Question about Baby Lock Esante
Will not advance the fabric. It just sews in one spot.
    President:
  • 1,216 Answers
I'm assuming you've already checked to see if your stitch length is set to a normal stitch length, and that the presser foot is down when you're sewing.
The bad news is that you may have a broken gear in the feed dogs. I would take the machine apart as far as you can using the manual (pull the needleplate, pull the bobbin case), and use a penlight and dental mirror to inspect everything possible, clean (vacuum, no canned air!) and oil per the manual again, put in a new needle, and try again. But I really suspect a bad gear here. It's a common way for the less expensive machines to die.
Posted on Mar 19, 2011
I have a Brother PE770. It is running just fine, but leaving little brown (looks like oil) spot on top of the fabric. They wash out easily enough, but how do I fix this?
You need to figure out exactly what is causing the brown spots. If it is, in fact, old oil, you may want to moisten a soft piece of fabric with rubbing alcohol and clean the presser foot bar and needle bar as the oil could be running down and staining the fabric.
Mar 17, 2017 | Brother PE770 Computerized Sewing Machine
Advance problem.
your foot pressure is too high.
lower the pressure as mentioned in your manual and you should be alright
Jul 02, 2008 | Kenmore 15218 Mechanical Sewing Machine
I only have a small amount of feed through the sewing claw, i mostly have to pull it through on my Toyota 2400, is this normal is is something wrong?
Unable to locate much information about your make/model machine.
If your machine has the capability of dropping the feed dogs for darning or free motion quilting, check that the feed dogs are in the up position for sewing. Also, verify that the stitch length is set to at least #2. Any shorter stitch selection will cause the machine to advance the fabric so slightly that it will nearly sew in place.
Some machines also have a pressure adjustment for the presser foot. If the fabric you are sewing is very fine, the feed dogs may have difficulty gripping the fabric to advance it through the machine. You can add body to the fabric by including a stabilizer when sewing the fabric, ie a wash-away stabilizer.
May 05, 2016 | Toyota Sewing Machines
My Memorycraft 6600 zig-zag stitch is not working. The fabric would not advance and the needle comes down ******* the metal if I try to shorten the width of the stitch.
suggestions
if the zig zag stitch is not working could be something wrong with the cam
try taking the bobbin out & use a different bobbin
try a new needle, make sure the needle is correct for the fabric being sewed
could also be a problem with the feeddogs
Feb 07, 2016 | Sewing Machines
Fabric not advancing
run you finger over the feed dogs under the foot - can us feel them above the surround? if not, you have placed your machine into free style sewing, and the feed dog does not advance the fabric in this mode. Look in your manual and see where the feed dog gets lowered/raised - raising it again should solve your problem.
Nov 23, 2013 | Janome Sewing Machines
Won't sew, the fabric stays in one spot
is the problem the fabric is not moving forward but staying in one spot? which would mean the feeddogs need to be checked to see what position there in --up for sewing---down for darning
or the thread is not feeding into the machine?
Feb 10, 2012 | Janome DC3050 Computerized Sewing Machine
Bobbin thread bunching, fabric not advancing
Check your manual to find out how make sure that the feed dogs are up. Those are the "teeth" on the bottom that move the fabric along. If you're not sure or can't find the manual then posting the question with machine's model number might help.
If the fabric won't advance because the bobbin thread is jamming: Check to be sure that your tension is set correctly and that your machine is threaded correctly - even experienced sewers can occasionally miss a spot like forgetting the change the loop after rewinding a bobbin. Also make sure the the thread in your bobbin is the same brand and type as the spool that is threaded. An imbalance in the types of threads can throw off the tension.
Jan 12, 2011 | Kenmore Sewing Machines
Sewing machine will not advance the fabric
Have you tried adjusting the tension as you sew?
Use a scrap piece of the same fabric, (doubled, etc to simulate piece you'll be working) and adjust the tension as you sew. Sometimes, that's all it takes.
Jan 27, 2009 | Sewing Machines
Fabric doesn't advance
Have you checked your feed dog position? The fabric will not advance if the feed dogs are in the down position. For the machines which don't have the raise/lower feed dog capability, there is a plate that covers the feed dogs and must be removed to advance the fabric when sewing.
Nov 06, 2006 | Bernina 1008
Sewing Machines Logo
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
