Question about General Heating & Cooling
Brand new heater but during initial lighting pilot7 dont lit or even spark none.
  • General Master
  • 8,220 Answers
Check the polarity. Wired backwards and the newer furnace boards won't work.
Posted on Mar 19, 2011
My heater is brand new and it will not light.
first check that the heater is designed for natural gas and not for lpg
the jet sizes are different
call for a gas fitter to inspect the unit and make the necessary adjustments
Oct 14, 2015 | Heating & Cooling
Hayward H400FDN will not stay lit - Brand New install - NO Fault codes.
make sure wiring is correct especially if wired 120 volt read instructions inside panel
Jan 28, 2014 | Hayward Industrial Products H400FDN...
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
Lowe's hot water heater pilot light will not stay
If it is one of the new ones with the fancy gas control and the blinking light... does the light blink?? or not??
If it is blinking then the pilot should stay lit...
If it will not blink then the sensor is bad or not in the right place...
Or... the gas control is bad... this is happening alot...
If it is brand new... take it back...
heatman101
Sep 05, 2011 | Whirlpool Water Heaters
The pilot light will not stay lit. A new
Try cleaning the orfice for the pilot light. You will have to dis-assemble the fuel lines from the thermostat to the burner to get at it. The orfice has an extremly small hole in it, do not make it any larger, just clean it out.
Mar 14, 2010 | Drills
5510 king pellet stove exhaust problem?
Mine does the same thing too-what I do is shut it off and put it on again then it works fine.
Nov 22, 2009 | Napoleon Auburn Pellet Stove Heater
Just bought used bike, bought new motor hooked it all up, even new ecm's.test light shows power from all sources motor turns just wont start
Hi and welcome to FixYa,
Initially, check for the presence or absence of spark at the plug(s). If none, check if there is a +12 on one terminal of the ignition coil and a pulsating ACV on the other. Additionally, verify that the neutral light is lit. Try starting with the clutch lever pulled in and/or the side stand folded up.
Postback results of tests.
Good luck and thank you for using FixYa.
May 26, 2009 | 1980 Honda GL 1100 Innerstate Gold Wing
Heating & Cooling Logo
19 people viewed this question
Top General Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Bill Long
Are you a General Heating and Cooling Expert? Answer questions, earn points and help others
