Question about JVC Televison & Video
Jvc 61-inch (HD-61MD60) -- on the bottom of the tv are 3 different spots. You can still see the picture behind two of them but one of them looks like a black cutout. They are getting bigger and spreading up the screen. What is causing it and can it be fixed?
  • 4,472 Answers
I assume you are talking about a coaxial connector? If that is the case then you could use a vcr to plug the coaxial cable into then output from the vcr with composite/rca and that will plug into your converter.
Hope that helps.
Thank you,
Lee
Posted on Jan 13, 2010
Black spots on TV when watching sports etc that have white in the picture. The black spots are showing up on the ice for instance (Hockey) all over the TV.
I SUGGEST CLEANING THE LENS ASSEMBLY. IF YOU LOOK ON THE SIDE OF THE TV CABINET YOU WILL A SMALL SQUARE THAT IS ABOUT 4 INCHES BY 6 INCHES HELD IN WITH ONE SCREW IF YOU LOOSEN THAT SCREW YOU WILL BE ABLE TO GET INTO THE CABINET OF THE TV AND CLEAN THE LENS GOOD LUCK
Jan 06, 2011 | JVC HD-52G786 52" Rear Projection HDTV
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
JVC TV: Model # HD61Z456 61 inch - what is the modet number of the bulb that I need to replace. I have no picture on my screen.
The bulb part number is: TS-CL110UAA. Take out the bulb and look inside from the front side. Visually inspect any physical damage inside. If it looks clean, lamp might be good
Jan 22, 2010 | JVC HD-61Z456 Television
Changed lamp in 61 inch jvc dlp and still can't get tv to turn on
Ballast board is what turns Lamp on and CK your Fans if Lamp Fan is defective TV willnot come on.
Dec 11, 2009 | JVC HD-61Z575 61" Rear Projection...
MY RCA R61WH76 61 INCH TV IS BLURY AND LOOKS LIKE IT HAS 3 PICTUR
RCA Scenium Profiles HD61 TV IT'S AT 480i how I get at 1080i or 720i please help....thanks...
Jul 02, 2009 | RCA R61WH76 61" HDTV
Need owner's manual
Click JVC Support to download owner's manual of HD-61FH97 TV
Apr 13, 2009 | JVC HD-61Z575 61" Rear Projection...
JVC HD-61Z786 Projection TV: Problem: There is a light/dim spot on the tv screen. Thinking it was the lamp, I replaced the lamp and the light/dim spot is still there. Any ideas on the problem?
There is either dust on the lens or there is a problem deep within the light engine. This is a some-what common problem with these sets. The light engine is very expensive; not economical to repair.
Mar 30, 2009 | JVC HD-61Z786 61" Rear Projection HDTV
Jvc hdmi????
Do an EEPROM reset and will be ok.
Dec 11, 2007 | JVC HD-61Z886 61" Rear Projection HDTV
Televison & Video Logo
71 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
