The TV would be on, the "arch" white on the screen with a loud "boom" and shut off. We would turn it off for a while, put it back on in about fifteen minutes, it would be okay. Then the frequency would increase until finally, you go to turn the TV on, he light turns from red to green but then there is a single "click" sound, and the light turns back to red. This happens within a few seconds. Took off the back and saw black dust by the HV distributor. Boards have cold solders on them: meaning already been worked on, and they are clean. The only part of the back that had the black dust was where the Sanyo VH distributors were. fuses looked good, every thing else looked good. Now what? Thanks Pittsburgh Rose
  • 5 more comments
  • nurseroseluc Mar 19, 2011
    Sorry thought I put that in there: Pioneer Elite Pro 710, old projection model
    Do not know what has been worked on.
    I have a Pioneer Elite Pro 710 rear projection.
    The TV would be on, the give a "arch"like white curved light on the screen with a loud "boom" and shut off. (When the picture is on, its good. But this seems to happen every time we change it from "factory" settings to what I wanted in tone and contrast.) We would turn it off for a while, put it back on in about fifteen minutes, it would be okay. Then the frequency would increase until finally, you go to turn the TV on, he light turns from red to green but then there is a single "click" sound, and the light turns back to red. This happens within a few seconds. Took off the back to see if there was any LED or signal lights on when it would turn on. There was not. Yet I saw black dust by the HV distributor. The Power Boards have cold solders on them: meaning already been worked on (I got this TV used and previously serviced) , and they are clean. The only part of the back that had the black dust was where the Sanyo VH distributors were. Fuses looked good, every thing else looked good. Now what?
    I ask that not as though I would touch it, for I am not an expert, that is why I am here, paying to ask someone who is.
    I know black dust is not good, a carbon dust from something over powered. I know enough to buy the parts when I get the service man over, that way I am not overcharged. Does this sound like I need a new HV distributor? A new video card? I check Ebay and parts for this TV are not easy to find. Gotta go to Pioneer, and its not pretty.
    What is your best guess about what this gonna set me back?
    I have had the TV for two years now and got it for a song. Love it for it takes a beating from the 1 year old grandchild which by now would have destroyed a plasma or an LCD.
    I would love to hang on to it, but is it worth it?
    I have chosen another "expert"...I found your comments insulting to me: as though I would be stupid enough to work on such a high voltage piece of equipment. It costs money to ask questions when I could have called around here for free, so you best learn to express yourself better, learn to be patient with those new to writing for "techs" instead of conversational expression, and learn a new answer other than"Get a professional"...WOW, for $12 bucks a question, you don't say? there is a reason your rating is what it is, I see that now.
    People get on here to learn, sound intelligent and save money, not waste time on people who claim the be "experts" and have their own agenda..."Call me, I will come to fix your TV..." got lots of guys right here in Pittsburgh to do that...I wrote here to learn, and that I did, never to do this again.OK?
    LOL...okay, now all that in single mom english please! : )
    Flyback/same as HV distributor?
    What am I looking at in parts?
    Silver Dragon...well done!
    Thank you sir...thank you.
    Silver Dragon: spoke informatively, practically and matter of factly...much to my disappointment, I guess I am getting a new TV!
    Thank Silver Dragon.
  • 12,061 Answers
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both. Although it is evident that you may already have had the explosion... Any explosion, always has a bad consequence, and destroys the component(s) concerned. there is also frequently, "Co-lateral" damage, caused by the failure...
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Sanyo in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
Unless one has money to spare, hours to spare, access to a service manual and spares, plus the required aligning, programming & servicing equipment & knowledge.. DIY service of these sophisticated computer controlled digital receivers, ie: The TV, is in reality rather impracticable.
These sets are often a challenge for even qualified engineers, and things can actually be made worse by inexperienced DIYers, say doing something as simple as doing a setup step out of order.
Posted on Mar 19, 2011
    Genius:
  • 1,112 Answers
Hi:
You have not mentioned if this is a rear projection set, meaning has pictubes, but from the discription you are giving i am asumming so. Check the High Voltage retrace scan Capacitors near and around the Flyback Transformer, also the Flyback could be arching inside of its casing. It is best to change the flyback transformer and the horizontal output transistor, they work in conjunction with each other, The H.O.T is mounted on a heatsink in the same area of the transformer. You might also try checking the High voltage spitter this device seperates the high voltage from the flyback to all three tubes.
