Question about HP SimpleSave 1 TB USB 20 Hard Drive
Have an ACER computer running Windows 7. The HP Simple Saver Portable Hard Drive exe file does not do ANYTHING when double clicked. Is it intended to work with Windows XP only?
    Master:
  • 525 Answers
Go to hps website and do a scan for devices. There it will tell you if there is compatible software for your equipment.
Posted on Mar 19, 2011
Dont work and dont format
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved. Cause, there is damage to the partition table
Solution:
1. Save the data. To saved data, you can use EASEUS Data Recovery software.
2. After the data is saved, to fix the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extrack
How to use the software HP Drive Key Boot Utility
For
Win XP, first way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For
Win XP, second way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7
, first way:
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way:
double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps
Sep 06, 2011 | Kingston Technologies 512MB DataTraveler I...
Tip
How to Troubleshoot a Toshiba Power
Click on the Windows "Start" button.Click on "Computer" or "My Computer Double-click on the primary hard drive. This is usually labeled as drive "C. Double-click on the folder labeled "Windows. Double-click on the folder labeled "System32.Right-click on the program labeled "TPSMain.exe." This is the executable program file for your Toshiba Power Saver software. "Properties.Click on the "Previous Versions" tab at the top of the window. Scroll the list of previous versions until you notice an earlier date and time when Toshiba Power Saver software worked properly. Click to highlight this listing.Click"Restore." Your computer will automatically restore your software to its previous state, before the software error began. If this does not fix the problem, your software may be corrupted by malware, and additional troubleshooting is required.Repeat Steps 1 through 6 Clickon "Scan with Microsoft Security Essentials" from the list of options.According to Microsoft, Microsoft Security Essentials is available for free to all Windows XP, Vista and Windows 7 users. Toshiba computers all use the Windows Operating System, so you should have access to Security Essentials. If you do not see the scan option, your computer probably did not come with Security Essentials pre-installed. You can download it for free at Microsoft's website. Wait while Windows automatically scans TPSMain.exe for possible malware. The s can can take several minutes. If the TPSMain.exe file is infected with malware, it can hinder performance. Click "Remove" if any malware is found.please make comment on this product by saying how helpful it is.
on Nov 02, 2010 | Computers & Internet
Tip
How to Recover Windows 2000 Password
Forgot administrator password on a system running Windows 2000 can be problematic when the administrator to perform maintenance. There is a trick that allows a computer user to reset his password, if you forgot. The process to recover a password in Windows 2003 and XP is different from the process used for Windows NT and Windows 2000.
Step 1. Insert the installation CD of Windows 2000 / DVD into the drive of the computer and then restart the computer.
Step 2. Select the destination directory for the alternative Windows operating system when the program asks you to do. This directory is not the same as the default installation of Windows. This is the computer is a dual-boot system.
Step 3. When the computer restarts, select the alternate Windows installation from the dual-boot menu.
Step 4. Find the logon.scr file. It should be located in the %systemroot%\System32 folder of the Windows folder.
Step 5. Rename logon.scr and move it into the C: folder of the hard drive. You can choose to move it to a different directory. The important thing is to remember where the file gets copied.
Step 6. Find cmd.exe and make a copy of it in the %systemroot%\System32 folder. Move this file to the C: folder of your hard drive.
Step 7. Right-click on the original cmd.exe file and select "Rename." Delete the cmd.exe text and replace it with logon.scr.
Step 8. Restart the computer and start Windows installation. Do not touch the computer until the start of the screensaver. Since the screen saver file, get the default is replaced with the file cmd.exe, then a command prompt instead of the screen saver.
Step 9. At this prompt type: net user administrator <password>
Step 10. Delete logon.scr from the %systemroot%\system32 folder.
Step 11. Issue the following commands from the command prompt:
copy c:\logon.scr c:\windows\%systemroot\system32
copy c:\cmd.exe c:\windows\%systemroot\system 32
Step 12. Restart the computer in the original. From here you can remove the additional installation if desired. If the administrator installation alternatives are on a different drive or partition to reformat the hard disk or partition is the easiest way to achieve this goal.
on Apr 26, 2010 | Computers & Internet
Sudenly kingstone usb changed to skymedi and doesnt formated
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
Win Vista & 7: double click the file cp006049.exe - select extract
For Win XP, first way
For Win XP, second way
For Win Vista & 7, first way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
I am expecting your Expert's advices for retrieving my Excel files from the "Microsoft Office XP Professional with FrontPage " system which I erased by mistake on Saturday, August 6, 2011
Depending on how much you have used your computer since deleting the files they still may be in your recycle bin.
Open (not empty!) your recycle bin. (right click and select OPEN). On the tabs accross the top click on FILE TYPE which will sort by the type of files. Locate all the files from excel and highlight them. Right click and click restore.
Aug 08, 2011 | Computers & Internet
My HP officejet 4110 all in one PRINTER DOES NOT SCAN
I would like to inform you that scanning involves bi-directional communication between the All-in-One and Computer, to check if the All-in-One is able to communicate with the Computer, please follow the steps below to scan a document or image from Windows Imaging Acquisition.
1. Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2. Click Start.
3. Click All Programs.
4. Click Accessories.
5. Click Scanner and Camera Wizard.
6. Follow the Scanner and Camera Wizard instructions to scan images to the computer
If you are able to scan from Windows Imaging Acquisition, then the All-in-One is able to communicate with the Computer, at this situation, please follow the steps below to resolve the
issue.
Before perform the below steps, I request you Download and run the HP Scan Diagnostic Utility and check the functionality of the All-in-One. If the issue persists please follow the further steps.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-45265-1&lc=en&dlc=en&cc=us&product=391153&os=228
NOTE: Clicking the link may give an error indicating it is invalid. Copy the entire link from "http://" to "&os=228" and paste it in your local Internet Explorer Address bar.
