Question about Sharp CD-XP200 CD Shelf System
Protect in display and stereo wil not switch on
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 19, 2011
My JVC car stereo display " Protect " on display
FIRST PRESS THE RESET BUTTON BEHIND THE FACE IF DONT WORK CHECK ALL SPEAKER WIRES SOMETHING MIGHT BE TOUCHING
Jul 24, 2011 | JVC AM FM CD DET FACE CAR STEREO
I have a digital camera marked 810/u810, when i power it on it display a blow screen with information write protection with a question mark. If memory card is removed it displays normal. I wil like to find...
HI, thats is probably the little switch on the memory cards
as to be slide to off the swicht is on the write protect mode
its locate on the edge of a side of the mem card if its an sd cards
regards Alan
Feb 26, 2011 | Olympus Cameras
M getting protect on my stereo display
It is possible that your device is shutting off due to a short in the circuit. hence for protection the device is switching offf the powerr to the main circuits. You will need to check for the short , maybe outputs or drivers and disconnect, replace to confirm. since you have not mentioned the model I am not able to comment more. Good day
Aug 12, 2010 | Samsung Electronics - Others
Car stereo keeps displaying protect
There is a short making the radio protect itself by cutting out to prevent it blowing up..
Check all wiring for any touching and check all fuses for radio in fusebox under the hood.
Aug 12, 2010 | JVC AM FM CD DET FACE CAR STEREO
Stereo
If your stereo is showing the protect display, it is an indication of a power shorting. This protection is to avoid serious circuit burnout and could be in the power output stages of the set. You will need to open and check for short in the output drives, the preoutput stages, the speakers or even the protection circuit amp.
It is important to address and check these sections with a votage check, elimination process too confirm the part. this may be a little tough and diffcult unles it shows easily on a continuity test. Helpful. Good day
May 31, 2010 | Kenwood Audio Players & Recorders
Protect error on model # CD BA200 Sharp Stereo
If you are a technician desolder the Audio amplifier IC,and check if the stereo turn on but with no sound.If the stereo turn on the audio amplifier IC is in short circuit and need to be replaced.
Good luck
Jun 05, 2009 | Sharp CD-BA200 CD Shelf System
"PROTECT" is displayed on the car stereo when turned on
This is really easy to fix. Look on the face plate for a REALLY small hole. Put the tip of a pen in the hole and it should work. This usually means the stereo isn't wired properly so if the PROTECT keeps coming on after you've re-set it, take it to a dealer. To make sure you're everything is in properly. Hope this helps...
Jan 26, 2009 | Kenwood KDC-MP228 CD Player
PROTECT mode
I have a Sharp cd-c2900 home stereo and a "protect" word came up on the lcd?? The stereo is not working now and olnly shows a "protect" word?? Can you please tell me if there is a reset button some where?? Thanks , "Joel" My Email address>> Jovelopa22002@yahoo.com
Jul 17, 2008 | Sharp CD-C2900 Shelf System
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Car audio 'safe'
'SAFE' Is displayed because the radio is protected by a 'CODE'
The more wrong codes you enter the longer the word 'SAFE' will remain on the display... Look through all your paper work & try to find the 4 digit 'CODE'... eg: 2456 this can then be entered by pressing the 12456 preset buttons.
Failing that you will have to go to a audi dealer they will be able to get it from a database or buy a aftermarket stereo.
Dec 19, 2007 | Rockford Fosgate 25 To LIFE Punch 150...
Sharp CD-XP200 CD Shelf System Logo
49 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
