Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
Draining Problem Water has begun draining into the internal tank rather than through gardenhose.
Mine had the same problem. Make sure the unit is tilted towards the side with the hose attached (hose side low)
Posted on Aug 17, 2008
New dehum0 ran great fro months,. beginiing in earl spring no water, unit turns on can feel air circualation, 'sounds' like it s workdingllllllll=======returnt to machine hours later,,,, not a drop ofmoisture....I removed parts hosed out the coils no real junk presen. put it back togher. operatig as previously... stil no liquide behig absorbed. The basement is wet and very must smelling. 'After the recemmmemded full cleaning...what step do i check next in my diysf profect?
Posted on Jul 16, 2009
Dehumidifier is not draining out of the hose.
The hose is most likely clogged. Try blowing into the end of the tube to loosen up the dirt in the water tank. You can use compressed air if you have it but plan on water spilling out of the back to be safe.
Jun 03, 2015 | Soleus Air DP2-70-03 aka SG-DEH-70-2...
Why does water leak onto the floor instead of draining into the tank?
The hose connector should be capped or a hose connected and directed to a floor drain.
Apr 29, 2015 | Amana D930M 30 Pint Dehumidifier
We have a DE65EK-2 dehumidifier. Currently the device is draining to the stogage tank which needs to be emptied manually. We want to be able to make the hose connection in the rear of the unit and directly...
Just punch out (or cut) the plug that the hose connects to. If not, it will block the water from draining to the hose. Should not need any adaptor.
Please rate 4 stars if this is helpful. Thanks and good luck!
Sep 09, 2017 | Dehumidifiers
My delonghi airadry slim is not draining through the hose
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Keep it in case you want to go back to the bucket.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Jul 29, 2017 | Dehumidifiers
Our dehumidifier isn't draining into tank anymore and shuts off.
Daniele, the drain hole or drain hole tubing, that that flows thru to the bucket may be clogged. To loosen & remove the clog, do the following:
1. Turn the Master ON/OFF Switch to OFF & unplug the unit.
2. Remove the bucket from the unit.
3. Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though).That's appropriately sized to fit into the hole or tube. Carefully insert the Zip Tie in to the drain hole or tube and continue to insert it until you reach a bend in the tube. You must gingerly work it past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. Slowly pull it back out while rotating (twisting) it, This will help dislodge any clogs. As you reach the inserted end of the Zip Tie, be prepared for some water to follow.
Completing the above, should dislodge any clogs and water will start draining back into the tank. Be sure that you have the humidity extraction level set on 35%, after you turn the unit back ON.
Jul 05, 2011 | Kenmore 54501 Dehumidifier
I have attached the hose to the Danby dehumidier and put the water tank back into the machine. I pressed continuously flow and the humidity indicator is at 87 The water tank was full later with the...
Oct 14, 2017 | Danby Dehumidifiers
My Danby dehumidifier leaks out of the bottom. Water not draining into the tank but around the tank therefore out of the bottom between the tank and the dehumidier itself
The drain tube or hole that drains into the bucket is probably clogged.
Turn the unit OFF and remove the bucket. Look in the cavity where the bucket was removed for a drain tube or drain hole. Using an 18" long plastic Zip Tie or something similar (No wire coat hangers) , that's appropriately sized to fit in the hole. Carefully feed the ZIP Tie into the hole or tube and thread it as far as you can. At some point the drain will curve, but you have to carefully get past this point. Once the Zip Tie has reached as far as it can, slowly pull it out while rotating it. This will loosen the clog. Once you have it half way out, be prepared for water to follow. This method should solve the problem.
Mar 23, 2011 | Danby Dehumidifiers
I want to change my deLonghi Dehumidifier from emptying into the container to continuous flow into the sink. I was given this from a friend, not new and dont have a manuel or the hose to change it over....
You may have a older model that has a collector tank with a protruding tube on it. If so just cut the end off the tube and slide on a piece of clear 9.5mm internal diameter PVC / Rubber tubing suitable for a fish tank air / water pump and secure it with a nylon tie wrap.
Continuous external draining for newer models with clear collection tanks.
If the appliance is to be operated for long periods of time but you are unable to empty the tank, you are recommended to use the continuous drain facility.
• Drill the inside of the drain spout using a small drill bit. This is located behind the rear grlle in the lower centre of the opening.
• Fasten the rubber hose to the spout. For models without drain hoses supplied, we suggest you purchase a rubber hose around 2m long, with an internal diameter of 9.5 mm.
• Make sure that the hose is not higher than the spout, otherwise water will remain in the tank; also check that the hose is not twisted. N.B: Keep the rubber bung. You will need it to plug the hose or close the spout if you revert to draining into the tank
Sep 28, 2009 | DeLonghi Dehumidifiers
Change my dehumidifier from draining by hose, to reservoir
I don't have the exact dehumidifier as yours, but on mine it's as simple as removing the hose, then the water fills the reservoir. Does it look like yours will do the same? If so, the hose fitting is also a sensor that will shut the unit off when it is full to avoid leaking onto the floor.
Sep 11, 2009 | Maytag M3DH30B2A Dehumidifier
Tank still fills when we are using direct drain feature
check to see that the hose isn't clogged, and that the hose runs down hill from the tank all the way to the drain. if it is higher than the tank at any point in its path it will not drain. you may put the dehumidifier on top of a small platform to aid drainage. also check that the knockout removed so there is a hole to let the water go from the tank to the hose?
Sep 24, 2006 | Danby DDR2504 Dehumidifier
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
584 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
