Hi antenna has low and very low signal. not able to connconnect as before. Unit is warm to touch. Q.do they wareout. it's about 2 years old thanks Peter
  • 2,794 Answers
I think it's ok if there warm. They can handle the heat. You can however get a larger antenna in some cases if that bracket that the antenna fits on is a standard fitting. Most computer carry them.
Posted on Aug 02, 2008
05 pacifica low singel only works by city radio
Hi Margaret, Im AL the owner of Big As Auto Repair
I've worked for Chrysler for over 40 years and I've found several reasons the radio has a low signal. (1) The radio itself could have a short inside. (2) The antenna or wiring could be shorted or frayed. (3) The antenna itself could be bad. Unfortunately, without running a test procedure you don't know which one is causing the problem. Hope this helps and please visit my auto-repair website and check out the testimonials of my satisfied customers. http://www.bigasautorepair.com/
Jun 20, 2015 | 2005 Chrysler Pacifica
Tried to hook up a HD antenna but it won't work
HD is pretty critical and if a indoor antenna do not expect much or anything for that matter.
Jun 17, 2012 | Televison & Video
LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Mar 20, 2010 | LG 42LB5D 42 in. LCD Television
2-3 years old, acquring signal, not ant-error,
Do you get audio out of the stereo jack? Do you have the proper antenna with TWO leads for TERR and SAT ? It could also be as simple as your antenna alignment not being to the SW, or you could have had a local repeater get shutdown. Also, this radio is several years old (designed in 2001) and could be 'shot' already from heat damage as these get really hot. I would try the radio in the car with a car antenna perched on the roof and see if it works; if it does, then it's your antenna alignment. Good luck my friend and report back please.
Jan 09, 2010 | Kenwood KTC-H2A1 SIRIUS Radio Receiver
Sirius Receiver goes silent and displays Acquiring Signal.
I have a 3 year old Sportster 2 replay unit that worked perfect until 1 month ago. I posted my problem on this website a day before you did with this same problem. I googled to no end and even spoke to Sirius who wasn't willing to replace my unit at no charge since it was out of warranty. I found an unusual solution on the internet that worked for me. I place my receiver in the freezer for at least 20 minutes (this was recommended by a guy somewhere on the internet with the same problem). I have actually left it in freezer overnight too. This has solved my problem. It is the craziest thing but I thought I would try it before I resorted to replacing all my accessories and receiver since Sirius was less than cooperative with the issue. Anyway, hope this helps.
Jun 04, 2009 | Sirius Satellite Radio Receiver
No signal are you in a building? how to fix?
have a look at the menu at the saterlite part you need at least 3 saterligths fixed to have a signal im betting you don,t have any
Jan 25, 2009 | Tomtom ONE 3rd Edition GPS
Acquiring signal
Even with the antenna looking like it is in good shape, it still may be the problem here. Physical damage may not be present, but there could be electrical damage (power surge) or corrosion on the antenna if it is in a moist environment. A quick trip to a local stereo shop can confirm this as new antenna can be plugged in to the unit to test. Also, the problem is more evident when the antenna is mounted inside the vehicle. For best reception, it is recommended that the antenna be mounted to the exterior of the vehicle and have a clear view of the sky. Make sure that there is plenty of metal underneath the antenna and you should be fine.
Aug 01, 2008 | Sirius SIR-STRC1 Satellite Radio Receiver
Air ware xm2go
The unit has an internal antenna (that is really poor) that is activated when you unplug the external antenna. This is why you get some signal when you unplug the unit.
I assume the problem is the antenna itself.
My suggesion is that you charge up the unit, take it to a place that sells XM equipment AND has a demo unit working. Be sure to take your docking station with you (it has the plug in for an external antenna). Ask the sales rep to please connect your unit to an external antenna to test your unit as you are trying to determine if your antenna is bad. If it works, you need a new antenna (cable may be cut on the inside or antenna may have water/weather damage). If it does not, then there is an electrical issue inside the unit and the unit itelf will need replacement/repair.
Jul 03, 2008 | Pioneer AirWave XM2Go Satellite Radio...
DTV conversion concerns
I just purchased a Magnovox converter at Wal-Mart with the coupon I ordered from the government program. Our TV is about 2 years old too and not HD. It has worked great. The reception and color is truly the best we've had in years. We live in the country about 50 miles from all the local stations and were told we would need a new antenna, so far the only channel we have problems with is the PBS. Not sure if it is antenna related or their signal strength. We don't have the problem until the sun comes up good. It has been great to get the additional channels that some stations have added. Hope this helps.
May 09, 2008 | Televison & Video
Unit is not locking onto signal
Check your antennae installation. Mine was frayed and I had to buy a replacement for the car.
Apr 17, 2007 | Kenwood Here2Everywhere SIRIUS Radio...
Computers & Internet Logo
David Payne
David Payne
