I need to replace my home heat pump. I've found a used Tempstar #10(?) Model No. NHP048AKA1 made by International Products Corporation. I need to know the specs of the unit. (What Ton it is (Maybe 3.5?) , Seer etc.) An owners manual or user guide online would be great. Any info' would be helpful. Thanks!
  • 1 more comment
  • J. Van
    J. Van Mar 19, 2011
    Thanks for the info. I also answer questions here and tried to locate a user guide or installation guide...so I know you're right. Any guess as to the Seer? And, how old it may be? Thanks!
  • J. Van
    J. Van Mar 19, 2011
    Thanks for your help. I'd still like to find more info if possible.
  • J. Van
    J. Van Mar 21, 2011
    Thanks for your help and your opinion! You found just what i was looking for.
  • 43,501 Answers
The unit you are looking at is a 4 ton unit...
This may help you...
http://icpindexing.toddsit.com/documents/086477/42803300105.pdf
That tech support manual is about all that is available at this point...
heatman101
Posted on Mar 19, 2011
  • D. Floyd Kolb
    D. Floyd Kolb Mar 19, 2011
    The unit will be no more then a 10 SEER
    The unit is probably at least ten years old...
    Here is the owners manual..
    http://icpindexing.toddsit.com/documents...
    Here is the spec sheet...
    This is a R-22 unit...low SEER... if you are paying anything for this unit, you are paying too much... till you get it installed, and then pay the higher cost to run it... you would be better off to buy new...of course that's just my opinion...
    heatman101
  • 8,220 Answers
NHP048AKA1 the 48 indicates 4 tons. How? 12 thou BTUs are 1 ton 4x12 =48. 4 tons.
Finding HVAC manuals and junk are not easy online.
  • Dan Webster
    Dan Webster Mar 19, 2011
    Ain't got no way of knowing. If ya install it put a new 2 way drier on there for insurance. Might not hurt to do an acid test and blow out the lines just ta give it a fightin chance. These newer models coming out need new copper because the gas works on a higher pressure. Outlawin R-22 is just a way ta make more money for greedy businessmen. My opinion.
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Identify heat pump by model #
2.5 ton. Hope this is what you are needing answered
May 24, 2015 | Heating & Cooling
Tempstar Performance Series Heat Pump
damaged capacitor most likely. open the unit and see if theres any liquid spilling from the capacitor.
Aug 09, 2013 | Heating & Cooling
Heat pump will not turn on
I would call an expert, testing needs to be done, but based on what I have seen it may be the control board of the heat pump is defective.
Mar 24, 2017 | Heating & Cooling
I need a part for my black and decker shortcut food processor...i need the shaft/blade holder model number F1-CFP-10
Per Black and Decker:
In June of 1998 Black & Decker (US), Inc. sold its Household Products business to Applica Consumer Products Incorporated.
Under the terms of the sale Applica will continue to produce appliances that carry the Black & Decker brand name. However, all issues regarding warranty, service, accessories, or parts, will be handled by Applica.
  • Please contact Applica Home Products.
    There are three ways to contact Applica Home Products:
    1. By web: Contact Applica Home Products
    2. By phone: 800-231-9786.
    3. By mail:
      Fox International
      C/O Christine Schuster
      23600 Aurora Road
      Bedford Heights, OH 44146
    Thank you for your interest in Black & Decker branded products.
  • Jul 02, 2010 | Food Processors
    How to wire rth3100c to tempstar heatpump
    Go to honeywell.com
    Under red welcome sign
    Bottom red highlighted box literature/image search
    Type in thermostat model number
    Click on arrow to right
    Then click on the PDF files owners manual / installation instructions
    If you can’t find what you want, the bottom left and bottom of web
    Page, they have homeowners assistance and Home products to get the help you need.
    Feb 26, 2010 | Heating & Cooling
    Heating & Cooling Logo
    98 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
