Question about Slik (611613) Tripod
When I bought the Slik 88M in Singapore (1988) I was shown how to get the camera lens very close to the subject on the ground (macro photography of plants). I remember it worked perfectly and have the photos to prove it. I need to do this again and can't for the life of me figure out how to get the camera so close. Also what is the screw mount for half way down one of the legs
  • Slik Master
  • 5,412 Answers
Hi - had one myself years ago - excellent 'pod. Firstly, the auxiliary screw mount on the leg is for whatever purpose you choose - standard 1/4 " thread, so you can mount a flash gun on it. However, combined with the rest of your query (IIRC), to lower the viewpoint you firstly undo the leg locks where the bracing struts meet the legs - this enables you to lower the 'pod to its lowest level (don't forget to raise the centre column).
Then, unscrew the entire head from the top of the centre column, and mount it on the screw mount we spoke of earlier - this is about the lowest you can get it. Drawback is that you need to kneel down to see through the viewfinder. Hope this helps.
When I bought the Slik 88M in Singapore (1988) I - 0000 slik 88-1li1ntbgxak40fx334oubg4i-4-0.jpg
Posted on Aug 28, 2017
3 Suggested Answers
  • 102366 Answers
SOURCE: attachment at base of camera - SLIK 88M
The standard tripod screw mount is 1/4"-20tpi. 1/4"-20 UNC will also work. You should be able to find such bolts at your local hardware store.
Posted on Dec 31, 2009
SOURCE: The lower leg clamp on my SLIK U212 deluxe is cracked.
Per another post on here i located a website which sells Slik parts -
http://kenkooutlet.com
- the part was cheap but the shipping was too high in my case. Good luck.
Posted on Jul 24, 2009
Canon rebel eos When trying to take a picture the autofocus won't work up close
Close up and macro photography require special lenses chances are you are to close for the lens to see what you are attempting to focus on. Another thing if you are hand holding the camera the chances are extremely good you can't hold it steady enough for the camera to lock on to the subject.
When shooting macro the depth of field is extremely shallow to you need to stop down the lens to maybe F11 or even F22 so now you have a light problem. You didn't say how close the subject was to the front of the lens. So to get started on this close up photograph mount the camera to a tripod switch the lens to manual and slowly focus on your subject. There is a small green dot in the lower right corner of the viewfinder that will come on sold green when your subject is in focus. If it doesn't you are to close to the subject for the lens you are using.
Dec 16, 2010 | Canon EOS Rebel XSi Digital Camera
The distance focus ring, is it supposed to turn all the way to the macro symbol when you are focusing on a subject that is very close?
If you're right "on top" of the subject - then, yes - it should indicate "macro". Macro focusing is for "very up close" photography and is exactly as you describe. You simply physically move the camera a little closer to or further from the subject to focus.
Not all lenses are capable of macro focusing. The vast majority of these non-macro lenses are required to be at least a couple (or more) feet away to focus. Macro lenses on the other hand can usually get just inches away - which is a great capability.
Enjoy your macro lens!
Oct 12, 2010 | Canon EF 28-80mm f/3.5 -5.6 USM Lens
I HAVE A NIKON 60 AND NEED TO KNOW WHAT TYPE OF LENS TO GET
In order to get close to the subject, you need to be able to focus close. If you're using one of the kit lenses, you won't be able to get much closer than a foot or two.
In order of decreasing cost:
  • Special macro lenses are designed to focus closer, as close as a couple of inches, but they cost more.
  • Extension tubes fit between the camera and other lenses, allowing the lens to focus closer.
  • Close-up adapters fit in front of the lens, also allowing closer focus.
One major consideration with any type of close-up photography is lighting. Having the camera close to the subject tends to block out light. Two possible ways around this are: a tripod or other support, and an additional light source such as an external flash unit.
Jul 22, 2010 | Nikon D60 Digital Camera
Can't use macro
Select Macro Mode - this is a fairly obvious first step but I’m always surprised by how many digital camera owners haven’t explored the shooting modes that their camera has. Macro mode is generally symbolized with a little flower and when selected it will tell your camera that you want to focus on a subject closer to your lens than normal (the minimum distance allowed will vary from camera to camera - consult your instruction manual to find yours). Macro mode will also usually tell your camera to choose a large aperture so that your subject is in focus but the background is not.
Read more: http://digital-photography-school.com/macro-photography-tips-for-compact-digital-camera-users#ixzz0KaYY32aZ&C
Jul 07, 2009 | Cameras
Trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
Dec 25, 2007 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Good book for a beginner?
have you set it to macro mode? (little flower icon on the right cursor) this function will allow you to get within about 2cm of the subject, however do not use the zoom as the lens cannot focus close enough. To get results any closer you will be looking at an slr and a budget on a few thousand! If enabling macro and not using zoom to allow the lens to focus doesn't get you close enough in you can always enlarge and crop images. have a look on www.picture-skew.blogspot.com i've taken some macros of flowers and bugs, this camera can capture the hairs on an ants back or the individual lenses of a flys compound lens eye.
persevere with this camera, for a very small budget you will get amazing results, ISO refers to the speed of 'film', it comes from the dark old ages of 35mm film cameras. Basically a low ISO is the lowest sensitivity to light and gives the best image quality, however as the ccd is less responsive to the light the camera holds the shutter open for longer. The higher the ISO the more sensitive the ccd but the greater the noise and lower the quality of picture.
Books, try looking for more photography orientated books and less digital camera based books. An upto date photography book will tell you all the technical information about how to take a good picture for any given senario.
if you would like any further advice email me (address on the blogspot)
Dec 20, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Macro Mode
The MACRO MODE is easily accessed via the arrow pad on the back of the camera. Press the left arrow key, which has a flower icon, to start the MACRO MODE. Press the down arrow key to select the flower icon in the menu. Then press the OK/MENU button; camera is now set for close-up photography. Remember to turn off the MACRO MODE when you begin shooting subjects beyond the focus range of the MACRO MODE.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Close-up picture
The Macro Mode is easily accessed via the arrow pad on the back of the camera. The right arrow key, which has a flower icon, is depressed to start the Macro Mode. Press OK and the camera is set for close-up photography. Remember to turn off the Macro Mode when you begin shooting subjects beyond the focus range of the Macro Mode.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Accessories lenses
Olympus offers the following add-on lens accessory options: MCON-35 Macro Extension Lens (equivalent to 1/4 life size, subject size that will fill the frame is approximately 1.4" x 1.9" f2.4 Tele/f2.0 Wide, 72mm filter size) minimum focusing distance - 4.75 inches. WCON-08B Wide Extension Lens (equivalent to 28mm f2.0 in 35mm photography, 105mm filter size) minimum focusing distance - 3.6 inches TCON-14B 1.45X Tele Extension Lens (equivalent to 200mm f2.4 in 35mm photography, 86mm filter size-tentative) minimum focusing distance -1 ft. TCON-300S Tele Extension Lens (equivalent to 420mm f2.8 in 35mm photography, 49mm filter size) minimum focusing distance - minimum focusing distance - 3.9 ft.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Slik (611613) Tripod Logo
818 people viewed this question
Top Slik Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Slik Photography Expert? Answer questions, earn points and help others
