Question about RCA P52937 52" Rear Projection Television
RCA P52937 WAS MAKING LOAD HUMING NOISE FOR A WEEK NOW TV WILL NOT TURN ON AT ALL, POWER SUPPLY ??
  • munisr Mar 19, 2011
    YOU THE MAN !! THANK YOU
  • RCA Master
  • 6,993 Answers
the problem is either from the power supply or projection lamp. Does you TV has a green standby light in front of it when you turn? If yes, then replacing the projection lamp should solve the problem. If no, then fault is from power supply which means power problem.
POWER: The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 19, 2011
Testimonial: "THANK YOU I WILL CHECK IT OUT IN THE MORNING. I LIKE THE PICTURE ON THIS TV AND DO NOT WANT A NEW SET."
    NO GREEN LIGHT COME ON WHEN I HIT THE POWER BUTTON, WOULD THE CAPASITOR CAUSE THE HUMMING I WAS HEARING?
  • Walesarumi
    Walesarumi Mar 19, 2011
    yes, it can cause it....
Hi my rca p52937 won't turn on and is making a
The ticking sound is almost always caused by the Flyback and Hot transistor. It could be other items also located on the deflection board but flyback is most likliest. You can get a replacement flyback and Hot tarnsistor from www.tvrepairworld.com
Jul 07, 2011 | RCA Televison & Video
RCA 52 PROJECTION TV MODEL P52151WK
No , if fuse was blown you would not get the popping. How old is unit ? It sounds like your high volt splitter. common problem with rca. repair should not cost more than 250.00. you will want to have chassis number  and manu date for help
www.classtorations.com
Jun 04, 2008 | RCA P52937 52" Rear Projection Television
RCA P52937 52 in. Rear Projection Television
It almost has to be a power supply problem, probably in the high voltage stages... Regulator, Horiz. Output.
Geno
Mar 01, 2008 | RCA P52937 52" Rear Projection Television
RCA Big Screen - Power turns on but then it powers off intermittently
The power supply section is having trouble.
Common possibilities are:
- Convergences amps are failing, overloading the supply
- High-voltage section (flyback transformer) is failing
(happens sooner or later, about 8 years typical))
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Feb 19, 2008 | RCA P52937 52" Rear Projection Television
A buzz nosie every time i plug in the t.v
COULD BE AN OLD ELECTROLYTIC CAPACITOR IN THE POWER SUPPLY
Nov 04, 2007 | RCA P52937 52" Rear Projection Television
Rca tv
my son cracked our screen protector and instead of paying two or three hundred dollars to replace it we had plexy glass cut at Lowes and put velcro striping around the edges and looked as good as the original and has held up great for five years now.
Oct 26, 2007 | RCA P52937 52" Rear Projection Television
RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Aug 02, 2007 | RCA P52937 52" Rear Projection Television
No power
The P52937 uses the PTK195 series chassis. If the TV makes a squeeling noise the instant it is plugged in then unplug it immediately and do not plug it back in. I have seen this many, many times. The flyback (high voltage) transformer has shorted out and the extra current it was drawing has shorted out the horizontal output transistor, so the B+ supply is dead shorted and the power supply squeels as a result. This is very common in that chassis. The flyback and output transistor will have to be replaced by someone with experience in RCA projection TV's. The HV block in the PTK169 sets is the one known to be bad a lot - the block in the 195 is very reliable and I have never seen one of those bad.
Jul 05, 2007 | RCA P52937 52" Rear Projection Television
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
RCA P52937 52" Rear Projection Television Logo
238 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
