Question about Dryers
When i pull out the lint trap and stick my hand in as far as i can, i can feel a large buildup of lint and I don't know how to get to it
    President:
  • 3,074 Answers
You will need to open then dryer up and with a brush(paint or another soft bristled brush) and vacuum remove all the lint, might as well clean the vent tube out, here is a website that will show you how to open it up, Good Luck Tim:
http://www.partselect.com/dryer+open-cabinet+repair.htm
Posted on Mar 19, 2011
My kenmore elite dryer that i bought 2 years ago lint trap corner is catching my clothes and tearing them. we had it replaced and its doing it again. I am tired of messing with it. Please help.
don't know if you already had this fixed,usually this is caused by not having your dryer cleaned out,the lint builds up inside the duct that the lint filter slides down into and has to be removed and cleaned out.also in some of the kenmore dryer ducts there's a metal clip inside the duct that can come loose and hold the lint filter up.these are the two most likely causes for this to happen.
Sep 23, 2013 | Kenmore Elite HE4 Electric Dryer
Whirlpool dryer ler7646eq1 will not heat
First the most obvious and you've most likely covered yourself look at the lint trap/if clogged clean thoroughly with vacuum cleaner pull out lint trap and **** up as far as deep as you can get some of the lint that you don't see and believe me there's a ton depending on your exhaust/vent type . Next go outside check the vent attached to the outside of home for clogs/lint buildup lastly here's a trick I've personally used SEVERAL TIMES on my old ge dryer if you have a LEAF BLOWER pull dryer out of the way and next go outside remove exhast vent usually 4 phippls screws going out next remove vent/trap outside go back inside and use the leaf blower to blow out all of the lint caught in the vent tube your be surprised how much was in there. HOPE this quick fix addresses your dryer issue if not its most likely the dryers thermostat they're fairly cheap online. Just trying to save you a buck friend. Have a good day Ryan in Minnesota
Oct 17, 2012 | Whirlpool Dryers
How do u know if the heating coil is bad?
If you are feeling any heat at all when you place your hand by the air vent in the back, your element is at least partially working. We must determine if your model has a single or double element. If you have a double, perhaps only one side is working. To determine this, I will need the model number located under the lid or on the back of the unit.
If you have NO hot or warm air, it may be your element or the thermal fuse. Need model number.
But before we do that...
The most common cause of this is just a simple build up of lint. No matter how well you clean the lint filter during use, lint does build up and may require cleaning every few years or so. If you do have some warm or hot air and it seems to take two cycles to dry your clothes, try these simple checks (unplug dryer):
1. Insure that your vent hose is not clogged with lint. Unhook it on both ends and see if you can see through it. If there is a blockage, remove lint, reconnect and you should be fine. 2. Insure that the flaps on the vent outside of your house are free of lint and can open and close freely. If they are upstructed, clean. If they do not open or are bent, you may need to replace the vent. 3. Pull out your lint screen and see what you see? Lint build up? Take a coat hanger and bend it to stick into the lint trap well. Can you pull out any lint? Pull out as much as you can. Also look into the vent on the back...is there lint inside? Use your hanger. This may involve opening the top of the unit, or pulling off the front to clean. But let's get the model number before you get that far.
Write me back with model number or let me know if cleaning the hose and/or vent help. I look forward to assisting you.
Aug 02, 2010 | Kenmore Dryers
When I pulled the lint trap out there was much on
if it is a top lint filter take the lint filter out,turn dryer on,put your hand in it and you should feel a stong stuckion,if not remove the back panel and the 2 lint filter screws and check for clog-mike
Feb 22, 2010 | Whirlpool WED5100SQ Front-Load Electric...
The cycles have stopped heating. We have replaced the thermol fuse twice now in two weeks. Noticed when I touch the button to start a cycle, the readout is saying to check filter. Where is that? I'm...
Go outside and look at your flapper valve. Here is another news flash the lint filter can be clean but the air ducts in the dryer can still have lint build up in them. Pull out the lint trap also then using a flaishlight look underneath and around the lint trap area for lint build up. If you don't see anything there remove the rear vent hose and look both into the dryer and into the vent hose. Most likely you find either a kinded vent hose or lint buildup somewhere other than the lint trap itself. If you do find the source just do not use anything sharp to attempt to remove the lint. A bent metal coat hanger or a very large zip / spot ite works great for this task. Hopefully this will resolve your problem. If not post back and we can go from there.
Jan 14, 2010 | Dryers
Takes to long to dry clothes
Check your lint trap and piping. Make sure that no lint is clogged in the lint trap all the way to out side. This is a pretty common issue.
Jan 01, 2010 | Frigidaire GLER642A Electric Dryer
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Dryer won't heat. Motor turns tumbler. Tried
Heres what you'll need to do.
First pull out your lint trap and place your hand down in the lint trap hole not very far just enough to feel a good amount of air blowing on your hand. If you feel no breeze in there you need to clean the ducting, starting at the back of the dryer (where you hook it up at) and ending out side your house (where vents at). Snake it your self or have someone do it but just the same it has to be done.
Secondly you'll need to change you thermal fuse. If after snaking the dryer still doesn't heat. Changing the thermal fuse is easily done. Firstly you must unplug the dryer and then remove the cover off of the back of the dryer. Then you'll see the thermal fuse
e05e4038970ae97c (most of them look like this). Change it and put the dryer cover back on, plug it in and your ready to rock and roll.
Hope this helps
Jason
Apr 02, 2009 | Maytag MDE2600 Electric Dryer
The dryer turns on, but there's no heat.
Hope this helps
Jason
Apr 02, 2009 | Dryers
Whirlpool supreme dryer will not get hot
Hope this helps
Jason
Mar 21, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
