Question about Advent Netbook
When i plug my speakers into headphone socket i gets an ehco on my advent netbook why is this?
    Genius:
  • 1,189 Answers
Hi dichubby, to fix the "Echo."
Do the following:
when i plug my speakers - paul7of9_81.jpg From the "Desktop Screen," [Right / Alt] click on the Volume Icon. paul7of9_82.jpg
Once the 'window' open!
Select the "Playback Device" shortcut.
paul7of9_167.jpg Next, highlight the Speaker icon,
or {2x click} to open the [Properties] 'window'.
Select the Enhancements" {Tab} ...
"You can place a [Check] in the "Disable all sound effects."
Or click on the Settings: Down-arrow, and choose a "Sound Effect, 'or' None!"
This should fix the 'echo.'
Click on the "Apply and OK" button when finished!
!"Take a 'moment to rate the help" Thanks
Posted on Mar 19, 2011
Lg arx 8000, I get sound from the headphones but not to the speakers from the main amp, can anyone please assist?
If inserting a headphone plug into the headphone socket used to switch off the speakers, assume there is something wrong with the headphone socket.
Aug 24, 2016 | Audio Players & Recorders
Kenwood KR-V7080 reciever will not play through speakers.I can still plug headphones into the reciever and get audio but not through the speakers. Tested the speakers and they still work.
If the speakers used to switch off when the headphone plug was put in the socket, suspect the socket it goes into as being the trouble. It is clearly not connecting the speakers, when the headphone plug is removed.
Aug 17, 2015 | Kenwood Audio Players & Recorders
MY N150 IS NOT PRODUCING SOUND
Fix your headphone socket contact, if your headphones work but internal speakers do not..
May 04, 2012 | Samsung N150 Netbook
My headphones will work but my desktop speakers will not why?
If your speakers work fine when plugged into the headphones socket on the front of the system, then there is no fault with them.
If the sound through the speakers is very low when plugged into the rear panel socket, that would suggest that you may be plugged into the line out socket rather than the speaker socket and that there is a mismatch of the impedence between the socket and speakers.
If you have three audio sockets on the rear panel, try the speakers in the second output socket (but not in the microphone socket) and see if it makes a difference.
You could try the same test using the headphones - do you still get good sound levels with the headphones when plugged in to the rear panel socket?
If neither the speakers nor headphones give good sound when plugged in to the rear panel, then you may have a problem with either the sound card if the sockets are on a separate PCI card, or with a poor connection on the cable to the socket header bracket from the motherboard pins for audio for integrated adapters.
Dec 23, 2011 | HP Compaq dc5000 Microtower PC Desktop
Replace advent md40674 power socket
Hi
That is not a problem,all you ned to do is to get to any computer store around and you would get the power socket of your notebook replaced.
BEST OF LUCK
Jul 03, 2010 | Advent Netbook
I have got 2CH speakers idont know where to plug in to the CPU
There are usually 3 audio connectors on a sound card. For Line in, headphone/line out and microphone. The connectors maybe connected to the motherboard or there is a separate sound card.
These connectors are 2.5mm audio sockets - connect the speakers to the headphone/line out (usually green).
If you are not sure which connector to plug the speakers in, just start a audio CD and plug the speaker plug into each socket connector until you get music from the speakers. You will not damage anything if you plug the speakers in the wrong audio socket.
Oct 24, 2009 | Acer X193W LCD Monitor
Sound coming from built in speakers instead of head phones
the socket that you are using, I assume headphone socket, has a "switch" inside that cuts off the speakers when you insert the plug. Perhaps this is broken/bent or shorted out.
May 03, 2009 | Acer Aspire One Netbook 8.9" Notebook
Speakers not working
Hi
Check the device manager and make sure everthing is enabled.
If everything is enable called the support guys for the speakers
Mar 25, 2009 | Acer Aspire™ T180 PC Desktop
Cable Type needed for Advent AW-820 wireless speakers
If I recal correctly these hookup like computer speakers with a 1/8" stereo line with a male plug on it. What you can do is buy the "y" adapter for using the RCA outputs on most devices and use these that way, or you can use them through a headphone jack etc. The adapter is a 1/'8' or 3.5mm Stereo female plug going to (2) RCA Male jacks. usually they come pre labeled red for right and white for left.
Feb 06, 2009 | Recoton Advent Advent AW-820 Main / Stereo...
Advent Netbook Logo
106 people viewed this question
Top Advent Computers & Internet Experts
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
