Question about Michele Urban Square 71-604-C-366-06 Wrist Watch
Hello. which steel band model number/part number fits the michele urban square 71-604 watch?
3 Suggested Answers
SOURCE: michele ladies watch
Anyone who says they can't open your watch is NOT a repairman. Take it to a mom and pop repairman, NOT a big store, because most of the big stores send all their repairs out to someone like the mom and pop store. If you still have problems finding someone please feel free to get ahold of me and I will assist you. Good Luck!!
Posted on Jul 20, 2008
escapement
  • 2334 Answers
SOURCE: how do you remove links
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes
Posted on Apr 04, 2011
How do I change the stainless steel band the michele mini urban?
This takes some special tools to do. Take it to your near by Jewler and they can do it for you for Next to nothing.
Sep 30, 2014 | Michele Mini Urban Diamond MWW02A000124...
My band broke on my watch and I need to replace it. It is a ST STEEL model.
Take your watch into most any jewelry store or even walmart and they will show you a number of stainless steel bands to pick from. J.
Aug 16, 2010 | Watches
How does it get sized?
You can usually have your local watch shop to shorten watchbands but if they cannot do it then you could contact Michele watches.
You could then discuss any problem you have with them.
Insert "www.michele.com/" into your search engine, at the bottom of the page on the left is a "contact us" link. Click on this for info.
Feb 16, 2010 | Michele Watches 16mm Stainless Steel Watch...
How to open Baume & Mercier Hampton Milleis ladies stainless band
Looking at your watch it looks like the clasp on the SS model is just a double deployant preasure fit. If it is brand new sometimes these style of deployants are vary tight.
It is Stainless Steel it is vary difficult to break it looking at the construction of the bracelet.
Basically you just Pull, there is no button it is just pressure fit.
mike -- consumerwatchguide.com
Jan 01, 2009 | Baume Et Mercier Hampton Milleis MOAO8242...
My michele watch band (stainless steel) is broken where it connects to the watch. Only on one side. Where do I send it to get fixed?
The best way is to find out if the manufacturer supports after sales service and post it to them if they do.
If not, you have to find your nearest watchmaker and ask him/her.
But first go to www.michele.com and try your luck.
Regards
Arthur
Dec 16, 2008 | Watches
Michele Urban Square 71-604-C-366-06 Wrist Watch Logo
21 people viewed this question
Top Michele Watches Experts
jasiel murphy
Jimmy Accardi
Are you a Michele Watch Expert? Answer questions, earn points and help others
