Question about Maytag MSD2756G Side by Side Refrigerator
The automatic defrost cycle is not working in freezer. Can this just be low on freon and making it freeze up? I can defrost and refrigerator will work fine till it freezes up again.
  • Maytag Master
  • 4,655 Answers
Most times on your model it is the ADC or adaptive defrost control. Part number 13 in photo here=> MSD2756GEW Maytag Refrigerator Control Panel This is behind your controls inside your fresh food compartment.
61005988 Adaptive Defrost Assembly
When the fresh food compartment begins to get too cold is usually when the part #8 in that photo goes bad and that is called the auto air damper
61005971 Damper Control Assembly
More on that part next time. I believe you will be fine once the ADC is changed, Thanks, Sea Breeze
Posted on Mar 19, 2011
The freezer doesn't freeze that good but the refridgerator does work.
It is possible that the defrost cycle is not working. Look for signs of ice built up in the freezer compartment. The excess ice prohibits the air circulation.
26128165-5xkmzur1kbcrfneaoxy43scu-3-0.jpg If defrost cycle appears working and compressor runs continuously it is probable that the Freon is low or compressor is failing.
the usual tell is the refrigerator gets colder than usual and the freezer does not get as cold. The situation is that the compressor runs until the freezer temperature is satisfied. If the compressor can not achieve the cold temperature of the freezer it will run continuously.
When the unit runs continuously the bi-pass of air is increased bringing more cold air into the refrigerator portion of the unit.
Mar 13, 2016 | Cars & Trucks
Ice forming
  • One cause of this is the compressor is going bad or Freon is low. The freezer is no longer able to achieve the zero temperature requiring the compressor to run continually. The refrigerator because of the continues running begins to freeze up. Food in the refrigerator begins to freeze and the freezer is not as cold as it should. This results in a very expensive repair of replacement of the unit .
  • The defrost cycle is not working. Depending on the conditions the unit has a sensor that detects when the defrost cycle should initiate. If this fails to occur than ice builds up on the coils and air can no longer pass preventing the normal cooling process. Many models use a mechanical timer that stops. On some units the defrost cycle can be initiated via advancing the mechanical timer. This repair is a reasonable expense.
  • The third possibility is a door was left open and the unit iced up the cooling coils. Suggest in that case shut off the unit , remove the food and allow the unit to manually defrost, Restart and see if unit gets cold and defrost cycle is working.
Nov 22, 2015 | Refrigerators
FFA74 HIGH TEMP WARNING LIGHT
That indicates that your system is low on Freon or there is a leak somewhere in you sealed system.
samedayappliancerepair.ca
Jul 06, 2017 | Refrigerators
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
GE Eterna ESS25LGNA freezer side not working
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer coils are freezing up and won't cool the refrigerator
I am no expert at this but have a few thoughts:
1. sometimes a refrigerator (or airconditioner, etc) can freeze up due to LOW Refrigerant. even the "wrong" part can freeze.
2. most refrigerators have a defrost cycle in which they pass warm air through the freezer compartment to evaporate frost. These work on a timer. If the timer motor is broken they will not remove frost and could result in a freeze-up.
Many freezers (e.g. chest, etc) do NOT as they are meant to NOT be opened as often as a refrigerator and thus do NOT go through this energy-wasting defrost cycle.
3. you may have a leak in the gasket allowing moist room air to enter causing excess moisture which then condenses on the freezer coil, although (2) might help that, but at a significant waste of energy.
4. I believe a fan may be used to bring some of the cooling from the freezer to the refrigerator (if it is a combination)
All three of these conditions result in wasted energy, and obviouslyl should be solved.
All but (1) may be things you can check on yourself. (1) I have heard of "hobbyist/engineers" doing themselves, but requires a means to get at the "freon" valve, have a meter, be able to replace / augment it with the right kind, etc - best left to a professional.
Jul 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have an Amana Side by Side. The freezer section
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
Build in kitchenaid, freezer working but not freezing
This video I made how to change evaporator on Thermador refrigerator, which is just copy of of Build in Kitchenaid. Problem was that it was running, but ice cream never got frozen. I checked pressures, was low on freon. I checked evaporator coils - found out that defrost heater got deformed and was touching evaporator coils - so it burned holes, where freon started to leak.( I think it designed not best way). Defrost heater on this fridges way to close to evaporator coils. Check this video to get an idea what Im talking about. I hope That helps u to understand why this repair is so expensive and what causing it.
May 08, 2009 | KitchenAid KSCS25FKSS Side by Side...
Freezer coil and back of freezer full of ice, never defrosting
Low on freon or the blower fan has stopped
Apr 11, 2009 | Refrigerators
Refrigerator is freezing; Freezer is defrosting...
Have you phoned the company you bought it from, and read the manual?
Dec 21, 2007 | Jenn-Air JCD2297KE Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
330 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