    Top Expert:
  • Televison & ... Master
  • 75,462 Answers
Hello
You haven't specified anything about your TV in your post; that i means, its brand name and model number etc; Please provide these to me by Fixya, and it will help me to detect the fault, and help you. The model number is important as well as brand name. Give me some details about what you have done in it till now, and which componets has been replaced. OK.
  • The Knight
    The Knight Mar 19, 2011
    Its video processing section has been damaged. it must be replaced as card basis. Please don't attempt to make any repair be self in projectors, if you aren't an experience serivce technician, or without any knowledged person by side. It will turn the things worse, and get the device irreparable. moreover, the spare parts and cards of old type of projectors will be very difficult to get too. So proceed with thinking. It will be better for you to contact the nearest Pioneer authorised service center. OK.
  • The Knight
    Hello
    The problem of your TV seems to be complicated. But the dust will do not much until it accumuate nere a very high voltage secion. No schematic of your Tv model is now available on net. If so I could advice you more. pioneer's spare parts, whichever devices' may be, won't get very easly. Get it checked by any experienced service technician. OK
My KP-51HW40 clicks off after running for a period. The red power light blinks when it goes off but screen stays dark. When TV is shut off for a while it restarts and runs fine. The "On"...
KP-51HW40 shuts off due to incorrect white balance and blue arch lines is an evidence of that incorrect white balance. I hope tv standby red light would flashing 5 times then 3 seconds pause and again 5 times when tv shuts down.
This is rear projection tv that has three picture tubes (red-green-blue) inside to generate picture that projected at front screen. These three picture tubes must be drive with correct drive voltage to produce good picture of each color.
Solution for your tv problem is Screen Voltage adjustment that can be done easily if you are handy with electronics stuff repair.
Let me know your expertise level to guide you more and if you feel unconformable by tv repair then local tv repairman will help you to adjust white balance in tv.
Hope these info will help you.
Let me know if you have additional questions.
Thanks.
Nov 05, 2010 | Sony KP-51HW40 51" Rear Projection...
Red arching lines showing up on screen promident when a dark background is present
Red picture tube needs screen voltage adjust. Open fornt or back of TV and look for a black square looking box with adjustment knobs. Look for red screen adj and slowly turn rt or lft until lines just disappear. If screen goes too bright tv will shut down, just turn back on again and retry
Dec 04, 2009 | Sony Televison & Video
Loud sound of air and screeching tv keeps powering down
Sounds like a CRT is arching internally. to confirm remove the covers to have a view of the picture tube necks- in adimly lit room you should see bue arching in one of the tubes. (there are three piture tube with glass necks)
Sep 14, 2009 | Zenith R56W36 56" Rear Projection...
Have a polaroid tv, model 3700 seriel F0600181940001053. WATCHING THE OTHER NITE AND A LOUD SQUEAL CAME ON AND THE PICTURE WENT OUT, TURN IT BACK ON TODAY AND THE SQUEAL IS STILL THERE WITH NO PICTURE..NO...
I have a flat screen polaroid lcd hdtv model 3700, first the sound started to get really loud with a beeeeeeeeep when we turned on and after a while was gone, now it doesnt! we had to put mute and connect the tv to a sorround system to hear it without that crazy noise, and now the colors of the tv are gone too its just black and white when we try to see the dish satelite but if we put a movie on the dvd player colors are perfect we try to conect the ps3 player too but its black and white too. Help what can it be!!!!????
Nov 14, 2008 | Televison & Video
Sony turns on and off again
My tv too had a blue screen problem. Then it started to shut down after staying on for less than a minute. I thought that I would with a huge repair bill but I followed the directions at this link: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html and now my tv works perfectly.
Apr 27, 2008 | Sony KP-57WS500 57" Rear Projection...
Samsung HLN507WX 50 rear projection
do you hear if the color wheel has been whining loudly?
clean the fans from dust.
Jan 20, 2008 | Samsung HLN5065W 50" Rear Projection...
Booming noise
10 years is about life for these, booming noise like a gun shoot?
i would suspect a cap blew up can you open the back and see any burn marks or paper ?
Nov 26, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
I850
Go to where you bought it and tell them the problem they might supply you with a new phone if you have a warrany with that phone hope that solves the problem.
Nov 07, 2006 | Motorola Mobility NEXTEL i850 Flexible...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
