Question about Victorinox Swiss Army Professional Chronopro Watch 25162 Watch for Men
Victorinox swiss army 020233547 replace wrist band and battery
  • 6,993 Answers
First let's start with the battery replacement;
  • Set the watch face down on a flat rubber surface. This will keep the watch firmly in place and will protect it from being scratched on a more hazardous surface.
  • Use a pair of needle-nosed pliers to pull the points just far enough apart so that each point can be pushed into each of the two notches on the back of the watch.
  • Keeping the pliers pushed into each notch, turn counterclockwise to begin removing the back of the watch. Once it has been loosened, finish removing it by hand.
  • The battery will be the only part inside of the watch that is not directly connected. Make a mental note of the battery's position and then remove it.
  • Insert the replacement battery into the same spot where the original battery was located.
  • Use the needle-nosed pliers to screw on the back of the watch in the same fashion you did in Steps 2 and 3, except this time turn clockwise.
For the wrist band replacement;
  1. Measure the band around your wrist to determine how many links must be removed.
  2. Identify the arrows on the underside of the watch band. These indicate what direction the pins should be pushed.
  3. Place the pin pusher above the first pin of the band, where the band connects to the watch clasp. Make sure the pin pusher is the proper size for the pin in question. Tap the pin pusher lightly with the hammer to remove the pin. Very little force should be needed to remove the pin. If you meet with resistance, make sure the pin remover is lined up with the pin. Set the pin aside.
  4. Move the pin pusher down the watch band to the amount of links needed to be removed. Tap the pin pusher with the hammer to remove the pin and the extra links.
  5. Reattach the watch band to the claps by putting the band back in the clasp and tapping the pin back into place with the hammer.
I hope the above helps....
Good luck.
Posted on Mar 19, 2011
Swiss army watch S.A.W CO. Where do we find a list of model numbers. Model number 1789A 00146 I cant find on internet.
Swiss Army Watch S.A.W. Co was acquired at 2002 by VICTORINOX. You can find information about prouct at
VICTORINOX website and you can get more information through teit CONTACT link.
http://www.victorinox.com/ch/content/contact_us?lang=en&
Apr 23, 2015 | Swiss Army Watches
Tip
SWISS ARMY (by VICTORINOX) watch manuals.
Follow this link and download all SWISS ARMY watch manuals by clicking on Red accented HERE: http://www.swissarmywatches.co.uk/index.htm
on Feb 04, 2010 | Watches
Swiss army watch 241083, what battery does it take
Any Brand, Type 371 1.55v. I replaced the same Swiss Army Victorinox Infantry Watch model 241083 specifically with the Energizer 371BPZ Zero Mercury Battery. BTW, the replaced original was also a 371.
Jun 30, 2013 | Swiss Army Watches
What kind of battery does a victorinox officer's 1884 watch use
It might say on the back cover of the watch, if not, when you carfully pry the back of the watch off, you will see the battery, and it will say on the battery what it is.
Jan 02, 2013 | Victorinox Swiss Army Classic Officer 1884...
Replace battery for officer's 1884 watch
You have to carfully pry the back off of the watch. There you will find the battery.
Jan 02, 2013 | Swiss Victorinox Army® officers 1884 Xs...
Does the Swiss Army Wenger Alpine 72558 Wrist Watch take a battery?
Yes, it has a Swiss Quartz movement, so a battery is what makes your watch work. Need a new battery? Take it an authorized dealer or other business that has the right tool to open the case. It's not worth ruining an expensive watch just to save a couple of dollars to change the battery.
Aug 19, 2010 | Swiss Army Wenger Alpine 72558 Wrist Watch
The second hand jumps forward every 5 seconds but the watch still keeps time OK.
You need to replace battery.
Q/A from swiss army website.
Q. How do I know when the battery needs changing?
A. In select models, the battery end-of-life indicator signals that the battery should be replaced within two or three days. When the battery is low, the second hand stands still for 2-4 seconds, and then speeds up to the correct time. This indication will last for approximately one week, and then the timepiece hands stand still.
Jul 02, 2010 | Swiss Army Wenger Victorinox Swiss Army...
My swiss army victorinox chrono watch stops about once a week when the date changes, I just tap on it and it starts back up????
It sounds like the watch movement needs to be serviced. A qualified watchmaker can do this for you.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 06, 2010 | Swiss Victorinox Army Classic Chrono...
Can't get the hour hand or minute hand to move
If your watch is genuine SWISS ARMY made, then follow this link, choose your watch and download the instructions (movie style): http://www.swissarmywatches.co.uk/index.htm
Feb 04, 2010 | Swiss Army Wenger Victorinox Swiss Army...
Wenger watch
swiss army watch had battery replaced after stopping, will not restart, replacement battery new and good.
Apr 22, 2008 | Swiss Army Wenger Alpenrose 70450 Wrist...
Victorinox Swiss Army Professional Chronopro Watch 25162 Watch for Men Logo
241 people viewed this question
Top Victorinox Watches Experts
Jimmy Accardi
Are you a Victorinox Watch Expert? Answer questions, earn points and help others