====Run the file hpqtra08.exe ======
1. Click Start and then click Run.
2. Click Browse.
3. Verify that C: is selected in the Look in section, and then locate and double-click Program Files from the list of folders.
4. Double-click the Hewlett-Packard or HP folder.
5. Double-click the Digital Imaging folder.
6. Double-click the Bin folder.
7. Double-click the hpqtra08.exe file.
=====Run the file hpqscnvw.exe=====
2. Click Browse.
7. Double-click the hpqscnvw.exe file.
Performing the above steps will resolve the issue if the issue persists , we need to reinstall the All-in-One software.
Please follow the steps below to uninstall All-in-One Software drivers from your Computer.
1. Turn the All-in-One off and disconnect any USB/Ethernet cable from All-in-One to computer.
2. Insert the all-in-one CD-ROM into the computer. Cancel any installation windows that appear.
3. Click Start on the taskbar and then click Run.
4. In the command box type the following command and press Enter key:
X:\Util\CCC\Uninstall_L3.bat
Note: Here X: is the CD-ROM drive letter. You can locate the CD-ROM drive letter by opening "my computer". For example if the CD-ROM drive letter is E: then you will type E:\Util\CCC\Uninstall_L3.bat instead of X:\Util\CCC\Uninstall_L3.bat.
Now that we have uninstalled All-in-One Software drivers from your PC, lets proceed with the installation steps.
NOTE: Do not connect the USB cable until instructed to do so.
1. Close any open programs, including antivirus programs.
2. Insert the HP Officejet software CD.
NOTE: If nothing appears on your computer screen after inserting the CD, click Start, and then Run. In the Run dialog box, type d:\setup.exe (where d is the CD-ROM drive letter).
3. Follow the on-screen instructions to install the software.
Now check the functionality of the All-in-One.
Please get back with your observations and the results which will help me to assist you further if required. It is our responsibility to serve our esteemed customers like you in the best possible way. We appreciate your support and cooperation.
Have a nice time !!
May 07, 2010 | HP Officejet 4110 All-In-One InkJet...
Compaq lan driver
Thank you very much!!
You can downlaod the Lan driver for Windows Vista here:
For Windows 7:
  1. Click on the link that represents your Windows version to download the appropriate driver.
  2. Save the file on your computer.
  3. After downloading double-click the file to start the installer.
  4. Follow the instructions to complete the installation.
This will update your Lan drivers!!
Best regards!!!
Jan 06, 2010 | Computers & Internet
My C:\drive is full and i have removed files to make space but it stil says there is not enough space on drive. What can i do?
Copy this text into a word document, print it and have it next to you when you ferform this:
Perform the steps given below to increase you system performance and clear space.
Uninstall all unwanted software:
To uninstall software
Click on Start -> Settings -> Control Panel -> Add/Remove Programs
Select the software (one at the time) from the list and click on Add/Remove button and follow the online screen instructions.
Erase unnecessary files in the windows temp folder.
Double Click My Computer.
Double Click the drive where windows are installed. This is typically drive C.
Double Click the windows folder. This is typically C:\Windows.
Double Click the temp folder. This is typically C:\Windows\temp.
Press control A to select all files and folders.
Press the delete key.
If confirmation is asked to delete these files choose yes to all.
Defragment hard disk.
Close all applications.
Disable your screen saver.
Disable all the programs on the taskbar if possible.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag.
You should defrag every hard disk on your system.
This process can take quite some time.
Click Ok.
Enable your screen saver.
Remove Startup programs (if you know what you are doing)
Click Start
Select Run
Type msconfig in the text box
The "System Configuration Utility" window will open
A list of programs will be shown each having a checkbox to the left of the name.
Click on the checkbox to enable the program (so it runs when windows boots) and click a second time to Uncheck the box to disable the program (so it does not run when windows boots).
Set the size of the virtual memory (swap file) to a constant optimal size.
Right click My Computer
Click Properties
The System Properties window lists the amount of RAM in your PC
Click Performance
Click Virtual Memory
Click Let me specify my own virtual memory settings
Click the arrow next to the hard disk.
Here are some guidelines to choose the best location for your virtual memory file
a) Select the quickest hard disk.
b) If you have, two hard disks that are similar in performance select the hard disk that does not contain Windows system files (usually C:).
c) Make sure the drive has free space equal to at least twice the size of the recommended swap file size.
d) If the partition is on the same physical drive, select the partition in alphabetical order. For example, if you have one 20GB hard disk and you partition it into two 10GB partitions drive C & D) You should pick Drive C over Drive D if meets all the guidelines of a, b & c.
Set the Minimum/Maximum to: With large hard disks settings at least 128mb or 256mb swap file should be sufficient in almost every situation.
Note: The amount of RAM plus the size of the virtual memory file is the maximum amount of RAM you can use at once.
Click OK.
After setting the size of the virtual memory file windows will display the following message. You have chosen not to let windows manage virtual memory automatically.
Click Yes.
You must restart your computer before the new settings will take effect. Do you want to restart your computer now?
Click Yes
Next :-) please vote if this help you
Nov 30, 2008 | Acer Computers & Internet
Gateway mx6930 laptop freezes up every 10 minutes - keyboard and mouse become inoperable
Perform the steps given below to increase you system performance.
Uninstall all unwanted software.
To uninstall software:
Erase unnecessary files in the windows temporary folder.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag. You should defrag every hard disk on your system. This process can take quite some time.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
Nov 29, 2008 | Computers & Internet
HP SimpleSave 1 TB USB 20 Hard Drive Logo
120 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
