Question about Whirlpool ET8WTKXK Top Freezer Refrigerator
Whirlpool top freezer fan not runnning and no voltage to the fan with the compressor running
  • Whirlpool Master
  • 4,655 Answers
This refrigerator has a basic wiring diagram showing power going through the defrost timer, compressor and compressor start components. Because the model number could be very close to the ET8WTKXK your model may have either a ADC, adaptive defrost control or typical 482493 Defrost Timer
Here is a Whirlpool ET8WTKXK Top Freezer Refrigerator basic wiring diagram.
sea_breeze_121.jpg In this photo you may have bad contacts inside timer part 4 in photo=> ET8WTKXKB03 Controls Ethier way I don't think it will be hard to find, Thanks, Sea Breeze
Posted on Mar 19, 2011
  • John Tripp
    John Tripp Mar 20, 2011
    Thank You for Your Rate! Sea Breeze
Fan in Freezer portion not running, compressor works
The door switch, some fridges run the fan on door closed only.
Jul 10, 2013 | Frigidaire FRT17G4B Top Freezer...
Freezer will not freeze water in bottles and seals between freezer door and fridge are very hot to touch
That means that heat from the compressor is being transferred to the rest of thet machine like a heatsink. The reason why is either the condensor fan motor is not running which most likely the reason, or the condensor coils are severely dirty. You'll need to pull the machine out from the wall, leaving it plugged in and remove the lower plate at the bottom. Locate the fan, usually more toward the right hand side if your behind it, and if the compressor is runnning then the fan should be running. Period. The fan draws air across the compressor and blows it throught the condensor coils which will located right next to the fan, cooling them down.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 08, 2012 | Hotpoint Refrigerators
The freezer stopped working but the frige seem fine. no ice build up on the defrost timer.
No model # given to reference the symtoms. I would surly worry if you had ice buildup on the defrost timer. Some are in the fresh food side and some are outside the compartments. Extreamly rare to have one in the freezer.
Also if this is a standard SxS or top mount system...everything that happens in the fresh food section, happens because of the freezer. Air moves from the ff side to the freezer. The air is cooled down and recirulates back through the freezer and to the ff side. Issue could be ...evaporator fan bad or low RPM, freezer door switch, cold control not cycling on / back on. Compressor intermittantly cycling / bad start device / weak compressor, condenser fan slow or not cycling...should be on anytime compressor is running. Some of these items can be visually checked, some require advanced knowledge and a multimeter for test. Be careful of live voltage and sharp edges.
Ric
Mar 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
My Fan in the back of freezer is not working?
You need to have a voltage tester on the fan terminals. if power is shown and motor doesnt turn, then fan must be replaced. If no power is shown, make sure you press the button on top of the door frame. basically, if door isnt closed, fan wont work.(This is referring to the freezer fan inside the cooling cabinet). If its the fan next to the compressor you are referring to, it must run at all times while the compressor is on. If not, replace it.
Jul 09, 2009 | Whirlpool ET1FHTXM Top Freezer...
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool top freezer bottom fridge
check if compressor is running if no check thermostat , bypass thermostat if comp starts change thermostat. if comp does not start call repair man as comp will have to be changed, major operation.
If comp is running OK then check evap fan motor
Oct 16, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Chest freezer
do you have voltage at the compressor? if not you have an open circuit or bad t-stat. if voltage is present and compressor is not running you have a bad start device or bad compessor. if voltage present and compressor runs you have a refrigeration issue get a new freezer.
Jul 17, 2008 | Whirlpool 14.8 cu. ft. Chest Freezer...
Whirlpool ET1MTMXKQ01
is you compressor running? do you have heat in condensor check your the evaporator for a frost pattern..
let me know if you need help
Apr 04, 2008 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool gd25sfxhs03
That click maybe you compressor cycling on its overload pertector... see if compressor is evern running..listen for a click there  .it maybe a bad relay on compressor
Oct 31, 2007 | Whirlpool ER6AHKXPQ Top Freezer...
Whirlpool ET8WTKXK Top Freezer Refrigerator Logo
1,271 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
