is the problem.
  • Dirty filter
  • Closed valves
  • Not enough water in tub or pool - low water level
  • Clogged pump impeller
  • Clogged baskets:
    • at pump or at skimmers
  • Clog / stopped up plumbing line
And finally, you may have a bad flow switch/sensor
Sep 06, 2014 | Jandy Pool & Spa
When i turn on my spa and heater it states on the outside unit "no air flow" and it won't heat up
that is usually an indicator of water flow not the air flow.
What does the hot tub do when you turn the breaker from off to on?
does it run through the purge cycle?
is it kicking out the GFCI?
if it is not tripping the GFCI then you most likely have either too little water flow for the heater to kick in or not enough water flow to activate the heater.
Try taking out your filter and see if that solves the issue.
you may also have a bad temp sensor if the tub just runs and runs but never heats up.
Rod
US Parts Center
888-521-6183
Feb 08, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Titan SCR4 tankless water heater. Breaker on water heater itself keeps kicking. Not in breaker box. I have 2 double breakers, 50 amps each in box, no problem there. On the water heater there are 2...
Breaker trips when heat on wire exceeds amp rating, or when breaker is bad.
Most breaker are slow acting, and do not trip immediately.
Shorted elect could cause problem.
http://waterheatertimer.org/Water-heater-is-tripping-breaker.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 15, 2017 | Water Heaters
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) Before calling service technician, open following link for Bosch troubleshooting steps.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Apr 22, 2011 | Bosch PowerStar AE115 Tankless Water...
My spa hums for a few seconds then kicks off. No flow. lights and control display are working.
Is the shut off occuring @ the GFI? & is there an error code displayed on your topside?
If the breaker is kicking off, the best way to troubleshoot is to disconnect all components, (pumps, heater, circ, etc.) & then plug one in & turn the breaker on. repeat the process until you locate which component is tripping the breaker.. then you know whats causing the trouble
Feb 24, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Installed my second Fahrenheat FUH 724 7500W heater in another garage. Installed same as previous heater that works perfectly. used 10 Gage wire and 40A 240V breaker (2-20A). Wiring is correct. Heater...
Could be either. But, I suspect that wiring is getting hot enough to trip the breaker. Check all of your wiring to see if there is a hot spot or insulation melted.
Feb 05, 2011 | Fahrenheat Ceiling-Mount Industrial Heater...
I know this is a long shot, because I don't know the brand or model of my heating unit; it's in a "partial attic" space that I can't get into at the moment. I'm hoping that I can provide enough...
sounds like its tripping every time you get it going firstly does it have a return air if so does it have filter if it does do you clean filter regulary like every two weeks, because it might be going out on over temp or poor air flow and over temp will be caused by poor air flow across it's heat exchanger, and there may be several reasons for this but i reckon you need to spend $$ if its not the filter or the airfolw as a problem
Nov 19, 2010 | Heating & Cooling
Pool pump shutting off/tripping the circuit breaker
What kind of pump are you using?
Sounds like the Intex is restricting water flow there by heating up your pump and shutting it down..
You may need to re plumb everything to handle the flow.
Intex hoses and fittings are different than the industry standards just so the can make you buy from them
Do what ever it takes to get good flow
Jul 01, 2010 | Intex Automatic Salt Water System for ...
Arc fault trips under load
Arc fault breakers are definitely a pain. First make sure the receptacles are made for a 20 amp circuit. Second vacuums, Curlers,and most appliances will trip your breaker since they create an arc or a short if you will to operate. That is exactly what these breakers are made for. To stop the arc. Apparently they never really thought the whole arc fault thing through. As per code in most of arizona you only need this breaker in bedrooms where this type of appliance is not used. They also are more prone to popping so make sure you aren't running something on each of the receptacles at the same time
Dec 18, 2008 | Siemens 20Amp 1-pole arc-fault circuit...
Hayward Comfort Zone Electric Spa Heater 11kw Logo
116 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
