Question about Canon Pixma MP500 All-In-One InkJet Printer
Paper keeps getting jammed in MP460
The paper tries to go thru but only one side pulls it and it goes sideways and gets jammed.
I had the same paper feed grabbing problem on pixma MP 610 printers - take a flashlight and look down into the feed rollers inside - deep - I found a paperclip in one and a hair clip in another - you need a pair of very fine pincer pliers to extract so you dont damage the roller assembly's made of plastic - and voila no more misfeeds and grabbing on the right side - hint - dont put anything on top of the printers because when you lift the scanner cover, it nicely slides anyting on top into the paper feed assembly and results in a jam
Steve
Posted on Aug 06, 2008
That sounds just like what I fixed yesterday. I had to take off the side plate of the printer, which is one screw on top that you can see, behind the scanner lid. And the other you can see at the front when you open the whole lid, it sort of unclips once you unscrew it. I found paper in the side that it had been chewing up most and removed it and put it all back together and now it works. Dont forget to turn off the power. Good luck. Sharina
Posted on Aug 05, 2008
Paper jam problem
Hi Sarah, do you have an epson printer?
In these years i had this problem with a lot of Epson Printers...
Well, if this is the situation, i'm sorry to tell you that this is caused by the printer pick up rollers that are worn, so... you can try to wipe with alcohol the surface of the rollers, but there's no way to fix this...
You can try to gently push the paper inside the printer when it takes the sheet
Dec 08, 2015 | Office Equipment & Supplies
Mp499 The paper tries to go thru but only one side pulls it and it goes sideways and gets jammed.
The feed wheels on the one side are either worn out or have some scrap paper stuck on them. Take a good look , after removing the paper tray, if it has one , inside the machine. It might be possible to turn the machine around and see into it from behind, if there is an access door on the back.
Aug 02, 2014 | Canon Office Equipment & Supplies
Getting message that I have a paper jam but there isn't on to be fpund
Try checking the printer for foreign objects that might be interfering with the paper path. Tilt the printer sideways and try shaking it a bit. After that, try printing. If the issue persists, clean the rollers of the printer.
Dec 13, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
Paper jams when I put it in the tray to fax (from the top tray)
your wheel on one side is impacted with small pieces of paper
this causes the paper flow to go unevenly you need to clean you wheels on both sides oil them and wipe dry with a paper towel
then do the paper feed jam clear and let a few pieces go thru to pick up any remiaining debris
Aug 22, 2012 | Brother MFC-7820N Printer
Paper pulls to right side and then jams it all started when paper jam i pulled it out and ever since then when loading paper it pulls to the right and then jams
Try running a good sized thickness paper thru it to clear out the cutters.
Sometimes when they jam some residual paper is left in the space between the cutter wheels and causes the paper to feed askew...
I use the cover from old phone books.
Sep 29, 2011 | Office Equipment & Supplies
Hp 2610 paper jams on print command. Paper pulls sideways.
find the paper feed rollers and clean them. they get slick and one side will catch quicker and pull the paper side ways.
Aug 12, 2010 | HP Photosmart 2610 All-In-One InkJet...
Paper jams
If you have some small twiser like you use to pull those nasty nose hairs, and pull the paper out with that. If that doesn't take a air compressor and gently blow it. A compress air will have some moisture in it and you don't want that to get on to the rollers.
Nov 11, 2009 | Canon PIXMA MX310 All-In-One Printer
HP scanjet 5590 pulls the paper half the way in and then starts pulling sideways and then gets stuck.
Have you checked to make sure there isn't previously jammed paper in the feeder?
It sounds like the paper is getting stuck on just one side which is causing the paper to start going sideways.
Oct 15, 2009 | HP Scanjet 5590 Flatbed Scanner
PAPER JAM:
OK, this is going to take a bit of nerve but it has worked every time (dozens) I have seen this problem. Switch off the printer and unplug, make sure the ink carriage is parked. Get a stiff piece of A4 card such as the backing from an A4 notepad. Place the card in the paper feed and push through quite firmly for the first half inch then open the scanner unit and watch the rollers inside the printer as you push it further. It should push out anything blocking the paper path. Push the card fully through in the direction of paper feed, never try to pull paper jams or anything else out backwards if it can at all be helped.
Please take a moment to rate this solution. Thanks.
Mar 18, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
3,090 people viewed this question
old marine
old marine
