Question about E-Machines eMachines Desktop PC
Virusgt....popup has locked up my computer. how do i reset it ... from zero if need be.
  • E-Machines Master
  • 11,800 Answers
Reinstall Windows using the recovery cd that came with it when you bought it - put the cd in, reboot and when asked to select the boot device choose the CD unit. From there on it's pretty much automatic.
Posted on Mar 21, 2011
My ipod doe not have sound and a popup says generic volume cannot be stopped
Follow these steps to reset an iPod Classic, or in fact any iPod with a Click Wheel.
Make sure the iPod Classic isn't simply paused or locked.
Check the screen for a lock symbol.
If you see a lock, unlock the Hold switch.
You should be back in business.
Put the iPod on a flat surface to stabilize it.
Slide the Hold switch on, then slide it off.
Hold down Select and Menu together for several seconds with two fingers.
Make sure your finger isn't touching the Click Wheel.
When the Apple logo appears, release Select and Menu.
If the iPod Classic doesn't reset, repeat the above step.
If that still doesn't get your iPod Classic to restart, plug the iPod into a power adapter or a computer and see if it starts up.
http://support.apple.com/kb/TS1382?viewlocale=en_US(URL)
Aug 01, 2013 | Apple iPod Audio Players & Recorders
Have simplex lp1000 keyless lock sytem is zeroed out but will not reset or take new code, aleays stayes unlocked
"If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution
Solution: Follow the procedure for changing a combination except omit step 3 (do not enter
the existing combination)."
I excerpted the above from the full instructions on how to change the code. If you don't have them, got to this link:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
and go across from L1000 to the last column, "Tips".
When you hover your mouse over PDF, two choices will appear; left click on the upper one, "Changing the code/..." to download it.
The download will be a PDF file format. If you are unable to open it, you will need to download and install Adobe Reader on your computer. There is a link (Get Adobe Reader) at the top right of the literature grid.
When you do get the download open, you will have the stepwise procedure and illustrations necessary-but don't forget to omit Step 3, if you believe that you have the ZERO code problem!
Good luck--and please provide feedback if this helps!
Oct 31, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
I have one Konica Minolta bizhub c250, unfortunately I forgot the administrator password can I reset it to system default.
There is no procedure to restore the admin password. It is possible to reset and enter a new password, and for that you will need a technician to make the adjustments on SERVICE MODE (stop,0,C).
Jan 27, 2011 | Konica Minolta bizhub C250 All-In-One...
Printer driver installation
Probably nothing.
When you select to download the file check that the popup window showing the percentage downloaded shows an acceptable amount of data being downloaded, could be anything from 2Mb to 200Mb depending on the printer driver and OS in use. If there is no popup window or it is just shown very quickly and disappears it means only a small amount of data (or nothing) was downloaded.
Right click on one of the downloaded files and select Properties and see if it shows zero. If not it could be your virus checker is deleting contents or Dell have a zero length file stored on their website - contact Dell and ask for the file.
May 17, 2010 | Dell Inkjet 720 Printer
Osd lock popup and maina menu popup is continously blinking on my monitor screen plzzz help me how can i remove it? i have view sonic monitor E70FSB...plzzz help me out
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..
in case case of 45Bn & 55V..look for Controller Reset IC201/IC202 (KA7045/KA7045AP) [it is a small alike transistor 3 pin IC !!] along with the afore said..
and in case of 56V..look for +14V SW. Transistor A1281 & C945 (therein) along with the afore said..
..beware u must b a professional..
contact ur system admin/vendor....
Nov 02, 2009 | Computers & Internet
My Sansa c250 has NO FILES on it, yet shows ''NO MEMORY'' available
Try this. Go to settings, reset all. connect to computer, when the popup displays, select view files. all should be there. I had the same problem today and that solution worked for me.
Bill
Sansa e250
Nov 23, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
My mobile has a phone lock and i dont have it
the default phone lock code is zero s (put the zeros until it lasts)
otherwise try to reset ur phone by using these codes
*2767*2878# Custom reset
*2767*3855# eeprom reset...
Feb 09, 2008 | Samsung SGH-E350 Cellular Phone
Phone lock code
  if this code is  for ur  phone  only then  the  only possible solution is that .... u need to go 4r phone reset ..   TAKE care  u need to take the data back up  before  going 4r phone reset ............  concern sonycare center   4r reset  process ...
Sep 16, 2007 | Sony Ericsson T610
E-Machines eMachines Desktop PC Logo
16 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
