Question about Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE Model number 110.27062603. When starting a load the water temperature lights flash in order. It will keep running and then you will hear a beep and the light will stop. You will then hear another beep and it will start running through the different lights again. This is continuous throughout the whole load. Then yesterday it turned itself on while the lid was opened.
jsrock516
  • 5911 Answers
SOURCE: kenmore oasis elite he
Have you tried leaving the washer unplugged for at least 30 minutes? The manufacturer recommends, first unplugging the appliance for this duration to reset the control board. In some cases this will correct momentary glitches. If this does not resolve your problem, you will need to inspect your drain pump. The "ld" error code is a Long Drain problem which is usually an indication of a clog in the drain pump or drain line, or a failed drain pump. This model washer has two pumps, I believe. One is a recirc pump, the other is the drain pump. The drain pump is below the wash tub on the RIGHT hand side (as viewed from the front of the washer). The way you access the pump is by tilting the washer backwards and working from underneath, or by removing the back panel of the washer. In order to safely tilt the washer, however, you will need to drain the wash tub. The easiest way to accomplish this without bailing is to remove the drain hose from the standpipe at the wall and pull a vacuum on the line with a wet/dry shop vac. You will need to empty ALL residual water in order to remove the drain lines to inspect the pump. If you do not, be prepared to mop up a lot of water. Your washer has one of the largest wash tubs available.
There is also a tech sheet inside your washer with all the error codes and recommended troubleshooting advice. You can access the tech sheet by locating the release tabs along the front of the washer where the top cabinet meets the front of the washer. About 2 inches in from each side you will find a tab in the seam. Use a putty knife and push straight in while lifting up to release. NOTE: This may require some muscle to do. Once you have the top free, hold on to the washer lid BEFORE you lift up the top or the lid will fly open. The tech sheet should be attached between the front washer case and wash tub.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 16, 2008
SOURCE: i have a kenmore oasis elite it beeps all the time and flashes F2
Code F2 means a stuck button. I removed the interface and lightly sprayed each with contact cleaner. So far this is working. The interface costs about $160 and contact cleaner, $10. Good luck.
Posted on Mar 18, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore elite oasis F2 (and beeping _
This code indicates a pump issue. First, remove and clean the filter. Then you need to check out the pump. Take a flashlight and look into the suction port on the pump. Check the impeller for broken or missing blades and make sure that the impeller moves freely. If any blades are broken or missing or if it won't move freely, the pump will have to be replaced. Hopefully, it is just clogged, but no matter how diligent we are, some items like coins, tacks, pens/pencils, or other hard items make it into the washer and some can end up at the pump and can damage the impeller or clog up the pump. Hope this helped and best wishes.
Posted on Sep 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis 27062, the lid lock broke
Simply attach both wires from the switch to jumper.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Posted on Sep 25, 2010
I have a model 27096 top load kenmore elite oasis he washing machine that keeps flashing code F2 and keeps turning itself on. Help
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Why is my kenmore elite (top loader) oasis washer HE is displaying a code of HC
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
Apr 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore oasis won't completely drain and flashes "LD"
Does the pump keep running and then shut off first if so you can try this .It is not the proper way but sometimes you have to wait for the machine to go into the spin drain cycle and tilt it gently a few times like an old pinball machine. I sometimes have to do that. but I want you to know it is not the best for the machine you could break something else while doing this
Dec 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer oasis he, mod 110.27062603
to andreya ,,, the code dl means door latch ,,,, you door latch is bad on your machine
to afinebalance ,,,, the f1 code is the control board and it too is going out and it isnt cheap ,,,,
if ya'll want to send me your complete model and serial numbers i will check on the parts for both or you.
Larry
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
Ok these are not the series 70, getting a model number off the door will reallllllly help. Some of these sound like the oasis. F1 is motor control or primary control failure and F 41 is a rps thermistor failure.
For the guest with the 11027086601 kenmore elite oasis here is a link for supplying me with a partial model number, much thank yous!! paste in a browser:)
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=11027086601&productCategoryId=0153200&brandId=0583&modelName=RESIDENTIAL WASHER&diagramPageId=00002&componentDescription=CONTROL PANEL PARTS&documentId=K0601003&backToLink=Return to Sub Components list
Aug 02, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
140 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
