Question about Mitsubishi SD200U Multimedia Projector
We have a Mitsubishi sd200u projector.The right side of the screen is dark,there is still picture but very dark.We thought it was the bulb,ordered and replaced that,and we are still having the same problem.What could it be??
  • 442 Answers
Does the dark side have a well defined straight vertical edge or is it ragged and blurry.
Is the picture still visible in the dark area, or has the picture disppeared and there's this darkness that has taken over.
I'm thinking that the optics may have been jolted. Has the unit suffered any impact or the like.
Posted on Mar 19, 2011
Dark spot in middle
A plastic prism between the lens and the lamp is melted. can't find part no. PLNS-A056WJN2
Jun 30, 2013 | Sharp XR-10X Multimedia Projector
I HAVE A SONY WEGA PROJECTOR TV KDFE60A20 I CHANGED THE LAMP AND THE PICTURE IS TOO DARK BEFORE I WATCHED THE TV FROM THE SIDE WITH THE WINDOWS OPEN AND NO PROBLEM NOW I HAVE TO CLOSE THE WINDOWS AND
my first thought would be new bulb needed but if you have changed bulb can't be that.
is the wall white?
is there a setting to say what colour you are projecting on?
good luck
Jan 20, 2013 | Sony Lamp For Sony KDFE60A20...
Tv is getting dimmer
Brenda, Your projection bulb is about to die. Go on eBay, so a search for the bulb. Only buy a genuine Mitsubishi bulb to replace it. Or order one of these;http://www.shopjimmy.com/mitsubishi-wd-65c9 Get one of the "assemblies".
Removing and replacing the bulb unit is SUPER easy. Unplug the TV!! You unscrew the one screw on the litle door and the lower right, back side of the TV, then unscrew those two screws that hold in the unit, and slide it out. Slide in the replacement, and tighten everything up. Put the door back on, and plug it in.
Nov 25, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
Loosing picture
replace the light tunnel
Mar 27, 2010 | InFocus X1 Multimedia Projector
I have an Mitsubishi X490U Multimedia Projector - it hangs inverted in our church auditorium. The image on the screen looks okay with bright images projected, but dark images appear to look green...
This unit needs a new Optical block, most likely more than a new projector
check out projectorsuperstore.com for a replacement
by the way, your $10,000 projector only has 2600 lumens, a new/refurbished unit will have 4000 lumens for less than 25% of the cost of your unit
Jul 11, 2009 | Mitsubishi X490U Multimedia Projector
Optima H30 warning
OK, found the solution on the net, you have to use the buttons on the projector instead of the remote to access the menu item.
Aug 25, 2008 | Optoma H30 Multimedia Projector
Infocus X1A Projector
This is a very common issue with the Infocus projectors. Sounds like the mirror tunnel that sits right behind the Color Wheel and concentrates the light source onto the DLP chip. This tunnel which is shaped like a small prism is very fragile and can "fall apart" over time. Some have attempted to try and remove the tunnel and repair with limited success. Otherwise you may either need to send the unit in for repair or find a dealer who can order the part for you.
Here is another who had the same issue;
http://www.fixya.com/support/t401456-infocus_x3_video_problem
Mar 14, 2008 | InFocus X1 Multimedia Projector
Bright then dark
check bulb life time if it is near end change it.
Feb 14, 2008 | Mitsubishi XL1XU Multimedia Projector
Mitsubishi SD200U Multimedia Projector Logo
487 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
