Question about Toshiba Computers & Internet
How to turn on the LED backlight display on Toshiba Satellite A665 computer?
  • Toshiba Master
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Mar 19, 2011
Are the display bands compatible?
1) Toshiba Satellite P300-13j LCD screen example,
http://www.screentekinc.com/Toshiba_Satellite_P300D-13J--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Thin Film Transistor (TFT) Active Matrix LCD screen, that is WXGA, and uses one CCFL for a Backlight.
2) http://www.lcds4less.com/ToshibaLaptop__Toshiba_Satellite_P300D-12L__laptop-screens.html
Thin Film Transistor (TFT) Active Matrix LCD screen, that is WXGA, and has 1 CCFL for a Backlight.
There is a pretty good chance. The screen Inverter and LCD screen are a matched unit. I would remove the screen Inverter from the P300-12L, and use it also.
Looks like this,
http://www.lcd-inverter-shop.com/Toshiba/Toshiba-Satellite-P300D.html
If I may ask;
1) Is there obvious damage to the LCD screen?
2) If there is not obvious damage to the LCD screen, have you used an external VGA monitor with the laptop?
To see if the problem is the graphics chipset, or the video cable, or inside the Display Assembly.
A) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P305/take-apart-notebook-1.htm
B) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
Post back in a Comment.
Regards,
joecoolvette
[Primer:
An LCD screen cannot produce light by itself,
(Click on the monitor icon,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/ )
It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
LED stands for Light Emitting Diode
CCFL stands for Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Observe the last 8 photos especially. This article shows you that the LCD screen is an assembly. It is composed of layers. Just like the 3M company's tutorial. Also shows general instructions for replacing a Backlight.
A screen Inverter is used to convert the power from the laptop, for the LCD screen, and Backlight.
It is a small circuit board, and is usually mounted towards the bottom of the LCD screen, and behind the Display Bezel.
A CCFL, (Or two of them), uses a screen Inverter.
LED backlighting however, may or may not use a screen Inverter.
Using LED's for backlighting is relatively new, when discussing backlighting technology.
Some of the first designs of LED backlighting does use a screen Inverter.
Newer designs do not seem to.
90 PERCENT OF THE TIME the problem can be attributed to a bad screen Inverter.
Aug 21, 2012 | Toshiba Satellite Computers & Internet
Recovery disc for toshiba A665-S6054
You must contact Toshiba customer support for this recovery disk set, there will be a charge for the discs.
Jul 12, 2012 | Toshiba Satellite PSAW0U-01K001 A665-S6054...
A665-s6057 screen compatabilty issue
Hello
If you can see the image on the screen with a flashlight then it's a problem with the inverter.
Good Luck
Feb 13, 2012 | Toshiba Computers & Internet
A665 Toshiba satellite when i switched on no dispaly after a while it's turn off the fan is noisy
Please remove the battery and ac power adapter. hold power on button for 1-2 minutes. Then try to power on laptop with ac power adapter without battery. check the display of laptop.
If not check the dc voltage of the ac adapter. is it the same voltage as written on the ac power adpater. if not same please try with another adapter.
If not remove the hard disk and ram. clean the fan,ram. Reinsert ram and power on with ac adapter. check the display.
Please check with external display if laptop is turned on but no display.
Jul 01, 2011 | Toshiba Satellite A665-S6086 Laptop
I need driver software for lab top toshiba satellite a665/s6086
all toshiba satellite A665-s6086 drivers: --->click here<----
and watch the video
May 19, 2011 | Toshiba Satellite A665-S6086 Laptop
How and where to download all drivers for toshiba a665-s6093 after reinstall the os with windows 7 64 bit some of fitur like hot key and etc not working properly....pls need help asap !! thanks
Hi
Go the website of the manufacture, choose your laptop model (
Satellite A665-S6093), and the operating system ( 7-64bit),
and download the software utility for the keyboard
Please tell us your results
Good Luck
May 16, 2011 | Toshiba Satellite A665-S6093 Laptop
I cannot get the keyboard to backlight. ??? LED Backlit, it lights in a couple places but not behind the keys. Please help.
The keyboard does NOT have back-lights. The display does have led back-light so you can read the screen.
Apr 14, 2011 | Toshiba Satellite A665-S6070 Notebook
Toshiba Satellite Laptop A665-S6086 came with 4GB of 2x2GB DDR3. Upgraded today to 8GB of 2x4GB DDR3 and went to turn it on, but the lights are on it beeps and then shuts off. Took out battery and AC for...
There is a chance that you ESD and ruined the motherboard. Take all the RAM out and try to boot it and see. Then put one in and boot and then the other. This checks the memory. See if you can get to CMOS setup screen in the bios.
May 20, 2017 | Toshiba Satellite A665-S6086 Laptop
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
413 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
