I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock through this printer for printing the name, address and gift certificate amount on the card stock. I have tried every all 4 types of 5x7 paper choices available to me in the print dialog box, HP Advanced Photo, HP Premium Photo, Other Plain, Other Photo. In all attempts, the printer just spits out the card stock and displays an error saying that the "page size or paper type is incorrect." The printer prints as expected to 4x6 photo paper and plain paper cut to 4x6 size. 5x7 has also printed as expected on plain paper cut to 5x7 but will not print to the 5x7 card stock. It's not really excessively thick card stock either... about the same as a 3x5 index card or "thick" photo paper. This is so frustrating because this printer was the answer to myneeds. I needed a compact printer that would print to 5x7 card stock so we can print our gift certificates easily when we travel. I'm assuming there must be some sort of sensor inside the printer that is making the determination that it doesn't like the card stock for some reason. Any ideas how to get this working for me? I've checked HP.com for driver updates; there are none. In fact, there is no driver even available for download as the driver is installed by the printer when hooked via USB to my MacBook with 10.6.6. I've got v1.1.0 of the driver installed. I've tried printing from various applications and browsers with the same result. It just won't print to my 5x7 card stock. I had a lengthy talk with an HP support tech but no solution was obtained. Somehow the printer is sensing the card stock and refusing to print to it. I guess I'm looking for a way to defeat the sensor or somehow trick the printer into accepting this card stock. HELP
  • Michael Erb
    Michael Erb Mar 19, 2011
    The advice in this reply to my problem does not even apply to the printer I have. This is generic advice that may apply to some printers but not to the HP Photosmart A646.
    Please read my question carefully. There are only 4 paper types available. They are stated in my original question.
  • Michael Erb
    Interesting concept that did not work.
    An interesting thing that I just discovered is that the card stock we use is dark colored one one side. When I flipped the stock around so that white side was going in the printer, the printer would print on it. So it's not the thickness that is the factor here, it is the color of the card stock. I then turned the card stock so that the dark color was going into the printer and in addition taped a one inch piece of white paper flush to the bottom and extending up the fron of the card stock about 1 " (the edge going into the printer). It printed this time just fine. So obviously there is an optical sensor of some sort in the printer that is the culprit. thank you for trying but I have stumbled upon the cause of the problem myself.
  • 1,555 Answers
This is a generic issue with all the card stocks specially if they are rough at one side and plain on the other side. By plain and rough I mean one side normal paper type and on the other side plastic quoted or very fine smooth paper. My advise is to try print on both the side and first time select normal paper and give a print out on smooth side then select card stock and try to print on smooth side only. and same way try to do for the other side also.
Posted on Mar 19, 2011
    President:
  • 1,738 Answers
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
    Genius:
  • 1,570 Answers
Yes, sometimes you can trick the printer and sometimes not.
Set the printer to 5x7 paper size.
Then print multiple different copies (difference name and addresses), the first 1 use a plain paper and the succeeding use all the 5x7 card stock. Sometimes it work that feeds the 1st paper and it will continues through out.
I have hardly used my A646 printer and it is coming up with the message "open the print-carriage access door, clear the jam, and then press ok to continue", How do I do this???
Hi Brit
HP PHOTOSMART A646 PRINT CARRIAGE JAM
It would seem that there is some papar or some other foreign object obstructing the the passage of the print head carriage in you printer.
Look carefully at the paper input and output trays to see if any paper of foreign object is jammed.
Then look carefully at the ink cartridge compartment to see if the cartridges are properly clicked into place and that all the sealing tapes and plastic clips have been removed from the cartridges. Check that nothing is blocking the free movement of the print head. When closing the door the to the ink cartridge compartment, make sure that the door is closed properly.
Then power off your printer, power it up again and test it again. If the error message appears again, press OK on the printer's control panel and test again.
A PDF copy of the printer manual is downloadable from here in case you do not have access to the printer's original manual:
h10032.www1.hp.com/ctg/Manual/c01846782.pdf
Good luck.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Oct 04, 2011 | HP Photosmart a646 InkJet Printer
Printing 5x7 card stock in HP 1510 injet all-in-one printer
You need to set up your printer preferences to accommodate the type and size of paper you wish to use, usually listed under printer/print or page set up.
Invariably, paper is loaded, butted to either left or right of the paper feed, but on the other side of the feed there should be a sliding stop which keeps your paper in place.
If feeding from the top feed, print side towards you, if printing from a tray at the bottom of the printer, print face down.
You can download a user manual from here once you've chosen your model printer:-
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=+HP+PSC+1510&submit.x=11&submit.y=7
Apr 22, 2010 | HP PSC 1510 All-In-One InkJet Printer
When trying to scan or reprint a picture on my HP photosmart C5180, and I choose a 4x6 or 5x7 or8x10, it prints out a thumbnail picture. If I insert my card from my camera, it prints a beautiful 4x6 print....
please go ahead and right click on the printer icon and ytou will get an option that says printing preferences
fromthe printing prefercnces select photo printing select the right photo printing
select the size and the printing type
hope this should fix the problem for more details you can also foillow the instructions from hp
since the ocpy is not fine you can try and do these steps:
1.disconnect the power cable from the back of the printer
2.press and hold the power button of the printer for 20-30 seconds
3.restart the printer and see if it coipies fine
for more details please download the manual from te following URL ;
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=1153481&lc=en&cc=us&dlc=en&lang=en&cc=us
thanks
regards
Hamid
Feb 19, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C4795. Can't get business cards to align correctly at top. Alignment is perfect on plain paper, but starts too high on card stock so every one is lined up wrong. What am I doing wrong? Using...
In printing properties and printing preferences be sure and tell the printer you're printing labels, it allows more time for the card stock to reach the starting point.
Jan 05, 2010 | Office Equipment & Supplies
Cannot print 5x7 photo on Photosmart D7360,
if you dont hvae 5x7 option you can creat your won setting open printer adn faxes ...>goto file ..>server properties there you can creat it......
Oct 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
When I tryto print 5x7 prints from windows fax viewer my photosmart all in one model C4480 is printing the first 5x7 fine but the second 5x7 also has a small wallet size printed ontop of it
Solution one: Print on heavier paper Try printing on a thicker type of paper. Solution two: Check driver settings If printing on plain paper, make sure the driver settings are set to Plain Paper.
  1. To change the driver settings, click the Properties button in the Print window.
  2. If the Paper Type is not set to Plain paper, click the drop down box and choose More .
  3. Find and click Plain paper , then click OK .
  4. Click OK to return to the Print window and click OK to continue printing.
Jun 18, 2009 | HP Photosmart C4480 All-In-One InkJet...
Printing 5X7 photos
try aligning and cleaning the cartridges
hope this helps
Apr 12, 2008 | HP Photosmart 2575 All-In-One InkJet...
Print 5x7 invitations on my 950?
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
Oct 04, 2007 | HP PSC 950 All-In-One InkJet Printer
486 people viewed this question
k24674
jasbo
jasbo
